[Salome] Definition of cellZones
Old   September 13, 2007, 04:26
Default Definition of cellZones
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
I'd like to import a mesh from ideasUnV-File format. The file contains information on a cellZone beside info on the boundary condition. I've modified the ideasUnvToFoam utility so that I can extract this information (i.e. a list of cells that belong to a zone) out of the .unv file.
The problem is how to add this info to my mesh.
How can I write this cellZone info in OF format?
Any hint where to start is welcome
br
Stefan
sradl is offline   Reply With Quote
Old   September 13, 2007, 05:32
Default Stefan, Here's some code th
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Stefan,
Here's some code that should help give you some hints. The addCellZones() method can be readily adapted to your needs.
/mark
2 Files:
cellTable.H
cellTable.C
olesen is offline   Reply With Quote
Old   September 13, 2007, 10:27
Default Dear Mark, got it: I just l
sradl's Avatar
Stefan Radl
Dear Mark,
got it: I just looked at the gmsh-converter and implemented in my ideasUnv-converter.
It is now possible to define a group "rotCellZone" in cubit, that will be registered by the converter and a cellSet file will be written. Then it can be used together with a MRF code.
If anybody is interested to test out the converter, please drop me an email:
stefan <dot> radl <@> tugraz <dot> at
However, the converter is very much customized but can be easily adjusted.
cheers
Stefan
[snappyHexMesh] SHM doesn't create cellZones for one region Eko OpenFOAM Meshing & Mesh Conversion 10 January 24, 2018 02:03
It has to include complete definition of a type (not just fwd declaration), isn't it? Zeppo OpenFOAM Programming & Development 12 August 16, 2016 14:01
(AutoGRID 5) Problem in Geometry definition of propeller venkat_aero2007 Fidelity CFD 14 July 31, 2012 14:05
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
DecomposePar and CellZones Anne Lincke OpenFOAM 4 October 13, 2010 09:18
