[mesh manipulation] Adaptive Meshes
Old   November 24, 2005, 05:14
Default Adaptive Meshes
Siddhartha Jain
sidgalt is on a distinguished road
I need to perform a numerical simulation on the heat transfer during compression for a sliding vane compressor. Since the shape of chamber containing the air will change with time, how do I create a mesh which changes in time?
Thank you
sidgalt is offline   Reply With Quote
Old   November 24, 2005, 06:51
Default I was reading the thread by Hr
Siddhartha Jain
I was reading the thread by Hrvjoe Jasak at
http://www.cfd-online.com/OpenFOAM_D...ges/1/224.html.
Is there any tutorial available for layer addition/removal?
Old   November 24, 2005, 13:39
Default Do you need to add layers or c
Mattijs Janssens
mattijs is on a distinguished road
Do you need to add layers or can you just move the mesh (mesh.movePoints) ? There is various info on this forum about it. See also icoFoamAutoMotion tutorial.
mattijs is offline   Reply With Quote
Old   November 24, 2005, 15:02
Default Thank you for the reply. Si
Siddhartha Jain
Since the vanes of the compressor will have a motion in the radial and tangential direction, and I plan to use a graded mesh, I think layer addition/removal will be necessary.
Since the geometry will be changing as well as moving due to the rotary motion of the vanes, the mesh will need to change geometry as well as move.
I will check out icoFoamAutoMotion.
Old   June 18, 2008, 16:34
Default How to adapt a mesh by some fi
kalaiselvan
21kalee is on a distinguished road
How to adapt a mesh by some field(may be Pressure or temperature for example) gradient?
Is there any tool for doing this.........
If so , please help me with it...... Also indicate the tutorial in which the adaptive mesh by gradient is used.
I have tried the sonicFoamAutoMotion, but there is no tutorial attached to it... I started to create a test file for it, but had an error in giving the dynamicMeshDict file..... or in other words, how to edit or convey to the solver that i have to use mesh adaptation by gradient of the field i like..
21kalee is offline   Reply With Quote
Old   June 24, 2008, 01:49
Default Help me too with the adaptive
ash
Arun Shourie
ash is on a distinguished road
Help me too with the adaptive mesh by gradient of a field. Or a direction will also do, i couldn't find the tutorial for sonicAutoMotionFoam... help me to find it
ash is offline   Reply With Quote
Mapping (interpolation) between two meshes Ebrahim OpenFOAM Programming & Development 2 June 15, 2020 13:31
Adaptive refinement of triangular meshes Jonas Holdeman Main CFD Forum 1 March 17, 2016 10:50
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 01:18
[Technical] Local adaptive mesh refinement with hybrid meshes holger_marschall OpenFOAM Meshing & Mesh Conversion 5 December 21, 2010 13:38
unstructured grid sreekanth Main CFD Forum 1 August 6, 2001 15:09
