[snappyHexMesh] How to use Openfoam 10 snappyHexMesh to foam-extend-5.0? |
November 21, 2023, 13:14 |
Rep Power: 3 |
Hello everyone,
I am newbie with SHM and OF. I create a mesh by SHM on OF10 but I don't know how to use it with foam-extend-5.0. I tried to convert by foamMeshToFluent and fluentMeshToFoam. But I have some polyhedral meshes. VTK also didn't help due to patch names are deleting. (deleted maybe only with my methods). I was using Ansys meshing and ICEM to run on foam-extend but now I need SHM. My common error is fe50 doesn't care firstLayerThickness and says cannot find finalLayerThickness. How can I solve these problems. It was creating good BL meshes with firstLayerThickness by OF10. Thank you. Best regards. |
November 26, 2023, 08:57 |
Saeed Jamshidi
Rep Power: 7 |
Hi mechanicalhead,
What is your problem exactly? Importing a mesh file (created by ansys or cfMesh) to openfoam? or generation of first prism layer in sHM? |
November 28, 2023, 01:49 |
#3 | |
Rep Power: 3 |
Hi saeed jamshidi, I was trying to use mesh created by SHM with foam-extend. I found solution with not using foam-extend solver. |
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 09:49 |
Difference between OpenFOAM and FOAM extend | ce73stargazer | OpenFOAM | 9 | November 10, 2019 10:00 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
[Other] cgnsToFoam problems with "QUAD_4" cells | lentschi | OpenFOAM Meshing & Mesh Conversion | 1 | March 9, 2011 04:49 |
