May 19, 2008, 09:36 |
CuBit
Denk Marcus
Hi Forum,
Just a few weeks ago i asked if somebody has experiences with CuBit as a preprocessor in combination with OpenFoam. I only got one answer. I was told that there should be no problem importing CuBit-meshes into OpenFoam. Is there somebody else who has experiences with CuBit and importing itīs meshes into OpenFoam. I would be very pleased get some information about this. Thanks a lot |
June 29, 2008, 06:01 |
I also use CUBE and Ope
Tian
I also use CUBE and OpenFOAM. I export the mesh in Fluent format and importing the mesh in OpenFOAM, no problem... Bye Tian
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance. |
June 29, 2008, 06:37 |
Hi Thomas!
I saw that the f
Stefan Radl
Rep Power: 18 |
Hi Thomas!
I saw that the fluent export function is new in Cubit 11.0. However, I have no tested it - currently I export in ideasUNV format, which allows me to only define "groups" of faces but not to specify the patch type, i.e., if this is a wall or a inlet, etc. Is it also possible to export boundary conditions, e.g. wall, etc. br Stefan |
July 8, 2008, 08:36 |
Hi Stefan,
I tried also to
Tian
Hi Stefan,
I tried also to export in ideasUNV Format with group of faces to OpenFOAM with CUBIT 11. It was not working :-( Do you have a nice excample for CUBIT? Thanks Thomas
July 8, 2008, 08:50 |
I had to modify the import pro
Stefan Radl
Rep Power: 18 |
July 8, 2008, 15:44 |
Hi Stefan,
thanks for the f
Tian
Hi Stefan,
thanks for the files. I can not import the UNV File. I group the face and export it but I can not import to OF. Can you also send me the Cubit File al excample? Sorry for my english, my german is better ;-) Bye Thomas
July 10, 2008, 07:51 |
here is an example for
Tian
here is an example for generation a mesh in Cubit and export it in msh format for OpenFOAM: brick x 4 y 4 z 1 create cylinder height 1 radius 0.5 subtract volume 2 from volume 1 create cylinder height 1 radius 1 chop volume 1 with volume 3 webcut volume all with plane yplane noimprint nomerge webcut volume all with plane xplane noimprint nomerge delete volume 4 5 8 9 webcut volume 10 with plane xplane rotate 45 about z center 0 0 0 noimprint nomerge webcut volume 6 with plane xplane rotate -45 about z center 0 0 0 noimprint nomerge sweep curve 149 164 along curve 70 sweep curve 164 along curve 129 sweep curve 149 along curve 137 webcut volume 7 with sheet surface 109 webcut volume 18 with sheet surface 108 webcut volume 11 with sheet surface 107 webcut volume 11 with sheet surface 110 delete surface all imprint volume all merge volume all curve 39 41 156 158 65 189 141 139 110 108 61 231 35 37 124 204 12 216 11 interval default curve 39 41 156 158 65 189 141 139 110 108 61 231 35 37 124 204 12 216 11 interval 1 preview curve 39 41 156 158 65 189 141 139 110 108 61 231 35 37 124 204 12 216 11 interval 1 curve 39 41 156 158 65 189 141 139 110 108 61 231 35 37 124 204 12 216 11 scheme equal mesh curve 39 41 156 158 65 189 141 139 110 108 61 231 35 37 124 204 12 216 11 volume 6 10 12 13 interval 10 mesh volume 6 10 12 13 volume 7 19 interval 20 mesh volume 7 19 delete mesh volume 7 19 propagate volume 7 19 interval 20 mesh volume 7 19 volume 20 18 21 11 interval 20 mesh volume 20 18 21 11 sideset 1 surface 94 90 106 99 sideset 1 name cylinder sideset 2 surface 40 27 28 41 sideset 2 name down sideset 3 surface 130 135 122 128 sideset 3 name up sideset 4 surface 146 140 sideset 4 name left sideset 5 surface 118 115 sideset 5 name right export fluent cylinder.msh volume all overwrite In Openfoam import the file with: fluentMeshToFoam root case cylinder.msh Have fun Thomas
Cubit going open source? | phsieh2005 | Mesh Generation & Pre-Processing | 17 | March 30, 2017 08:01 |
Cubit old version or similar software | File | Mesh Generation & Pre-Processing | 2 | March 12, 2013 05:05 |
CUBIT Tool Suite Download | asoltoon | Mesh Generation & Pre-Processing | 2 | February 6, 2013 23:33 |
[Other] Cubit --> Openfoam problems | fijinx | OpenFOAM Meshing & Mesh Conversion | 0 | April 13, 2010 17:31 |
CuBit | t42 | OpenFOAM Pre-Processing | 0 | May 16, 2008 05:06 |
