[Gmsh] Boundary Conditions
Old   September 23, 2008, 06:02
Default Boundary Conditions
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
I have created a 3D geometry with gmsh and got a nice mesh.
Now, gmshToFoam worked fine and I have the complete set of polyMesh files.
How can I specify boundary and initial conditions for my desired fields at this point?
This problem must be related to OpenFOAM since gmsh is not able to set conditions like this.
(The developers call gmsh "solver-agnostic")
Thanks a lot.
sega
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   September 23, 2008, 09:32
Default Hi Sebastian, according to
Andrea M.A. Barbera
andrea_barbera is on a distinguished road
Hi Sebastian,
according to my experience, in the GMSH model you should create some physical surfaces (that will become your OF patches) and one physical volume (the domain). You should run gmsh with this settings without the "save all" option. If you use this options patches will not be saved.
At this point you should convert the mesh using "gmsh2toFoam", that you should find in the OF Wiki. This utility preserves patches names but must be compiled. From what I know this utility has some problems with OF 1.5 version: I use my old 1.4.1 version to convert meshes.
Regards
Andrea
andrea_barbera is offline   Reply With Quote
Old   September 23, 2008, 11:40
Default Ok, now I see how this is goin
sega's Avatar
Sebastian Gatzka
Ok, now I see how this is going to work.
I tried to set up a simple cavity case with a gmsh mesh. Everything is working into I want to start the calculation.
(Well, actually the orientation of the faces got messed up on the way, but thats not the problem).
When starting the interFoam solver there is this familiar error:
--> FOAM FATAL ERROR : This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
As the debugging was easy with blockMesh and structured hex-meshes, I don't know what to do on this unstructured mesh.
I hope you have some ideas for me?
Maybe a look at my case helps:
http://therealsega.th.funpic.de/open...mshMesh.tar.gz
Thanks so far.
Old   November 17, 2008, 15:59
Default Hi Sebastian, you probably
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Hi Sebastian,
you probably figured that out by now but if your mesh is 3D you cannot specify any of the boundaries as type "empty".
cheers,
-Louis
louisgag is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
