[Netgen] Create boundary
Old   October 26, 2008, 08:54
Default Create boundary
fabrizio
fabrizio is on a distinguished road
Hi everybody I have created a polymesh from Netgen and all went fine. Now I have to fix boundaries, and I have this boundary file:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
root "/home/fabrizio/OpenFOAM/fabrizio-1.4.1/run";
case "prova";
instance "constant";
local "polyMesh";
class polyBoundaryMesh;
object boundary;
12
patch1
type patch;
physicalType patch;
nFaces 14;
startFace 294;
patch2
type patch;
physicalType patch;
nFaces 18;
startFace 308;
patch3
type patch;
physicalType patch;
nFaces 16;
startFace 326;
patch4
type patch;
physicalType patch;
nFaces 14;
startFace 342;
patch5
type patch;
physicalType patch;
nFaces 14;
startFace 356;
patch6
type patch;
physicalType patch;
nFaces 14;
startFace 370;
patch7
type patch;
physicalType patch;
nFaces 6;
startFace 384;
patch8
type patch;
physicalType patch;
nFaces 6;
startFace 390;
patch9
type patch;
physicalType patch;
nFaces 6;
startFace 396;
patch10
type patch;
physicalType patch;
nFaces 8;
startFace 402;
patch11
type patch;
physicalType patch;
nFaces 6;
startFace 410;
patch12
type patch;
physicalType patch;
nFaces 6;
startFace 416;
I want patch1 to be inlet, patch 2 to be outlet and all the other patches to be walls. I haven't found nothing about in the forum, so I hope someone can help me.
Thanks to all
Fabrizio
fabrizio is offline   Reply With Quote
Old   October 26, 2008, 14:12
Default Hello Fabrizio, A Good even
Philippose Rajan
philippose will become famous soon enough
Hello Fabrizio,
A Good evening to you....!
Well... a short answer to your question would be... there is no automatic method to tell netgenNeutral2Foam which patches have what names.
During the import, the converter automatically recognises the boundary definitions available, and gives them default names "patch<n>"....
You will have to manually change these to the names you want.
If you have many such cases with the same boundary patch names, I would suggest that you quickly cook up a bash script which uses something like "sed" to automatically rename the patches based on a "configuration file" which you provide.
In addition, note that you would also have to change the "type" of the patch to the relevant ones (as you mentioned, wall, etc...)
As for defining a patch to be an inlet or an outlet.... this is not specified in the "boundary" file. Such definitions are made in the "p", and "U" files in the "0" time-step folder of the case.
Hope this helps!
Have a nice day!
Philippose
philippose is offline   Reply With Quote
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Fluid Domain moving with Rigid body Lloyd Sullivan CFX 3 August 17, 2018 09:58
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 01:54
