[Commercial meshers] Problem converting fluent mesh
Like Tree1Likes
Old   June 25, 2007, 05:54
Default Problem converting fluent mesh
Vincent RIVOLA
vinz is on a distinguished road
Hi everybody,
A client gave me a fluent mesh, to try the case in OpenFOAM.
I tried to use fluentMeshToFoam and got the error message:
Dimension of grid: 3
Number of points: 31955
Reading points
Number of cells: 158329
Reading uniform cells
number of faces: 326387
Reading uniform faces
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
--> FOAM FATAL ERROR : Cannot find match for face 1.
Model: tet model face: 3(0 3 2) Mesh faces:
4
3(-1 16435 12859)
3(12859 12868 16435)
3(12871 12868 12859)
3(12868 12871 16435)
Matched points: 4(-1 -1 16435 12859)
From function create3DCellShape(const label cellIndex, const labelList& faceLabels, const labelListList& faces, const labelList& owner, const labelList& neighbour, const label fluentCellModelID)
in file create3DCellShape.C at line 281.
FOAM aborting
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
fluentMeshToFoam [0x804ffe6]
fluentMeshToFoam [0x80558ff]
__libc_start_main
__gxx_personality_v0
Abort
Does someone know what is going wrong? Please notice I'm not famiiar with fluent format so I don't know what's wrong either the mesh or the converter. However the mesh looks to run fine under Fluent.
Help would be much appreciated.
Vincent
vinz is offline   Reply With Quote
Old   July 3, 2007, 08:21
Default Hello all, I got the same e
mayank
Hello all,
I got the same error error message when converting mesh from fluent.But it is starnge that I already converted the same mesh by 'fluentmeshToFoam' a few days ago and now that mesh conversion does not work.
The error is as follows:
--> FOAM FATAL ERROR : Cannot find match for first face. cell model: tet first model face: 3(1 2 3) Mesh faces:
4
4(786 1968 1563 415)
4(1563 1968 1362 1263)
4(1362 1968 786 154)
4(154 786 415 63)
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 Foam::create3DCellShape(int, Foam::List<int> const&, Foam::List<foam::face> const&, Foam::List<int> const&, Foam::List<int> const&, int)
#3 main
#4 __libc_start_main
#5 __gxx_personality_v0
I have been doing stuff with fluentMeshtoFoam.L which is posted in other forums ,maybe that is the reason it stopped working.But I copied the original file again and compiled then also the same error is shown.
Can anybody help me with this.
Mayank.
Old   July 10, 2007, 06:58
Default Hi I got a similar Problem wit
Jens Klostermann
jens_klostermann is on a distinguished road
Hi I got a similar Problem with OpenFoam-1.4
error with fluentMeshToFoam.L from OpenFoam-1.4:
4
4(4046 5039 5022 3597)
4(5022 5039 12844 11579)
4(5039 4046 12832 12844)
4(4046 3597 11580 12832)
#3 main
#5 __gxx_personality_v0 at ../sysdeps/x86_64/elf/start.S:116
in file create3DCellShape.C at line 186.
FOAM aborting
Aborted
If I use fluentMeshToFoam.L from OpenFoam-1.3 with OpenFOAM-1.4 I get the following error:
--> FOAM FATAL ERROR : Trying to add 5th face to a cell with 4 faces. Face index: 7101 Current faces: 4(5888 7098 7099 7100)#0 Foam::error::printStack
#2 main
#3 __libc_start_main
#4 __gxx_personality_v0 at ../sysdeps/x86_64/elf/start.S:116
From function fluentMeshToFoam
in file fluentMeshToFoam.L at line 907.
FOAM aborting
If I use OpenFOAM 1.3 I the conversion works. I thought the problem is within fluentMeshToFoam.L, but this doesn't seem to be the case. Where do I have to dig to find more information?
Jens
jens_klostermann is offline   Reply With Quote
Old   July 10, 2007, 07:27
Default sorry but I'm a newbie in Open
Davide Pasini
ilpaso is on a distinguished road
sorry but I'm a newbie in OpenFoam.
Why don't you use gambitToFoam to import your mesh in OpenFoam?
I do this in gambit:
- create mesh
- change solver to "generic"
- create patches with differents name (wall, inlet, ...) and the same type: "ELEMENT_SIDE"
- use gambitToMesh to convert mesh
- In FoamX define the patch types
bye
Davide
zaynah04 likes this.
ilpaso is offline   Reply With Quote
Old   July 10, 2007, 07:55
Default Hy Davide, because I didn't
Jens Klostermann
Hy Davide,
because I didn't create the mesh myself and I just have *.msh file. And it worked with OpenFOAM-1.3 but not with OpenFOAM-1.4.
Best regards
Jens
Old   July 10, 2007, 08:11
Default Convert it with OF 1.3 and the
Francesco Del Citto
fra76 is on a distinguished road
Convert it with OF 1.3 and then use it with 1.4
Is a workaround, I know, but it could work...
Francesco
fra76 is offline   Reply With Quote
Old   July 10, 2007, 08:28
Default I don't know if this can help
Davide Pasini
I don't know if this can help you.....
another workaround:
if you have a .msh (or .cas) file import in gambit the mesh (file>import>mesh)
after do this:
bye
Davide
Old   July 10, 2007, 09:32
Default @Francesco this workarounds wo
Jens Klostermann
@Francesco this workarounds works. Thank you!
@Davide thanks for your hints
@all:
I don't want workarounds. I actually want to know, why it worked with OF-1.3 and not with OF-1.4. Maybe Mattijs, Henry, Eugene or Hrv has a hint where to dig further to get this bug.
Jens
Old   July 10, 2007, 09:45
Default The file create3DCellShape.C h
Hrvoje Jasak
The file create3DCellShape.C has not changed, which means there is a problem with the parsing. Run a diff on fluentMeshToFoam.L and start chasing it from there.
I would assume the face belongs to a zone that should be ignored - looks silly to add a fifth face on a quad.
Hrv
Hrvoje Jasak
Old   July 10, 2007, 10:07
Default Yes, indeed within the fluentM
Jens Klostermann
Yes, indeed within the fluentMeshToFoam directory only the fluentMeshToFoam.L has changed. I made a diff, which shows me a lot of changes. But I still have the problem that the fluentMeshToFoam (version OF-1.4) doesn't work with the fluentMeshToFoam.L taken from OF-1.3, which is strange (With OF-1.3 it works.).
Since this is not working I thought the error must come from somewhere else.
Regards Jens
PS: Don't know if the fluentMeshToFoam (version OF-1.3) works with the fluentMeshToFoam.L taken from OF-1.4?
Old   July 27, 2007, 09:25
Default Hi all I hope there is still
  #11
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi all
I hope there is still someone to answer my question on a friday afternoon ... in july ...with this weather (sunny here) ...
I created a mesh with Gambit, and importing to OF-1.3. In fact, I just tried to import it;
this is the OF message:
FINISHED LEXING
--> FOAM FATAL ERROR : Number of face labels not equal tonumber of face in the model. Number of face labels: 32774 number of faces in model: 6
so, if the number of face labels was close to the number of face in the model, I should correct by hand ... but there
I don't know where I can look to understand the problem and then, find a solution. I've defined only 5 BC on gambit so where the 6 and the 32774 come from ?
Can anybody help me with this problem before week end?
thanks,
Cedric
cedric_duprat is offline   Reply With Quote
Old   August 30, 2011, 02:59
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
Hi.
I'm trying to convert fluent mesh to OF.
$ fluentMeshToFoam fluent_V6_ascii_1.msh
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 2.0.1-51f1de99a4bc
Exec   : fluentMeshToFoam fluent_V6_ascii_1.msh
Date   : Aug 30 2011
Time   : 10:39:14
Host   : debian-toshiba
PID    : 4364
Case   : /home/jenek/msh1/fluentMsh
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/jenek/msh1/fluentMsh/system/controlDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Ok, I create folder system and emtpy controlDict file in it.
Date   : Aug 30 2011
Time   : 10:40:48
PID    : 4431
nProcs : 1
Create time
--> FOAM Serious Error :
    From function IOobject::readHeader(Istream&)
    in file db/IOobject/IOobjectReadHeader.C at line 89
    Reading "/home/jenek/msh1/fluentMsh/system/controlDict" at line 3
    First token could not be read or is not the keyword 'FoamFile'
Check header is of the form:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
problem while reading header for object controlDict
file: /home/jenek/msh1/fluentMsh/system/controlDict at line 3.
    in file db/regIOobject/regIOobjectRead.C at line 95.
FOAM exiting
Can anybody comment what is wrong?
j-avdeev is offline   Reply With Quote
Old   August 30, 2011, 10:32
Avdeev Evgeniy
Don't know why this not written in User Guide. Or I read inattentively?
fluent mesh file was successfully converted to OpenFOAM after
1. creating system folder in folder with fluent file
2. copying any controlDict file to system folder
3. run fluentMeshToFoam <fluent mesh file name> from directory with fluent mesh file. Running from other folder threw fluentMeshToFoam <fluent mesh file path> didn't work for me.
Old   November 30, 2011, 03:55
xinguang cui
flying is on a distinguished road
I have also met this problem in OpenFOAM 1.5, Is there some solution for it?
The error information is as following:
FINISHED LEXING
4
0()
0()
0()
0()
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/bwgrid/cae/openfoam/1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/bwgrid/cae/openfoam/1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/opt/bwgrid/cae/openfoam/1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#3 Foam::create3DCellShape(int, Foam::List<int> const&, Foam::List<Foam::face> const&, Foam::List<int> const&, Foam::List<int> const&, int) in "/opt/bwgrid/cae/openfoam/1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#4 main in "/opt/bwgrid/cae/openfoam/1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 __gxx_personality_v0 in "/opt/bwgrid/cae/openfoam/1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
flying is offline   Reply With Quote
Old   June 19, 2012, 02:47
kumawat
kumawatnana is on a distinguished road
Hi
i am new in OpenFOAM. i am trying to convert Fluent mesh file to OpenFOAM by using fluentMeshToFoam command in command prompt but i got "fluentMeshToFoam is not recognized as internal or external command operable program or batch file " massage .Can any one help me on this problem if possible send me step by step Procedure of mesh conversion.
thanks
Kumavat
kumawatnana is offline   Reply With Quote
Old   June 19, 2012, 02:50
Default OpenFOAM mesh conversion Problem
  #16
kumawat
Hi
thanks
Kumavat
Old   November 17, 2012, 03:30
zaynah K.
zaynah04 is on a distinguished road
I want to import my gambit mesh to open foam
I did create a case directory but still when i do fluent3DMeshToFoam
i obtain " command not find"
can anyone please explain to me step by step what must i do?
i am a newbie in both openfoam and ubuntu...
any help would be welcome.
regards
zaynah
zaynah04 is offline   Reply With Quote
Old   November 17, 2012, 03:47
kumawat
hii,
1) put your mesh file in working directory where o, constant ...folders are their .
2)after that go to working directory through command prompt.
3)then type fluent3DMeshToFoam <space> mesh file name.
try it....
regards
kumavat
Old   November 17, 2012, 03:57
zaynah K.
hi
thanks for your quick reply..
i did it but still i get " command not found"
Old   November 17, 2012, 05:25
kumawat
ok,
after entering into working directory just type fluent and after that tab button (keybord) two times then yes you will get commands which you can use on your system in that search fluent3DMeshToFoam if available then only you can able to convert mesh in your system. Also remember that "fluent3DMeshToFoam" is case sensetive
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
