December 7, 2023, 13:42 |
Holes in Mesh after conversion
Anurag
Rep Power: 3 |
Hi all, I have converted a 3D Mesh from Fluent to OpenFOAM that has got tetrahedral cells. But after conversion I can see some holes in the 3D as well as 2D mesh inside paraview. But this problem is not with hexa cels. Can anyone please suggest what is the problem? Is OpenFOAM not suitable for tetra cells? I attached the picture.
Many Thanks. |
December 8, 2023, 04:26 |
Rep Power: 5 |
Hey!
I suspect it is only an issue with the visualization in Paraview. I have encountered this issue sometimes when using fluent meshes, but I could always run the cases. What does checkMesh say? I think you should be fine if the import was successful. |
December 8, 2023, 14:07 |
Anurag
Rep Power: 3 |
Hi, Okay, checkMesh is fine. But then how can I submit these results with these holes? Is there a way to correct it? with hexahedral cells this issue is not coming.
thanks. |
December 8, 2023, 14:52 |
Anurag
Rep Power: 3 |
thanks. |
December 11, 2023, 03:45 |
Rep Power: 5 |
Have you tried turning on the "Crinkle slice" option, to avoir splitting cells? It might be better looking. Did you open a reconstructed or decomposed step? Decomposed steps can sometimes lead to visualization issues in my experience.
December 11, 2023, 13:52 |
Anurag
Rep Power: 3 |
Hi Brother, I opened a reconstructed case. No I havent tried the crinkle slice option. But what I am seeing is when I am giving tetra cells this issue is coming, but when I am giving hexa cells this issue is not there. Thanks. Do you have any suggestions?
December 11, 2023, 16:51 |
Anurag
Rep Power: 3 |
Now I have tried the crinkled slice option but I want to look at a flat slice to submit these results in my project.
December 12, 2023, 04:47 |
Rep Power: 5 |
Hey!
I noticed you are using Paraview 5.3. Maybe you could try to upgrade to the latest version (5.11 I believe). It could help with the issue. No other idea right now sorry! |
December 12, 2023, 08:42 |
Anurag
Rep Power: 3 |
Thanks, no problem
December 12, 2023, 16:30 |
Anurag
Rep Power: 3 |
Hi , I am using the terminal of my HPC and there I could only open paraview/5.3. I tried opening latest version of paraview but it is showing a graphics error
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found. This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem. Available platform plugins are: xcb. I am doing this to visualise the results directly on the HPC. Any suggestions what to do? Thanks |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 15:16 |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
[snappyHexMesh] Mesh contains holes on interface of multiregion case | DriesAllaerts | OpenFOAM Meshing & Mesh Conversion | 6 | December 17, 2019 04:43 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
