May 24, 2023, 01:40 |
snappyHexMesh -parallel
Rep Power: 5 |
Hii all,
i have been trying to run my openfoam case in parallel, I have managed to do that with the following code. I am actually getting results and they look good. I wanted to double check the code to make sure that there is no error/mistake before i run all of my cases. ################## mkdir 0 cp constant/turbulenceProperties_sst constant/turbulenceProperties blockMesh decomposePar -force -copyZero mpirun -np 16 snappyHexMesh -parallel -overwrite reconstructParMesh -constant -mergeTol 1E-06 rm -rf processor* extrudeMesh checkMesh rm -fr 0 cp -r 0.org 0 setFields decomposePar mpirun -np 16 olaFlow -parallel touch full.foam ########## Did i do something terrible ? Please help Paul |
May 27, 2023, 00:18 |
#2 | |
Farzad Faraji
Rep Power: 7 |
I think it is better to add
reconstructPar -constant Code:
reconstructParMesh -constant -mergeTol 1E-06 Farzad Quote:
[snappyHexMesh] snappyHexMesh in parallel | shailesh.nitk | OpenFOAM Meshing & Mesh Conversion | 33 | January 25, 2022 10:35 |
snappyHexMesh parallel, avoid reconstructParMesh | Tom Lauriks | Main CFD Forum | 2 | April 27, 2020 11:47 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
[snappyHexMesh] SnappyHexMesh in Parallel problem | swifty | OpenFOAM Meshing & Mesh Conversion | 10 | November 6, 2015 04:40 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
