November 3, 2008, 07:49 |
Point inside Cell
Robert Manning
Is there a quick way to determine the volume of a cell that is cut by a surface? Also, is there a way to determine if an arbitrary point is in inside a cell?
November 3, 2008, 08:11 |
Hi Robert
Please try
mes
Rep Power: 18 |
Hi Robert
Please try mesh.findCell(location); where location is a point defined as: point location(x y z); Once you have the label of the cell where point is located you can get its volume as well. Hope that helps Regards Jaswi |
November 4, 2008, 14:37 |
Thanks Jaswi for your help. H
Robert Manning
Thanks Jaswi for your help. How do I make a pointField structure from several individual vectors?
November 4, 2008, 15:02 |
Hi Robert
Sorry I did not g
Rep Power: 18 |
Hi Robert
Sorry I did not get that question :-). Well as far as I know pointField is a field of points and field itself is a List of a <type>. So if you have certain number of individual vectors then you can create a pointField of certain size as you would do for an array and then assign your vectors as the elements of array . The code might look something like this: pointField myField(size,vector::zero); myField[0] = vector1(x,y,z); myField[1] = vector2(x,y,z); and so on..... Please let me know if this doesn't works ... Hope that helps Regards Jaswi |
November 6, 2008, 10:36 |
Thanks Jaswinder. It works we
Robert Manning
Thanks Jaswinder. It works well. I'm currently trying to debug a code that I wrote which initializes gamma based on an STL file. It is slightly different than "surfaceToCell" because it will set gamma to a fraction of the cell that is cut by the surface. It places hundreds of points within each cell that is cut by the surface. It then calculates the fraction that is interior using surfaceToPoint. However it seems that surfaceToPoint returns some false-negatives if the point is in the cell. Anyone willing to give me a hand? I can post or email you the code and STL file.
Thanks, Bob |
November 7, 2008, 10:20 |
Hi Robert
I can give it a
Rep Power: 18 |
Hi Robert
I can give it a try Regards Jaswi |
November 8, 2008, 19:24 |
Thanks Jaswi. Is there anyway
Robert Manning
Thanks Jaswi. Is there anyway to post a compressed file? If not, email me at "BobatPurdue" at "yahoo.com".
Thanks, Bob |
November 11, 2008, 20:32 |
I attached a short code that s
Robert Manning
I attached a short code that sees if points are within a STL surface. It reads gamma.stl. However, there appears to be a bug. It reports that points are both interior and exterior to the surface when they are both inside the surface. Possible bug / limitation of the code / programmer error ? I can attach the gamma.stl if needed.
Thanks, Bob ---- CODE ----- #include "argList.H" #include "Time.H" #include "fvMesh.H" #include "topoSetSource.H" #include "cellSet.H" #include "volFields.H" #include "triSurface.H" #include "Random.H" #include "triSurfaceSearch.H" using namespace Foam; int main(int argc, char *argv[]) { //Random Random rndGen(label(0)); // Temp variables scalar currentx; scalar currenty; scalar currentz; scalar randnum; // Point list pointField cellPoints(10,vector::zero); // Random point in cell vector currentpoint = vector::zero; forAll(cellPoints,pointsi) { randnum = rndGen.scalar01(); currentx = (randnum-0.5)*0.57735*2; randnum = rndGen.scalar01(); currenty = (randnum-0.5)*0.57735*2; randnum = rndGen.scalar01(); currentz = (randnum-0.5)*0.57735*2; currentpoint = Vector<scalar>(currentx,currenty,currentz); cellPoints[pointsi] = currentpoint; } // Select Surface triSurface surf("gamma.stl"); triSurfaceSearch querySurf(surf); // determine if points inside surface boolList pointInside(querySurf.calcInside(cellPoints)); forAll(pointInside, pointI) { bool isInside = pointInside[pointI]; cout << cellPoints[pointI].x() << " " << cellPoints[pointI].y() << " " << cellPoints[pointI].z(); if (isInside) cout << " Inside\n"; else cout << " Outside\n"; } return 0; } |
April 25, 2019, 11:15 |
Rep Power: 10 |
Did this ever get resolved?
I am in need of the same utility but don't want to re-invent the wheel if this has already been done. |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Fluent UDF wrong number of cells in parallel - correct in serial | dralexpe | Fluent UDF and Scheme Programming | 7 | May 17, 2018 08:26 |
Simulating fire in a tunnel | luca1992 | OpenFOAM | 14 | August 16, 2017 13:50 |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 14:38 |
