[blockMesh] How to increase Mesh near the surface of the model
Old   September 1, 2008, 09:23
Default How to increase Mesh near the surface of the model
weihong yao
ivanyao is on a distinguished road
hi,
i am use OF1.4,i don't know how to increase Mesh near the surface of the model?
ivanyao is offline   Reply With Quote
Old   September 1, 2008, 11:19
Default If you talk about the surface
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
If you talk about the surface of some multiphase flow, then I do not think it is straight forward.
If you talk about increasing the number of computational cells toward the boundaries of your computational domain, then look into the user guide, the meshing chapter and especially the grading routines.
- Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   September 1, 2008, 20:16
Default hi, I think i have got your m
weihong yao
hi,
I think i have got your message.thank you!
Old   September 1, 2008, 21:20
Default hi, i have followed your sugg
weihong yao
hi,
i have followed your suggestion.but it can not increase nunber of the cells.my blockMesh.file are follow:
vertices
(-3 -3 0)
(3 -3 0)
(3 3 0)
(-3 3 0)
(-3 -3 6)
(3 -3 6)
(3 3 6)
(-3 3 6)
(-39 -3 0)
(-39 3 0)
(-39 -3 6)
(-39 3 6)
(153 -3 0)
(153 3 0)
(153 -3 6)
(153 3 6)
(-3 -60 0)
(3 -60 0)
(-3 -60 6)
(3 -60 6)
(-3 60 0)
(3 60 0)
(-3 60 6)
(3 60 6)
(-39 -60 0)
(153 -60 0)
(153 60 0)
(-39 60 0)
(-39 -60 6)
(153 -60 6)
(153 60 6)
(-39 60 6)
(-39 -60 60)
(153 -60 60)
(153 60 60)
(-39 60 60)
(-39 -3 60)
(-39 3 60)
(-3 -60 60)
(3 -60 60)
(153 -3 60)
(153 3 60)
(-3 60 60)
(3 60 60)
(-3 -3 60)
(3 -3 60)
(3 3 60)
(-3 3 60)
blocks
hex (24 16 0 8 28 18 4 10) (36 57 6) simpleGrading (1 1 1)
hex (28 18 4 10 32 38 44 36) (36 57 54) simpleGrading (1 1 1)
hex (16 17 1 0 18 19 5 4) (6 57 6) simpleGrading (1 1 1)
hex (18 19 5 4 38 39 45 44) (6 57 54) simpleGrading (1 1 1)
hex (17 25 12 1 19 29 14 5) (150 57 6) simpleGrading (1 1 1)
hex (19 29 14 5 39 33 40 45) (150 57 54) simpleGrading (1 1 1)
hex (1 12 13 2 5 14 15 6) (150 6 6) simpleGrading (1 1 1)
hex (5 14 15 6 45 40 41 46) (150 6 54) simpleGrading (1 1 1)
hex (2 13 26 21 6 15 30 23) (150 57 6) simpleGrading (1 1 1)
hex (6 15 30 23 46 41 34 43) (150 57 54) simpleGrading (1 1 1)
hex (3 2 21 20 7 6 23 22) (6 57 6) simpleGrading (1 1 1)
hex (7 6 23 22 47 46 43 42) (6 57 54) simpleGrading (1 1 1)
hex (9 3 20 27 11 7 22 31) (36 57 6) simpleGrading (1 1 1)
hex (11 7 22 31 37 47 42 35) (36 57 54) simpleGrading (1 1 1)
hex (8 0 3 9 10 4 7 11) (36 6 6) simpleGrading (1 1 1)
hex (10 4 7 11 36 44 47 37) (36 6 54) simpleGrading (1 1 1)
hex (4 5 6 7 44 45 46 47) (6 6 54) simpleGrading (1 1 1)
edges
patches
patch inlet
(27 9 11 31)
(37 11 31 35)
(9 8 10 11)
(11 10 36 37)
(8 24 28 10)
(10 28 32 36)
patch outlet
(25 12 14 29)
(29 14 40 33)
(12 13 15 14)
(14 15 41 40)
(13 26 30 15)
(15 30 34 41)
wall front
(0 3 7 4)
wall <back>
(1 2 6 5)
wall <left>
(0 1 5 4)
wall <right>
(2 3 7 6)
wall <top>
(4 5 6 7)
empty <wall>
(24 16 18 28)
(28 18 38 32)
(16 17 19 18)
(18 19 39 38)
(17 25 29 19)
(19 29 33 39)
(26 21 23 30)
(30 23 43 34)
(21 20 22 23)
(23 22 42 43)
(20 27 31 22)
(22 31 35 42)
(32 38 44 36)
(44 36 37 47)
(47 37 35 42)
(38 39 45 44)
(44 45 46 47)
(47 46 43 42)
(39 33 40 45)
(40 45 46 41)
(41 46 43 34)
(16 24 8 0)
(0 8 9 3)
(3 9 27 20)
(17 16 0 1)
(2 3 20 21)
(25 17 1 12)
(12 1 2 13)
(13 2 21 26)
wall <bottom>
mergePatchPairs
I change the simpleGrading(1 1 1) by (1 1 5).my geometry is very simple ,just put the 6*6*6 cube into 192*120*60 box.my purpose is increasing grid near the surface of the cube.
would someone help me?
Old   September 1, 2008, 21:32
Default Hi, WeiHong, First of all,
Ivan Lau
ivanwhlau is on a distinguished road
Hi, WeiHong,
First of all, changing simpleGrading, which is cell expansion ratios, will not increase the number of cells.
Read the manual here:
http://www.opencfd.co.uk/openfoam/do...#x25-1390005.3
Hmm.. I see what you try to do. Well, where do you put that (1 1 5)? If you really want to intensively increase the number of cells close to surface, I recommend you to add one more strip above.. It is not too hard, but tedious, somehow.
iL
ivanwhlau is offline   Reply With Quote
Old   September 1, 2008, 22:44
Default hi,ivan, thank you for giving
weihong yao
hi,ivan,
thank you for giving the feedback! first, i put the (1 1 5)into simpleGrading of the blocks,as follow:
hex (24 16 0 8 28 18 4 10) (36 57 6) simpleGrading (1 1 5)
hex (28 18 4 10 32 38 44 36) (36 57 54) simpleGrading (1 1 5)
hex (16 17 1 0 18 19 5 4) (6 57 6) simpleGrading (1 1 5)
hex (18 19 5 4 38 39 45 44) (6 57 54) simpleGrading (1 1 5)
hex (17 25 12 1 19 29 14 5) (150 57 6) simpleGrading (1 1 5)
hex (19 29 14 5 39 33 40 45) (150 57 54) simpleGrading (1 1 5)
hex (1 12 13 2 5 14 15 6) (150 6 6) simpleGrading (1 1 5)
hex (5 14 15 6 45 40 41 46) (150 6 54) simpleGrading (1 1 5)
hex (2 13 26 21 6 15 30 23) (150 57 6) simpleGrading (1 1 5)
hex (6 15 30 23 46 41 34 43) (150 57 54) simpleGrading (1 1 5)
hex (3 2 21 20 7 6 23 22) (6 57 6) simpleGrading (1 1 5)
hex (7 6 23 22 47 46 43 42) (6 57 54) simpleGrading (1 1 5)
hex (9 3 20 27 11 7 22 31) (36 57 6) simpleGrading (1 1 5)
hex (11 7 22 31 37 47 42 35) (36 57 54) simpleGrading (1 1 5)
hex (8 0 3 9 10 4 7 11) (36 6 6) simpleGrading (1 1 5)
hex (10 4 7 11 36 44 47 37) (36 6 54) simpleGrading (1 1 5)
hex (4 5 6 7 44 45 46 47) (6 6 54) simpleGrading (1 1 5)
is that the only way to increase the grid close the surface of cube?you mean that create more vertices and blocks?
Old   September 2, 2008, 12:10
Default hi, weihong, Yes, you can cre
Ivan Lau
hi, weihong,
Yes, you can create more vertices and blocks next to surface and increase the number of cells here. Does your blockMesh work? If so, what you did now is to put the bottom cells with closer space and the top cells far apart....
Did you follow the meshing routine like what Niels suggest? Read words by words on manual of Meshing. You can easily solve this problem.
Regards,
iL
Old   September 3, 2008, 03:16
Default hi, thank you!i solved th
weihong yao
hi,
thank you!i solved the problem. thank you!
Surface mesh from polygon model of motorcycle Simonomis Main CFD Forum 3 July 27, 2011 15:27
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
