[mesh manipulation] Problems with using the extrudeMesh to create a pseudo-2D axisymmetric mesh from the
Old   May 27, 2023, 09:37
Default Problems with using the extrudeMesh to create a pseudo-2D axisymmetric mesh from the
John Holmes
Korasamy is on a distinguished road
Hello everyone! I want to obtain a pseudo-2D axisymmetric mesh and first I used the ICEM to build a 2D mesh because I think it is more convenient for me than blockMesh. And then I used the command “fluentMeshToFoam xxx.msh -scale 0.001” to convert it. After conversion, I run the command “autoPatch 60” to separate the automatically generated patch “frontAndBackPlanes” to “auto6” (the front face) and “auto7” (the back face). I set the sourcePatch “auto6” and the exposedPatchName “auto7” in extrudeMeshDict. Next, I ran the command “extrudeMesh” and generated a wedge. But I found that the patch AXIS had faces it should not have had. So, I run the command “collapseEdges” and collapse 0 edges even when I set the minimumEdgeLength a big number higher than the minimum edge length. And checkMesh all failed after doing extrudeMesh. Some photos and files are uploaded as supplements for my problem. I have spent nearly two weeks in it, and searched a lot for instruction, but all my attempts have failed miserably. I am feeling very down at the moment, and I really wish you would help me if it would be convenient for you. Many thanks in advance!
Korasamy is offline   Reply With Quote
2d mesh, collapseedges, extrudemesh, icem, wedge
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[mesh manipulation] Generating 3-D axisymmetric mesh using extrudeMesh martyn88 OpenFOAM Meshing & Mesh Conversion 17 June 21, 2017 19:42
[ICEM] How can I create prism mesh for a 3D domain surrounded by a torus? lzgwhy ANSYS Meshing & Geometry 5 May 18, 2017 17:10
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
