[snappyHexMesh] How to Refine Symmetry Faces/Edges |
April 12, 2023, 10:35 |
Hello there,
I have a problem to refine the right edges of my system. Since I can use symmetries, I only have to calculate 1/4 of the whole system. But my Problem is that I cannot refine the edges of the symmetry faces, only the other not necessary edges are refined with refine surfaces. here is a screen of paraview: https://imgur.com/a/B0rA7Kx Here is my snappyhexmeshdict: Code:
// Which of the steps to run castellatedMesh true; snap true; addLayers false; //true; mergeAcrossPatches true; // default false geometry { Body.stl { type triSurfaceMesh; name body; } InletRight.stl { type triSurfaceMesh; name right; } }; // Settings for the castellatedMesh generation. castellatedMeshControls { maxLocalCells 10000000; maxGlobalCells 200000000; minRefinementCells 0; maxLoadUnbalance 0.10; nCellsBetweenLevels 1; features ( ); refinementSurfaces { body { // Surface-wise min and max refinement level level (1 3); // Optional region-wise level specification } right { // Surface-wise min and max refinement level level (0 0); // Optional region-wise level specification } } resolveFeatureAngle 30; planarAngle 30; refinementRegions { /* body { mode inside; levels ((1.0 2)); } */ } limitRegions { } locationsInMesh ( ((0 0.003123 0) body) ((0.00085 0.006486 0) right) ); allowFreeStandingZoneFaces true; /* locationsInMesh ( ((-0.09 -0.039 -0.049) bottomAir) // cellZone 0 ((-0.09 0.009 -0.049) topAir) // cellZone 1 ((-0.09 0.001 -0.049) leftSolid) // cellZone 2 ((0.02 0.001 -0.049) rightSolid) // cellZone 3 ((-0.001 -0.039 0.0015) heater) // cellZone 4 ); */ // Per synthesised faceZone name the faceType and type of baffles to // create faceZoneControls { bottomAir_to_heater { // Optional specification of patch type (default is wall). No // constraint types (cyclic, symmetry) etc. are allowed. patchInfo { type patch; inGroups (patchPatches); } faceType baffle; } } } snapControls { nSmoothPatch 3; tolerance 2.0; nSolveIter 30; nRelaxIter 5; // Feature snapping // Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 3;//10 // Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false;//true // Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //false // Detect features between multiple surfaces // (only for explicitFeatureSnap, default = false) multiRegionFeatureSnap true;//false //- When to run face splitting (never at first iteration, always // at last iteration). Is interval. Default -1 (disabled) //nFaceSplitInterval 5; // (wip) Optional for explicit feature snapping: //- Detect baffle edges. Default is true. //detectBaffles false; //- On any faces where points are on multiple regions (see // multiRegionFeatureSnap) have the other points follow these points // instead of having their own independent movement, i.e. have snapping releasePoints true;//false } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Layer thickness specification. This can be specified either through the // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of the layer furthest away from the wall. // If relativeSizes this is relative to undistorted size of cell // outside layer. finalLayerThickness 0.3; minThickness 0.1; layers { body { nSurfaceLayers 1; } maxY { nSurfaceLayers 1; // Per patch layer data expansionRatio 1.3; finalLayerThickness 0.3; minThickness 0.1; } // Disable any mesh shrinking and layer addition on any point of // a patch by setting nSurfaceLayers to 0 frozenPatches { nSurfaceLayers 0; } right { nSurfaceLayers 1; } maxY { nSurfaceLayers 1; // Per patch layer data expansionRatio 1.3; finalLayerThickness 0.3; minThickness 0.1; } // Disable any mesh shrinking and layer addition on any point of // a patch by setting nSurfaceLayers to 0 frozenPatches { nSurfaceLayers 0; } } // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 1.7.x! (didn't do anything in 1.7.x) nGrow 0; // Advanced settings // Static analysis of starting mesh // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular. Note: was not working correctly < 1806 featureAngle 120; // When to merge patch faces. Default is featureAngle. Useful when // featureAngle is large. mergePatchFacesAngle 45; //normally off // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Patch displacement // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Smooth layer thickness over surface patches nSmoothThickness 10; minMedialAxisAngle 90; maxThicknessToMedialRatio 0.3; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; slipFeatureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Mesh shrinking // Create buffer region for new layer terminations, i.e. gradually // step down number of layers. Set to <0 to terminate layer in one go. nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will // exit if it reaches this number of iterations; possibly with an // illegal mesh. nLayerIter 50; // Max number of iterations after which relaxed meshQuality controls // get used. Up to nRelaxedIter it uses the settings in // meshQualityControls, // after nRelaxedIter it uses the values in // meshQualityControls::relaxed. nRelaxedIter 20; // Additional reporting: if there are just a few faces where there // are mesh errors (after adding the layers) print their face centres. // This helps in tracking down problematic mesh areas. //additionalReporting true; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { // Specify mesh quality constraints in separate dictionary so can // be reused (e.g. checkMesh -meshQuality) #include "meshQualityDict" // Optional : some meshing phases allow usage of relaxed rules. // See e.g. addLayersControls::nRelaxedIter. relaxed { // Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 75; } // Advanced // Number of error distribution iterations nSmoothScale 4; // amount to scale back displacement at error points errorReduction 0.75; } mergeTolerance 1e-6; // I have removed some // comments, so it could be the case that some brackets are wrong now, but i hope that you can help me. |
Simulation of a chimney with heat in open atmosphere | Jurado | OpenFOAM Running, Solving & CFD | 9 | December 18, 2020 07:35 |
rhoSimpleFoam - Newbie Issues | AndyR | OpenFOAM Running, Solving & CFD | 6 | March 10, 2020 09:28 |
High nut values in random place and time | krzychu111 | OpenFOAM Running, Solving & CFD | 0 | January 9, 2019 08:42 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
