[surface handling] Separate feature file per STL from surfaceFeatureExtract
Old   August 2, 2023, 11:30
Default Separate feature file per STL from surfaceFeatureExtract
obscureed is on a distinguished road
I'm using surfaceFeatureExtract to extract feature edges from a collection of different STL files. Is there a slick way to specify multiple .stl file names, and get a separate .eMesh.gz file for each? The motivation is that different levels of refinement are used at different edges, so the STL names are a good way to keep track of them.
It is possible that I am abusing surfaceFeatureExtract, which gives a message about "only valid on closed manifold surfaces". I'm presuming it's OK to ignore that message? -- the workflow has been fine in Foundation-style OpenFOAM 10 (using surfaceFeatures).
In OF10, I can specify a list of surfaces. The controls seem to be just lying around in the file -- I presume they take effect (or maybe I have been using the defaults all these years).
FoamFile { version 8.0; format ascii; class dictionary; object surfaceFeaturesDict; }
surfaces (
  "w-floor.stl"
  "w-outside.stl"
  "w-sides.stl"
includedAngle 150;
trimFeatures { minElem 1; }
writeObj yes;
In ESI-style OpenFOAM 2306, I can specify many files -- I can even match all the files with a wordRe, as below. Unlike in OF10, though, this generates only a single file, multiple123.eMesh.gz file. Is there a way to get a separate output file for each matching STL?
FoamFile { version 8.0; format ascii; class dictionary; object surfaceFeatureExtractDict; }
multiple123
  surfaces (".*stl");
  extractionMethod extractFromSurface;
  includedAngle 150;
  writeObj yes;
  trimFeatures{ minElem 1; minLen 0.01; }
  subsetFeatures{ openEdges yes; }
  loadingOption file;
While I'm here, can I also ask: what are the meanings of "offsetting" and "subsetting" in https://www.openfoam.com/documentati...xtract_8C.html -- where are they discussed in documentation?
obscureed is offline   Reply With Quote
[snappyHexMesh] stringing of feature edges Hr_kules OpenFOAM Meshing & Mesh Conversion 0 July 22, 2022 08:30
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
