August 26, 2004, 06:53 |
Gmsh with physicals
In the 2.3 version of FOAM, gmshToFoam is supplied, however it can't handle physical boundaries, which is quiet crucial. Are there anyone that are planning to extent the converter to handling this? If so, I would be VERY interested to hear about it!
P.S. In the sourcecode for gmshToFoam it looks like it is under way?! |
August 26, 2004, 07:25 |
Hello Rasmus,
gmshToFoam w
Hello Rasmus,
gmshToFoam was a quick&dirty attempt to have a look at the gmsh generated meshes. I tried doing the patch info but then got stuck since I was not clear what they were using for the boundaries. Am quite willing try fixing that piece of code if you can send me a simple testcase. E.g. can you send me a cube built out of tets with some different physical boundaries? Mattijs |
August 27, 2004, 10:57 |
I adapted the gmshToFoam conv
I adapted the gmshToFoam converter to use physical regions as patch numbers. Tried it on one case (thanks Rasmus) and it seems to work.
It will be in the next release or contact me directly if you want to try it. It requires a version 1 format file (whatever that may be - don't ask me about gmsh) and both volume elements (tets/hexes) and surface elements (triangles) present. Mattijs |
January 17, 2005, 12:04 |
I wrote a simple netgen Neutr
I wrote a simple netgen Neutral file format converter. It will be in the next release or you can contact me if you want it earlier.
Netgen is a pretty good & simple tetrahedral mesh generator which also allows setting of boundary regions. Mattijs |
March 9, 2005, 16:53 |
Hello
Would it be possible to
Lars Edvardsen
Rep Power: 17 |
Hello
Would it be possible to get the netgen to Foam converter from someone? I run OpenFoam on SuSE Linux 9,2 ? Best Regards Lars |
March 10, 2005, 03:47 |
Try following post:
http://
Mattijs Janssens
Rep Power: 26 |
Try following post:
http://www.cfd-online.com/cgi-bin/Op...=1245#POST1245 and - unpack (tar xzf XXX.tgz) - cd XXX - wclean - wmake Mattijs |
January 27, 2006, 12:57 |
I made some modifications to t
E. David Huckaby
Rep Power: 17 |
I made some modifications to the gmshToFoam converter to write out cellZones and faceZones of internal faces. A time consuming function call was also moved out of an inner loop, which seems to reduce the execution time significantly.
I have posted this to the wiki: http://openfoamwiki.net/index.php/Contrib_gmshToF oamMod Dave |
February 2, 2006, 14:11 |
Hello Dave,
can I put your
Mattijs Janssens
Rep Power: 26 |
Hello Dave,
can I put your gmshToFoam mods into the release? |
February 2, 2006, 14:20 |
Yes you can.
Dave
#9 |
E. David Huckaby
Rep Power: 17 |
Yes you can.
Dave |
February 2, 2006, 14:36 |
Could you send a small test ca
#10 |
Mattijs Janssens
Rep Power: 26 |
Could you send a small test case?
Just email it to me directly. |
[Gmsh] Converting gmsh to OpenFoam | Friendly | OpenFOAM Meshing & Mesh Conversion | 3 | June 26, 2018 05:46 |
[Gmsh] Insatlling gmsh from the source code-issue? | CFD-Lover | OpenFOAM Meshing & Mesh Conversion | 20 | June 12, 2018 06:39 |
[Gmsh] Cgns support for gmsh | robyTKD | OpenFOAM Meshing & Mesh Conversion | 1 | July 13, 2016 11:27 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
