[Other] Floating point exception error in foam-extend 5.0
Old   April 17, 2024, 22:40
Default Floating point exception error in foam-extend 5.0
Na.Li
Na.Li is on a distinguished road
I am learning to use the immersed boundary method in foam-extend 5.0 to simulating identify the grids around a wind turbine. The error occured when I used writeIbMasks to identify the grids around the wind turbine. I found if I used model rotor.ftr, the command of writeIbMasks runs normally. When I used the model tower.ftr, there was also no error. Then I assembled these two parts by the SolidWorks and exported Windturbine.stl and Windturbine.ftr. Something wrong happens when I use Windturbine.ftr for writeIbMasks in foam-extend 5.0. A Floating point exception is displayed. I have looked at the source code writeIbMasks.C, but I still have no idea. Finally i got the IbMasks by unsetting FOAM_SIGFPE,but i don't know if this approach will have any other impacts. Thanks, any help would be much appreciated, as I am pulling my hair out here, trying to figure this out.
Thanks
Na.Li
Na.Li is offline   Reply With Quote
writeibmasks
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Floating point exception (PLEASE HELP :) ) mn14cat OpenFOAM CC Toolkits for Fluid-Structure Interaction 9 December 8, 2021 11:24
ERORR floating point exception fluent udf cudau.95 Fluent UDF and Scheme Programming 0 August 4, 2021 22:11
simpleFoam: floating point exception student666 OpenFOAM Running, Solving & CFD 9 March 13, 2016 18:23
Temperature floating point exception ayckrom FLUENT 1 May 13, 2015 09:02
