[blockMesh] blockMesh - Curved surface - 3D - edge grading |
August 1, 2023, 22:21 |
Desh
Rep Power: 5 |
Hi Foamers,
I am attempting to get to perfect mesh using blockMesh. my geometry has a curved channel, please see the figure. So far the mesh is error free but checkMesh complains over high orthogonal cells. Theses cells are located along the y-axis, at the very edge of the curved channel ( along the curved line towards the end of top right). I've tried edge grading to make those cells bigger as possible which seems to solve the problem but I am losing the smoothness of the curve. I've attached the blockMesh file as well. PHP Code:
Or do I have to say good buy to my good old friend (blockMesh) and turned into snappy ? your thoughts on this highly appreciated. Thank you PS: my mesh could be fine as it is but I am always too sceptical about it. |
August 1, 2023, 23:40 |
Lucky
Rep Power: 66 |
snappy is not that scary. But the key to blockMesh is understanding that you need a topology change. You have a 3-way singularity meeting on a surface. You need to relieve the grid stress and allow that singularity to occur inside the domain to improve the orthogonal quality. Still, it is quite cumbersome to define all the edges in blockMesh and snappy can save you a lot of time.
August 2, 2023, 02:16 |
#3 | |
Desh
Rep Power: 5 |
Thank you for the quick reply. Sorry I forgot to mention, apart from my personal preference, 99% of the time, I'm dealing with 2D geometry unlike this example. And as you know, Snappy meshes in 3D which I really do not need to. Quote:
Thank you Dasith |
blockmeshdict, curved channel, edgegrading |
leading edge 3D surface mesh problem | Muggy | STAR-CCM+ | 1 | May 4, 2020 07:12 |
[snappyHexMesh] SnappyHexMesh edge not snaped correctly | yongxiang | OpenFOAM Meshing & Mesh Conversion | 2 | October 25, 2019 09:11 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
