April 23, 2024, 12:27 |
mesh conversion
sai
hi,
I did mesh by Salome and want to convert it to the openfoam mesh to use I exported mesh as .mesh file and use the command of fluentmeshtofoam.... however the boundary condition is not implemented there... i did make the group faces and named the boundaries |
May 23, 2024, 09:13 |
#2 | |
Rep Power: 2 |
To convert a Salome mesh to openfoam, you have to export it as a .unv format. Then you use Quote:
The command you used is for Ansys Fluent meshes being converted to Openfoam and it is for files of the .msh extension. |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
[Commercial meshers] Thin Walls Conversion from Fluent Mesh | Isaac | OpenFOAM Meshing & Mesh Conversion | 1 | March 4, 2016 12:08 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
