[snappyHexMesh] cell does not seem to have 8 points |
February 22, 2024, 04:11 |
Gianluca
i'm trying to mesh a valve with snappy but everytime the result is this:
--> FOAM FATAL ERROR: cell 236 of level 1 does not seem to have 8 points of equal or lower level cellPoints: 11 ( 21898 32807 32808 6957 6958 6960 6961 10162 10163 6964 36423 ) pointLevels: 11 ( 2 2 2 0 1 1 1 1 1 1 2 ) From function Foam::labelListList Foam::hexRef8::setRefinement(const labelList&, Foam::polyTopoChange&) in file polyTopoChange/polyTopoChange/hexRef8/hexRef8.C at line 3678. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::hexRef8::setRefinement(Foam::List<int> const&, Foam::polyTopoChange&) at ??:? #3 Foam::meshRefinement::refine(Foam::List<int> const&) at ??:? #4 Foam::meshRefinement::refineAndBalance(Foam::string const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&, Foam::List<int> const&, double) at ??:? #5 Foam::snappyRefineDriver::shellRefine(Foam::refinementParameters const&, int) at ??:? #6 Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, Foam::dictionary const&) at ??:? #7 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/snappyHexMesh" #8 ? in "/lib/x86_64-linux-gnu/libc.so.6" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/snappyHexMesh" Aborted (core dumped) This are my code i've tryed to change every single parameter but nothing changes the result. if someone can help me i would be very pleased because i'm going crazy These are snappydict and qualitydict Meshing.zip |
March 25, 2024, 01:07 |
BlockMeshDict might be wrong
#2 | |
Amirreza
Rep Power: 6 |
Dear Gianluca I think the problem is with your background mesh or the stl file, attach the stl and blockMeshdict. there might be some disorder in blocks arrangement. |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 09:26 |
[snappyHexMesh] layer not added | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 1 | January 2, 2020 10:43 |
Fluent UDF wrong number of cells in parallel - correct in serial | dralexpe | Fluent UDF and Scheme Programming | 7 | May 17, 2018 09:26 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 12:27 |
How to get cell labels for all the points within specific distance from a given point | gxy200992243 | OpenFOAM Programming & Development | 7 | October 11, 2014 16:17 |
