Pei-Ying Hsieh
Rep Power: 18 ![]() |
I created a quarter of a cylinder (the cross section is a quarter of a circle) using blockMesh. The problem I am solving is true 3D, so, I would like to generate the mesh of the complete cylinder. Since this is symmetrical in X-plane and in Y-plane, how can I generate the mesh of the whole cylinder using "mirror" technique? Pei |
Eugene de Villiers
Rep Power: 21 ![]() |
mirrorMesh?
Pei-Ying Hsieh
Thanks Eugene!
I did try mirrorMesh and got strange results. The geometry was mirrored, but, mesh were messed up. It looks like mirrorMesh requirs mirrorMeshDict. I set the point to (0 0 0) and vectorToNormal to (-1 0 0). The following command was used: mirrorMesh . casename I probably did something wrong. pei |
Pei-Ying Hsieh
Hi Eugene,
I tried mirrorMesh again. I moved the base point to an node point inside the domain, and it worked perfectly. Previously, I simply picked one corner point of the geometry. Also, after mirrorMesh, it looks like there is no need to run stitchMesh to remove duplicate nodes on the symmetry plane - nice! Pei |
nikhil babu madduri
Rep Power: 17 ![]() |
hi pei.
even im trying to solve the same problem as u ve....first i generated the quarter cylinder. now i want to make it a complete cylinder. can u explain how do u do that? itz a kind of urgent, replies will be highly appreciated. regards, nike |
nikhil babu madduri
hello,
where can we find this "mirrorMeshDict" file? replies will be highly appreciated. Thanks Nikhil |
Christian Winkler
Hi Nikhil,
A sample dictonary can be found under: ~/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/mesh/manipulation/mirrorMesh Btw.: Please refrain from double postings in the future. In fact it makes it more unlikely that your post is answered. This has been discussed recently: http://openfoamwiki.net/index.php/Ho..._Message_Board Best regards Christian |
Hi Nikhil
Please check out this directory OpenFOAM/OpenFOAM-1.4.1/applications/utilities/mesh/manipulation/mirrorMesh For future searches please use beautiful features of LINUX such as locate or find . Other appraoch is to please familiarize yourself with the following OpenFOAM folders: /src /applications/solvers /applications/utilities Hope that will help. With Best Regards Jaswi |
#9 | |
zink
Rep Power: 10 ![]() |
When you mirror the mesh what will happen to the earlier defined boundary patches in the blockMesh dict?
I am using quarter circle blockMesh to create full circle. My mesh file is like https://cfd.direct/openfoam/user-guide/v6-platehole/ Initially, the boundary are hole, right , top, left and down. I am able to generate the the full circle but I am concerned about defining the new patch names and what will happen to the earlier faces at the symmetry location The patch names should be inlet, outlet, topwall, bottomwall and cylinder Can anyone guide me? Quote:
create the file *.foam | phongstar | OpenFOAM | 12 | October 14, 2018 18:06 |
[GAMBIT] How to plot S pipe | mariam.sara | ANSYS Meshing & Geometry | 36 | November 7, 2013 15:22 |
[ANSYS Meshing] is it possible to create virtual edges on the blades | er_ijaz | ANSYS Meshing & Geometry | 0 | November 3, 2013 05:15 |
[DesignModeler] Design Modeller create surface | papis | ANSYS Meshing & Geometry | 0 | October 31, 2013 13:52 |
About create interface! | xinzhiyu2008 | STAR-CCM+ | 2 | August 6, 2010 20:47 |
