[Salome] zero area patch created after extrudemesh |
August 17, 2023, 03:32 |
Song Young Ik
Rep Power: 4 |
I created quasi-2D single cell thickness mesh using salome, and used extrudemesh to create axisymmetric 5 degree mesh
My initial goal was to create it directly from salome, but since unv format can't handle such polyhedral cells inside it, I moved created med file to gmsh and converted again using gmshtofoam, however it couldn't convert it properly since such 'could not match gmsh face' error occured. Whatever, I exported quasi-2D mesh using unv and used ideaunvtofoam and extrudemesh, and I got wedge mesh But after that, I got some patch that is invisible from paraview, but still contains 1000 faces which was exact # of faces which was face containing rotating axis at quasi-2D mesh. How should I deal with this infinitesimal patch? Is it ok to just leave it alone? Or should I do something to remove it? |
extrudemesh, patch, wedge |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
