[blockMesh] FATAL ERROR: face 6 in patch 2 does not have neighbour cell face: 4(8 9 21 20)
Like Tree8Likes
Old   January 18, 2010, 14:59
Default FATAL ERROR: face 6 in patch 2 does not have neighbour cell face: 4(8 9 21 20)
Robin Gilbert
robingilbert is on a distinguished road
Hello I was trying to make an I-shaped room and i got the following error:
This is how my blockMeshDict looks like:
convertToMeters 1;
vertices
(0 0 0)
(3 0 0)
(3 1 0)
(2 1 0)
(2 2 0)
(3 2 0)
(3 3 0)
(0 3 0)
(0 2 0)
(1 2 0)
(1 1 0)
(0 1 0)
(0 0 1)
(3 0 1)
(3 1 1)
(2 1 1)
(2 2 1)
(3 2 1)
(3 3 1)
(0 3 1)
(0 2 1)
(1 2 1)
(1 1 1)
(0 1 1)
blocks
hex (0 1 2 11 12 13 14 23) (30 10 10) simpleGrading (1 1 1)
hex (10 3 4 9 22 15 16 21) (10 10 10) simpleGrading (1 1 1)
hex (8 5 6 7 20 17 18 19) (30 10 10) simpleGrading (1 1 1)
edges
patches
wall floor
(13 1 0 12)
wall ceiling
(18 6 7 19)
wall fixedWalls
(6 5 17 18)
(4 3 15 16)
(2 1 13 14)
(7 8 20 19)
(9 10 22 21)
(11 0 12 23)
(8 9 21 20)
(4 5 17 16)
(11 10 22 23)
(3 2 14 15)
mergePatchPairs
(9 4 16 21 8 5 17 20)
(10 3 15 22 11 2 14 23)
Please help me....I am new to OpenFOAM as well as C++
deoga likes this.
robingilbert is offline   Reply With Quote
Old   January 18, 2010, 17:41
Alan Russell
AlanR is on a distinguished road
Robin,
Without going through all of your vertices, blocks, etc., myself, you probably have things in the wrong order. It's very easy to get the order of vertices mixed up in a patch, which will give you fatal errors. First, I would start with one block at a time. I like to number the vertices so that the hex block numbers are consecutive - it's easier to keep track of that way. So you will have 24 vertices and your first block will be hex (0 1 2 3 4 5 6 7) (30 10 10) simpleGrading (1 1 1). Next, try just running blockMesh on one block at a time - blockMesh is very fast, so this will save you debugging time. Once you get all three blocks individually correct, you have problems with mergePatchPairs. Each patch that you want to merge must be individually named. You need something like wall fixedWall1 (6 5 17 18) wall fixedWall2 (4 3 115 16). Then, your mergePatchPairs will look like mergePatchPairs ( (fixedWall2 fixedWall1) (fixedWall3 fixedWall4) etc). Be careful with the order of mergePatchPairs - there is a note in the User Guide about which goes first.
So, break things down, order vertices so the blockMeshDict is easy to debug, and build up your geometry one step at a time. I'm still relatively new at this myself - spending a little time on learning blockMesh is worth the effort. It works quite well once you get used to it. Below is a simple geometry model multiple blocks and merged patch pairs as an example.
Good luck,
Alan
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0) //a
(2 0 0)
(2 1 0)
(0 1 0)
(0 0 1)
(2 0 1)
(2 1 1)
(0 1 1)
(0 1 0) //b
(2 1 0)
(2 2 0)
(0 2 0)
(0 1 1)
(2 1 1)
(2 2 1)
(0 2 1)
(2 1 0) //c
(3 1 0)
(3 2 0)
(2 2 0)
(2 1 1)
(3 1 1)
(3 2 1)
(2 2 1)
(3 1 0) //d
(5 1 0)
(5 2 0)
(3 2 0)
(3 1 1)
(5 1 1)
(5 2 1)
(3 2 1)
(3 0 0) //e
(5 0 0)
(5 1 0)
(3 1 0)
(3 0 1)
(5 0 1)
(5 1 1)
(3 1 1)
blocks
hex (0 1 2 3 4 5 6 7) (10 4 4) simpleGrading (1 1 1)
hex (8 9 10 11 12 13 14 15) (10 4 4) simpleGrading (1 1 1)
hex (16 17 18 19 20 21 22 23) (5 4 4) simpleGrading (1 1 1)
hex (24 25 26 27 28 29 30 31) (10 4 4) simpleGrading (1 1 1)
hex (32 33 34 35 36 37 38 39) (10 4 4) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 7 3)
(8 12 15 11)
patch outlet
(25 26 30 29)
(33 34 38 37)
wall upper
(11 15 14 10)
(19 23 22 18)
(27 31 30 26)
wall lower
(0 1 5 4)
(1 2 6 5)
(16 17 21 20)
(32 33 37 36)
(32 36 39 35)
wall front
(4 5 6 7)
(12 13 14 15)
(20 21 22 23)
(28 29 30 31)
(36 37 38 39)
wall back
(0 3 2 1)
(8 11 10 9)
(16 19 18 17)
(24 27 26 25)
(32 35 34 33)
patch i1
(3 7 6 2)
patch i2
(8 9 13 12)
patch i3
(9 10 14 13)
patch i4
(16 20 23 19)
patch i5
(17 18 22 21)
patch i6
(24 28 31 27)
patch i7
(24 25 29 28)
patch i8
(35 39 38 34)
mergePatchPairs
(i2 i1)
(i3 i4)
(i6 i5)
(i7 i8)
AlanR is offline   Reply With Quote
Old   January 18, 2010, 20:10
Robin Gilbert
Hi Alan,
Thanks... I got it running. the error was with the meshpatchpairs.... I dint know that i had to name it!!! thank you.
Old   April 14, 2016, 21:23
Default Error in blockMesh
Milad
mizzou is on a distinguished road
Guys,
I would be so grateful if anybody could help me. I just got this error when I execute the blockMesh:
--> FOAM FATAL ERROR:
face 1 in patch 0 does not have neighbour cell face: 4(12 15 19 16)
From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.
My blockMeshDict is as follows:
convertToMeters 1;
vertices
(0 0 -0.001) //0
(1 0 -0.001) //1
(1 0.005 -0.001) //2
(0 0.005 -0.001) //3
(0 0 0.001) //4
(1 0 0.001) //5
(1 0.005 0.001) //6
(0 0.005 0.001) //7
(0 0.01 -0.001) //8
(1 0.01 -0.001) //9
(1 0.01 0.001) //10
(0 0.01 0.001) //11
(0 0.015 -0.001) //12
(1 0.015 -0.001) //13
(1 0.015 0.001) //14
(0 0.015 0.001) //15
(0 0.02 -0.001) //16
(1 0.02 -0.001) //17
(1 0.02 0.001) //18
(0 0.02 0.001) //19
blocks
hex (0 1 2 3 4 5 6 7) (50 10 1) simpleGrading (1 1 1)
hex (3 2 9 8 7 6 10 11) (50 10 1) simpleGrading (1 1 1)
hex (8 9 13 12 11 10 14 15) (50 10 1) simpleGrading (1 1 1)
hex (12 13 17 16 15 14 19 18) (50 10 1) simpleGrading (1 1 1)
edges
boundary
inlet_water
type patch;
faces
(3 7 11 8)
(12 15 19 16)
inlet_air
type patch;
faces
(0 4 7 3)
(8 11 15 12)
outlet_water
type patch;
faces
(1 2 6 5)
(9 13 14 10)
outlet_air
type patch;
faces
(2 9 10 6)
(13 17 18 14)
lowerWall
type wall;
faces
(0 1 5 4)
topWall
type wall;
faces
(17 16 19 18)
outlet_air
type patch;
faces
(2 9 10 6)
(13 17 18 14)
lowerWall
type wall;
faces
(0 1 5 4)
topWall
type wall;
faces
(17 16 19 18)
mergePatchPairs
mizzou is offline   Reply With Quote
Old   April 15, 2016, 04:19
Antimony is on a distinguished road
From the definition of your last block, you have (12 13 17 16 15 14 19 18).
If you look up the way OF looks at a block, then you will see that there is no face that can be defined by (12 15 19 16)
There are two possible solutions:
1. Assuming your block definition is correct, then the face should be (12 15 18 16).
2. Assuming your face definition is correct, then the block should be (12 13 17 16 15 14 18 19)
Cheers,
Antimony
mizzou and sourav90 like this.
Antimony is offline   Reply With Quote
Old   April 15, 2016, 21:15
Milad
Originally Posted by Antimony View Post
Cheers,
Antimony
Thank you so much Antimony, it worked.
Old   June 20, 2016, 12:31
mohd nor hazwan bin hadzir
M.N Hazwan Hadzir is on a distinguished road
Trying to specify a boundary face 4(6 7 15 14) on the face on cell 6 which is either an internal face or already belongs to some other patch. This is face 0 of patch 17 named G_zone.
im not understand, what the meaning specific a boundary face??
my program is like this..
vertices
(0 0 -1) // 0
(43 0 -1) // 1
(86 0 -1) // 2
(129 0 -1) // 3
(172 0 -1) // 4
(215 0 -1) // 5
(258 0 -1) // 6
(301 0 -1) // 7
(0 1 -1) // 8
(43 1 -1) // 9
(86 1 -1) // 10
(129 1 -1) // 11
(172 1 -1) // 12
(215 1 -1) // 13
(258 1 -1) // 14
(301 1 -1) // 15
(0 0 1) // 16
(43 0 1) // 17
(86 0 1) // 18
(129 0 1) // 19
(172 0 1) // 20
(215 0 1) // 21
(258 0 1) // 22
(301 0 1) // 23
(0 1 1) // 24
(43 1 1) // 25
(86 1 1) // 26
(129 1 1) // 27
(172 1 1) // 28
(215 1 1) // 29
(258 1 1) // 30
(301 1 1) // 31
blocks
hex (0 1 9 8 16 17 25 24) (60 20 1) simpleGrading (1 1 1)
hex (1 2 10 9 17 18 26 25) (60 20 1) simpleGrading (1 1 1)
hex (2 3 11 10 18 19 27 26) (60 20 1) simpleGrading (1 1 1)
hex (3 4 12 11 19 20 28 27) (60 20 1) simpleGrading (1 1 1)
hex (4 5 13 12 20 21 29 28) (60 20 1) simpleGrading (1 1 1)
hex (5 6 14 13 21 22 30 29) (60 20 1) simpleGrading (1 1 1)
hex (6 7 15 14 22 23 31 30) (60 20 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 16 24 8)
outlet
type patch;
faces
(7 23 31 15)
lowerWall_A
type patch;
faces
(0 1 17 16)
upperWall_A
type patch;
faces
(8 9 25 24)
lowerWall_B
type patch;
faces
(1 2 18 17)
upperWall_B
type patch;
faces
(9 10 26 25)
lowerWall_C
type patch;
faces
(2 3 19 18)
upperWall_C
type patch;
faces
(10 11 27 26)
lowerWall_D
type patch;
faces
(3 4 20 19)
upperWall_D
type patch;
faces
(11 12 28 27)
lowerWall_E
type patch;
faces
(4 5 21 20)
upperWall_E
type patch;
faces
(12 13 29 28)
lowerWall_F
type patch;
faces
(5 6 22 21)
upperWall_F
type patch;
faces
(13 14 30 29)
lowerWall_G
type patch;
faces
(6 7 15 14)
upperWall_G
type patch;
faces
(30 31 15 14)
A_zone
type wall;
faces
(0 1 9 8)
(16 17 25 24)
G_zone
type wall;
faces
(6 7 15 14)
(6 7 15 14)
front
type empty;
faces
(1 2 10 9)
(2 3 11 10)
(3 4 12 11)
(4 5 13 12)
(5 6 14 13)
Back
type empty;
faces
(17 18 26 25)
(18 19 27 26)
(19 20 28 27)
(20 21 29 28)
(21 22 30 29)
mergePatchPairs
M.N Hazwan Hadzir is offline   Reply With Quote
Old   June 21, 2016, 03:17
Default --> FOAM FATAL ERROR: Trying to specify a boundary face..
Hallo, everyone,
my name is hazwan,
im is new in OpenFoam using,
I got some problem during make meshing,
Trying to specify a boundary face 4(6 7 15 14) on the face on cell 6 which is either an internal face or already belongs to some other patch. This is face 0 of patch 28 named G1.
below is my program,
im dont what is the meaning of " trying to specify a boundary face"
anybody can help me to solve this problem?
vertices
(0 0 -1) // 0
(43 0 -1) // 1
(86 0 -1) // 2
(129 0 -1) // 3
(172 0 -1) // 4
(215 0 -1) // 5
(258 0 -1) // 6
(301 0 -1) // 7
(0 1 -1) // 8
(43 1 -1) // 9
(86 1 -1) // 10
(129 1 -1) // 11
(172 1 -1) // 12
(215 1 -1) // 13
(258 1 -1) // 14
(301 1 -1) // 15
(0 0 1) // 16
(43 0 1) // 17
(86 0 1) // 18
(129 0 1) // 19
(172 0 1) // 20
(215 0 1) // 21
(258 0 1) // 22
(301 0 1) // 23
(0 1 1) // 24
(43 1 1) // 25
(86 1 1) // 26
(129 1 1) // 27
(172 1 1) // 28
(215 1 1) // 29
(258 1 1) // 30
(301 1 1) // 31
blocks
edges
boundary
inlet
type patch;
faces
(0 16 24 8)
outlet
type patch;
faces
(7 23 31 15)
lowerWall_A
type patch;
faces
(0 1 17 16)
upperWall_A
type patch;
faces
(8 9 25 24)
lowerWall_B
type patch;
faces
(1 2 18 17)
upperWall_B
type patch;
faces
(9 10 26 25)
lowerWall_C
type patch;
faces
(2 3 19 18)
upperWall_C
type patch;
faces
(10 11 27 26)
lowerWall_D
type patch;
faces
(3 4 20 19)
upperWall_D
type patch;
faces
(11 12 28 27)
lowerWall_E
type patch;
faces
(4 5 21 20)
upperWall_E
type patch;
faces
(12 13 29 28)
lowerWall_F
type patch;
faces
(5 6 22 21)
upperWall_F
type patch;
faces
(13 14 30 29)
lowerWall_G
type patch;
faces
(6 7 15 14)
upperWall_G
type patch;
faces
(30 31 15 14)
A1
type empty;
faces
(0 1 9 8)
A2
type empty;
faces
(16 17 25 24)
B1
type empty;
faces
(1 2 10 9)
B2
type empty;
faces
(17 18 26 25)
C1
type empty;
faces
(2 3 11 10)
C2
type empty;
faces
(18 19 27 26)
D1
type empty;
faces
(3 4 12 11)
D2
type empty;
faces
(19 20 28 27)
E1
type empty;
faces
(4 5 13 12)
E2
type empty;
faces
(20 21 29 28)
F1
type empty;
faces
(5 6 14 13)
F2
type empty;
faces
(21 22 30 29)
G1
type ;
faces
(6 7 15 14)
G2
type empty;
faces
(22 23 31 30)
mergePatchPairs
(F1 G1)
Old   June 21, 2016, 03:44
Your "lowerWall_G" and "G1" have the exact same face definition. A face can be specified as belonging only to one patch...
Cheers,
Antimony
Old   June 21, 2016, 04:29
Dear Antimon,
thank you very much.. it's work for the last problem..
Old   June 21, 2016, 05:45
Cheers,
Antimony
sir, i want to ask u one more question..
what the problem when after i run the blockMesh and proceed to paraFoam..
this error is come out?
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for lowerWall_A
file: /home/hazwanhadzir/Desktop/MY_master/mhdFoam_0/hartmann/0/p.boundaryField from line 25 to line 46.
Old   June 21, 2016, 05:58
It means that you have not specified that patch in the boundary file.
Essentially, every patch entry in the boundary file under constant/polyMesh, must be mentioned in each of your boundary condition files.
Cheers,
Antimony
M.N Hazwan Hadzir likes this.
Old   June 21, 2016, 06:17
Cheers,
Antimony
ok thank you..
i will try it again..
Old   June 25, 2016, 08:13
Madeleine
Madi is on a distinguished road
I have kind of the same problem. I try to build a channel with an indented wall (see picture). Now i try to define these new walls. but the following error occured:
face 15 in patch 2 does not have neighbour cell face: 4(28 2 10 26)
Can someone help me please. Thanks.
here is my blockMesh file:
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
backgroundMesh
x0 3.91; // Einlaufbereich
x1 9.91; //Bereich Rechen 1.5m vor Rechen
x2 12.91; //Bereich Rechen 1.5m nach Rechen (Verfeinerungsbereich) (Rechen genau in der Mitte bei 11.410)
x3 18.91; //Auslaufbereich
y0 -0.9025;
y1 0.7975;
y2 -0.9275;
y3 0.8225;
y4 -0.9525;
y5 0.8475;
y6 -0.900;
y7 -0.875;
y8 -0.925;
z0 0;
z1 0.85; //Wasserstandshöhe
z2 1.700;
convertToMeters 1;
vertices
($:backgroundMesh.x0 $:backgroundMesh.y0 $:backgroundMesh.z0) //0
($:backgroundMesh.x0 $:backgroundMesh.y1 $:backgroundMesh.z0) //1
($:backgroundMesh.x1 $:backgroundMesh.y0 $:backgroundMesh.z0) //2
($:backgroundMesh.x1 $:backgroundMesh.y1 $:backgroundMesh.z0) //3
($:backgroundMesh.x2 $:backgroundMesh.y0 $:backgroundMesh.z0) //4
($:backgroundMesh.x2 $:backgroundMesh.y1 $:backgroundMesh.z0) //5
($:backgroundMesh.x3 $:backgroundMesh.y0 $:backgroundMesh.z0) //6
($:backgroundMesh.x3 $:backgroundMesh.y1 $:backgroundMesh.z0) //7
($:backgroundMesh.x0 $:backgroundMesh.y2 $:backgroundMesh.z1) //8
($:backgroundMesh.x0 $:backgroundMesh.y3 $:backgroundMesh.z1) //9
($:backgroundMesh.x1 $:backgroundMesh.y2 $:backgroundMesh.z1) //10
($:backgroundMesh.x1 $:backgroundMesh.y3 $:backgroundMesh.z1) //11
($:backgroundMesh.x2 $:backgroundMesh.y2 $:backgroundMesh.z1) //12
($:backgroundMesh.x2 $:backgroundMesh.y3 $:backgroundMesh.z1) //13
($:backgroundMesh.x3 $:backgroundMesh.y2 $:backgroundMesh.z1) //14
($:backgroundMesh.x3 $:backgroundMesh.y3 $:backgroundMesh.z1) //15
($:backgroundMesh.x0 $:backgroundMesh.y4 $:backgroundMesh.z2) //16
($:backgroundMesh.x0 $:backgroundMesh.y5 $:backgroundMesh.z2) //17
($:backgroundMesh.x1 $:backgroundMesh.y4 $:backgroundMesh.z2) //18
($:backgroundMesh.x1 $:backgroundMesh.y5 $:backgroundMesh.z2) //19
($:backgroundMesh.x2 $:backgroundMesh.y4 $:backgroundMesh.z2) //20
($:backgroundMesh.x2 $:backgroundMesh.y5 $:backgroundMesh.z2) //21
($:backgroundMesh.x3 $:backgroundMesh.y4 $:backgroundMesh.z2) //22
($:backgroundMesh.x3 $:backgroundMesh.y5 $:backgroundMesh.z2) //23
($:backgroundMesh.x1 $:backgroundMesh.y8 $:backgroundMesh.z2) //24//Tor
($:backgroundMesh.x2 $:backgroundMesh.y8 $:backgroundMesh.z2) //25
($:backgroundMesh.x1 $:backgroundMesh.y6 $:backgroundMesh.z1) //26
($:backgroundMesh.x2 $:backgroundMesh.y6 $:backgroundMesh.z1) //27
($:backgroundMesh.x1 $:backgroundMesh.y7 $:backgroundMesh.z0) //28
($:backgroundMesh.x2 $:backgroundMesh.y7 $:backgroundMesh.z0) //29
blocks
hex (0 2 3 1 8 10 11 9) (10 10 10) simpleGrading (1 1 1) // Block1 Einlauf Wasser
hex (8 10 11 9 16 18 19 17) (10 10 10) simpleGrading (1 1 1) // Block Einlauf Luft
hex (28 29 5 3 26 27 13 11) (10 10 10) simpleGrading (1 1 1) //Rechen (11.410) Wasser
hex (26 27 13 11 24 25 21 19) (10 10 10) simpleGrading (1 1 1) // Rechen Luft
hex (4 6 7 5 12 14 15 13) (10 10 10) simpleGrading (1 1 1) // Auslauf Wasser
hex (12 14 15 13 20 22 23 21) (10 10 10) simpleGrading (1 1 1) // Auslauf Luft
edges
boundary
inlet
type patch;
faces
(0 8 9 1)
/*InletAir
type patch;
faces
(8 16 17 9)
outlet
type patch;
faces
(6 7 15 14)
/*OutletWater
type patch;
faces
(6 7 15 14)
walls
type wall;
faces
(0 2 10 8) // Rückwand
(8 10 18 16)
(28 29 27 26)//(2 4 12 10)
(26 27 25 24)//(10 12 20 18)
(4 6 14 12)
(12 14 22 20)//ab hier Boden
(0 1 3 2)
(28 3 5 29)//(2 3 5 4)
(4 5 7 6) // ab hier Vorderwand
(1 9 11 3)
(9 17 19 11)
(3 11 13 5)
(11 19 21 13)
(5 13 15 7)
(13 21 23 15)
(28 2 10 26)//indentedWall
(26 10 18 24)
(29 4 12 27)
(27 12 20 25)
/*(8 16 17 9)//inletA
(14 15 23 22) //outletA*/
atmosphere
type patch;
faces
(16 18 19 17)
(24 25 21 19)//(18 20 21 19)
(20 22 23 21)
(8 16 17 9)//inletA
mergePatchPairs
Madi is offline   Reply With Quote
Old   June 25, 2016, 22:07
Cheers,
Antimony
I try to make help from my friends,
He told me, my block mesh (Geometry) is OK, nothing error,
but when i'm try with my PC, during insert ParaFoam command
its error, as i told you before..
have u face with this problem before?
Old   June 27, 2016, 06:21
@Madi: You get the error because none of the blocks that you have defined have all of 28 2 10 and 26. If you want to create a face, then the first rule is that all the vertices specifying the face must be part of a the block to which the face belongs.
@Hadzir: What exactly is the error message you get?
Cheers,
Antimony
Old   July 5, 2016, 15:31
Post Error in blockMesh
  #17
Sudheer Reddy B
sudheer717 is on a distinguished road
Send a message via Skype™ to sudheer717
Hi guys,
I am very new to OpenFoam. I am trying to create a thermal plume rising from the floor of a heated room. I have gone through the hotroom tutorial and I need to modify the boundaries and mesh.
In the tutorial, the whole floor is at higher temperature than the rest of the domain. What I am trying to do is to heat only a certain portion of the floor (lets say a square tile located at the center of the floor). For that I have modified the meshdict and encountered the following error. Any help is appreciated.
Thank you
Error message:
face 0 in patch 0 does not have neighbor cell face: 8(4 8 9 10 14 13 15 5)
Meshfile:
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0 0 0) //0
(20 0 0) //1
(20 30 0) //2
(0 30 0) //3
(0 0 20) //4
(20 0 20) //5
(20 30 20) //6
(0 30 20) //7
(0 0 10) //8
(9.5 0 10) //9
(9.5 0 10.5) //10
(9.5 0 9.5) //11
(10.5 0 9.5) //12
(10.5 0 10) //13
(10.5 0 10.5) //14
(20 0 10) //15
blocks
hex (0 1 2 3 4 5 6 7) (100 100 100) simpleGrading (1 1 1)
edges
boundary
floor
type wall;
faces
(8 0 1 15 13 12 11 9)
tile
type patch;
faces
(10 9 11 12 13 14)
ceiling
type wall;
faces
(3 7 6 2)
fixedWalls
type wall;
faces
(0 8 4 7 3)
(2 6 5 15 1)
(0 3 2 1)
(4 5 6 7)
mergePatchPairs
sudheer717 is offline   Reply With Quote
Old   July 10, 2016, 22:11
Please refer to my reply to Madi. it is the same in your case.
If you want to specify a subset of your block to be something different, I suggest you use the combination of topoSet and createPatch.
Cheers,
Antimony
Old   July 15, 2016, 18:58
Default Mesh is not OK
  #19
Milad
Hello everyone,
What is the problem for this mesh? I can execute blockMesh but after executing checkMesh, I got "Failed 5 mesh checks." And when I see my geometry in paraview, it has a problem in some part. Any comment is highly appreciated.
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0 0 -0.001) //0
(0.5 0 -0.001) //1
(0.5 0.001 -0.001) //2
(0 0.001 -0.001) //3
(0 0 0.001) //4
(0.5 0 0.001) //5
(0.5 0.001 0.001) //6
(0 0.001 0.001) //7
(0 0.0035 -0.001) //8
(0.5 0.0035 -0.001) //9
(0.5 0.0055 -0.001) //10
(0 0.0055 -0.001) //11
(0 0.0035 0.001) //12
(0.5 0.0035 0.001) //13
(0.5 0.0055 0.001) //14
(0 0.0055 0.001) //15
(0 0.0075 -0.001) //16
(0.5 0.0075 -0.001) //17
(0.5 0.0011 -0.001) //18
(0 0.0011 -0.001) //19
(0 0.0075 0.001) //20
(0.5 0.0075 0.001) //21
(0.5 0.011 0.001) //22
(0 0.011 0.001) //23
(1 0.0075 -0.001) //24
(1 0.011 -0.001) //25
(1 0.0075 0.001) //26
(1 0.011 0.001) //27
(0.52 0 -0.001) //28
(0.54 0 -0.001) //29
(0.54 0.001 -0.001) //30
(0.52 0.001 -0.001) //31
(0.52 0 0.001) //32
(0.54 0 0.001) //33
(0.54 0.001 0.001) //34
(0.52 0.001 0.001) //35
(0.52 0.0035 -0.001) //36
(0.54 0.0035 -0.001) //37
(0.52 0.0035 0.001) //38
(0.54 0.0035 0.001) //39
(0.598 0 -0.001) //40
(0.6 0 -0.001) //41
(0.6 0.001 -0.001) //42
(0.598 0.001 -0.001) //43
(0.598 0 0.001) //44
(0.6 0 0.001) //45
(0.6 0.001 0.001) //46
(0.598 0.001 0.001) //47
(0.598 0.0035 -0.001) //48
(0.6 0.0035 -0.001) //49
(0.598 0.0035 0.001) //50
(0.6 0.0035 0.001) //51
(0.658 0 -0.001) //52
(0.66 0 -0.001) //53
(0.66 0.001 -0.001) //54
(0.658 0.001 -0.001) //55
(0.658 0 0.001) //56
(0.66 0 0.001) //57
(0.66 0.001 0.001) //58
(0.658 0.001 0.001) //59
(0.658 0.0035 -0.001) //60
(0.66 0.0035 -0.001) //61
(0.658 0.0035 0.001) //62
(0.66 0.0035 0.001) //63
(0.718 0 -0.001) //64
(0.72 0 -0.001) //65
(0.72 0.001 -0.001) //66
(0.718 0.001 -0.001) //67
(0.718 0 0.001) //68
(0.72 0 0.001) //69
(0.72 0.001 0.001) //70
(0.718 0.001 0.001) //71
(0.718 0.0035 -0.001) //72
(0.72 0.0035 -0.001) //73
(0.718 0.0035 0.001) //74
(0.72 0.0035 0.001) //75
(0.778 0 -0.001) //76
(0.78 0 -0.001) //77
(0.78 0.001 -0.001) //78
(0.778 0.001 -0.001) //79
(0.778 0 0.001) //80
(0.78 0 0.001) //81
(0.78 0.001 0.001) //82
(0.778 0.001 0.001) //83
(0.778 0.0035 -0.001) //84
(0.78 0.0035 -0.001) //85
(0.778 0.0035 0.001) //86
(0.78 0.0035 0.001) //87
(0.838 0 -0.001) //88
(0.84 0 -0.001) //89
(0.84 0.001 -0.001) //90
(0.838 0.001 -0.001) //91
(0.838 0 0.001) //92
(0.84 0 0.001) //93
(0.84 0.001 0.001) //94
(0.838 0.001 0.001) //95
(0.838 0.0035 -0.001) //96
(0.84 0.0035 -0.001) //97
(0.838 0.0035 0.001) //98
(0.84 0.0035 0.001) //99
(0.898 0 -0.001) //100
(0.9 0 -0.001) //101
(0.9 0.001 -0.001) //102
(0.898 0.001 -0.001) //103
(0.898 0 0.001) //104
(0.9 0 0.001) //105
(0.9 0.001 0.001) //106
(0.898 0.001 0.001) //107
(0.898 0.0035 -0.001) //108
(0.9 0.0035 -0.001) //109
(0.898 0.0035 0.001) //110
(0.9 0.0035 0.001) //111
(0.958 0 -0.001) //112
(0.96 0 -0.001) //113
(0.96 0.001 -0.001) //114
(0.958 0.001 -0.001) //115
(0.958 0 0.001) //116
(0.96 0 0.001) //117
(0.96 0.001 0.001) //118
(0.958 0.001 0.001) //119
(0.958 0.0035 -0.001) //120
(0.96 0.0035 -0.001) //121
(0.958 0.0035 0.001) //122
(0.96 0.0035 0.001) //123
(1 0 -0.001) //124
(1 0 0.001) //125
(1 0.001 -0.001) //126
(1 0.001 0.001) //127
(1 0.0035 -0.001) //128
(1 0.0035 0.001) //129
blocks
hex (0 1 2 3 4 5 6 7) (500 2 1) simpleGrading (1 1 1) //1
hex (3 2 9 8 7 6 13 12) (500 5 1) simpleGrading (1 1 1) //2
hex (8 9 10 11 12 13 14 15) (500 4 1) simpleGrading (1 1 1) //3
hex (11 10 17 16 15 14 21 20) (500 4 1) simpleGrading (1 1 1) //4
hex (16 17 18 19 20 21 22 23) (500 7 1) simpleGrading (1 1 1) //5
hex (17 24 25 18 21 26 27 22) (500 7 1) simpleGrading (1 1 1) //6
hex (1 28 31 2 5 32 35 6) (20 2 1) simpleGrading (1 1 1) //7
hex (2 31 36 9 6 35 38 13) (20 5 1) simpleGrading (1 1 1) //8
hex (28 29 30 31 32 33 34 35) (2 2 1) simpleGrading (1 1 1) //9
hex (29 40 43 30 33 44 47 34) (58 2 1) simpleGrading (1 1 1) //10
hex (30 43 48 37 34 47 50 39) (58 5 1) simpleGrading (1 1 1) //11
hex (40 41 42 43 44 45 46 47) (2 2 1) simpleGrading (1 1 1) //12
hex (41 52 55 42 45 56 59 46) (58 2 1) simpleGrading (1 1 1) //13
hex (42 55 60 49 46 59 62 51) (58 5 1) simpleGrading (1 1 1) //14
hex (52 53 54 55 56 57 58 59) (2 2 1) simpleGrading (1 1 1) //15
hex (53 64 67 54 57 68 71 58) (58 2 1) simpleGrading (1 1 1) //16
hex (54 67 72 61 58 71 74 63) (58 5 1) simpleGrading (1 1 1) //17
hex (64 65 66 67 68 69 70 71) (2 2 1) simpleGrading (1 1 1) //18
hex (65 76 79 66 69 80 83 70) (58 2 1) simpleGrading (1 1 1) //19
hex (66 79 84 73 70 83 86 75) (58 5 1) simpleGrading (1 1 1) //20
hex (76 77 78 79 80 81 82 83) (2 2 1) simpleGrading (1 1 1) //21
hex (77 88 91 78 81 92 95 82) (58 2 1) simpleGrading (1 1 1) //22
hex (78 91 96 85 82 95 98 87) (58 5 1) simpleGrading (1 1 1) //23
hex (88 89 90 91 92 93 94 95) (2 2 1) simpleGrading (1 1 1) //24
hex (89 100 103 90 93 104 107 94) (58 2 1) simpleGrading (1 1 1) //25
hex (90 103 108 97 94 107 110 99) (58 5 1) simpleGrading (1 1 1) //26
hex (100 101 102 103 104 105 106 107) (2 2 1) simpleGrading (1 1 1) //27
hex (101 112 115 102 105 116 119 106) (58 2 1) simpleGrading (1 1 1) //28
hex (102 115 120 109 106 119 122 111) (58 5 1) simpleGrading (1 1 1) //29
hex (112 113 114 115 116 117 118 119) (2 2 1) simpleGrading (1 1 1) //30
hex (113 124 126 114 117 125 127 118) (40 2 1) simpleGrading (1 1 1) //31
hex (114 126 128 121 118 127 129 123) (40 5 1) simpleGrading (1 1 1) //32
edges
boundary
inlet_water
type patch;
faces
(0 4 7 3)
(3 7 12 8)
(8 12 15 11)
inlet_air
type patch;
faces
(11 15 20 16)
(16 20 23 19)
outlet_air
type patch;
faces
(24 25 27 26)
outlet_water
type patch;
faces
(124 126 127 125)
(126 128 129 127)
front_mesh
type wall;
faces
(9 10 14 13)
(10 17 21 14)
bottomMesh_h
type wall;
faces
(9 36 38 13)
(31 30 34 35)
(37 48 50 39)
(43 42 46 47)
(49 60 62 51)
(55 54 58 59)
(61 72 74 63)
(67 66 70 71)
(73 84 86 75)
(79 78 82 83)
(109 120 122 111)
(115 114 118 119)
(121 128 129 123)
bottomMesh_v_front
type wall;
faces
(31 36 38 35)
(43 48 50 47)
(55 60 62 59)
(67 72 74 71)
(79 84 86 83)
(91 96 98 95)
(103 108 110 107)
(115 120 122 119)
bottomMesh_v_back
type wall;
faces
(30 37 39 34)
(42 49 51 46)
(54 61 63 58)
(66 73 75 70)
(78 85 87 82)
(90 97 99 94)
(102 109 111 106)
(114 121 123 118)
top_mesh
type wall;
faces
(17 24 26 21)
lowerWall
type wall;
faces
(0 1 5 4)
(41 52 56 45)
(76 77 81 80)
(1 28 32 5)
(52 53 57 56)
(77 88 92 81)
(28 29 33 32)
(53 64 68 57)
(88 89 93 92)
(29 40 44 33)
(64 65 69 68)
(89 100 104 93)
(40 41 45 44)
(65 76 80 69)
(101 112 116 105)
(100 101 105 104)
(112 113 117 116)
(113 124 125 117)
topWall
type wall;
faces
(18 19 23 22)
(25 18 22 27)
mergePatchPairs
File Type: png Screenshot from 2016-07-15 17:56:10.png (639 Bytes, 14 views)
Old   February 16, 2017, 18:43
Default Another blockMesh neighbor cell face error
  #20
Randal Samstag
rsamstag is on a distinguished road
Here is another neighbor cell face error.
Anybody see the problem?
Thanks so much.
Randal
face 0 in patch 2 does not have neighbour cell face: 4(0 6 13 12)
| \\ / O peration | Version: 4.1 |
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0 0 -0.1) //0
(8.65 0 -0.1)//1
(8.65 0.9 -0.1)//3
(0 0.9 -0.1)//4
(8.65 1 -0.1)//5
(0 1 -0.1)//6
(0 0 0.1)//7
(8.65 0 0.1)//8
(8.65 0.9 0.1)//9
(0 0.9 0.1)//10
(8.65 1 0.1)//11
(0 1 0.1)//12
(0.1 0 -0.1)//13
(0.1 0 0.1)//14
blocks
hex (0 1 2 3 6 7 8 9) (200 36 1) simpleGrading (1 1 1)
hex (3 2 4 5 9 8 10 11) (200 4 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch; //0
faces
(3 9 11 5)
outlet
type patch; //1
faces
(2 4 10 8)
bottomOutlet
type patch; //2
faces
(0 6 13 12)
bottomWall
type wall; //3
faces
(12 13 7 1)
endWall
type wall;
faces
(1 2 8 7)
top
type patch;
faces
(5 11 10 4)
frontAndBack
type empty;
faces
(0 3 2 1)
(6 7 8 9)
(3 5 4 2)
(9 8 10 11)
mergePatchPairs
rsamstag is offline   Reply With Quote
fatal error
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[swak4Foam] get the value of a field in the neighbour cell of a patch face miles_davis OpenFOAM Community Contributions 7 October 5, 2011 11:57
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
