[Technical] Merge patch
Old   July 21, 2008, 20:40
Default Merge patch
Ery Djunaedy
erydj is on a distinguished road
I am trying out OpenFoam and here is a newbie questions about merging patch.
I am using hotRoom example (in buoyantSimpleFoam) and what I did was just creating a second block (exactly the same size and same gridding) and put it on top of the first one (in y-direction).
I also moved the "ceiling" wall to the top of the second block. I want to merge the patch between these blocks.
The manual says that if the grid on the two patches are exactly the same than the patch will be deleted. But apparently a default patch was created on the boundary of the two patches.
And when I run buoyantSimpleFoam, there is an error saying:
"This mesh contains patche op type empty but is not 1D or 2D by virtue of the fact that the number of faces of this empty patch is not divisible by the number of cells."
Can anybody tell me how to solve this?
I also tried a different gridding on the patches and use mergePatchPairs in the blockMeshDict. But when I run blockMesh, it says:
mergePatchPairs not currently supported.
From function blockMesh
in file genBlockMesh.C at line 198.
FOAM exiting
Any idea what is wrong?
Thanks!
erydj is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 04:48
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
