[blockMesh] Create mirror mesh
Old   February 9, 2007, 12:07
Default Create mirror mesh
Pei-Ying Hsieh
hsieh is on a distinguished road
I created a quarter of a cylinder (the cross section is a quarter of a circle) using blockMesh. The problem I am solving is true 3D, so, I would like to generate the mesh of the complete cylinder. Since this is symmetrical in X-plane and in Y-plane, how can I generate the mesh of the whole cylinder using "mirror" technique?
Pei
hsieh is offline   Reply With Quote
Old   February 9, 2007, 12:13
Default mirrorMesh?
Eugene de Villiers
eugene is on a distinguished road
mirrorMesh?
eugene is offline   Reply With Quote
Old   February 9, 2007, 15:07
Default Thanks Eugene! I did try mi
Pei-Ying Hsieh
Thanks Eugene!
I did try mirrorMesh and got strange results. The geometry was mirrored, but, mesh were messed up. It looks like mirrorMesh requirs mirrorMeshDict. I set the point to (0 0 0) and vectorToNormal to (-1 0 0). The following command was used:
mirrorMesh . casename
I probably did something wrong.
pei
Old   February 10, 2007, 07:18
Default Hi Eugene, I tried mirrorMe
Pei-Ying Hsieh
Hi Eugene,
I tried mirrorMesh again. I moved the base point to an node point inside the domain, and it worked perfectly. Previously, I simply picked one corner point of the geometry.
Also, after mirrorMesh, it looks like there is no need to run stitchMesh to remove duplicate nodes on the symmetry plane - nice!
Pei
Old   June 26, 2008, 00:19
Default hi pei. even im trying to sol
nikhil babu madduri
nikhilmadduri is on a distinguished road
hi pei.
even im trying to solve the same problem as u ve....first i generated the quarter cylinder. now i want to make it a complete cylinder. can u explain how do u do that?
itz a kind of urgent,
replies will be highly appreciated.
regards,
nike
nikhilmadduri is offline   Reply With Quote
Old   July 8, 2008, 01:59
Default hello, where can we find th
nikhil babu madduri
hello,
where can we find this "mirrorMeshDict" file?
Thanks
Nikhil
Old   July 8, 2008, 02:50
Default Hi Nikhil, A sample dictona
caw
Christian Winkler
caw is on a distinguished road
Hi Nikhil,
A sample dictonary can be found under:
~/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/mesh/manipulation/mirrorMesh
Btw.: Please refrain from double postings in the future. In fact it makes it more unlikely that your post is answered.
This has been discussed recently:
http://openfoamwiki.net/index.php/Ho..._Message_Board
Best regards
Christian
caw is offline   Reply With Quote
Old   July 8, 2008, 02:51
Default Hi Nikhil Please check out
jaswi is on a distinguished road
Hi Nikhil
Please check out this directory
For future searches please use beautiful features of LINUX such as locate or find . Other appraoch is to please familiarize yourself with the following OpenFOAM folders:
/src
/applications/solvers
Hope that will help.
With Best Regards
Jaswi
jaswi is offline   Reply With Quote
Old   April 22, 2022, 03:03
zink
ansab_sindhu is on a distinguished road
When you mirror the mesh what will happen to the earlier defined boundary patches in the blockMesh dict?
I am using quarter circle blockMesh to create full circle. My mesh file is like
https://cfd.direct/openfoam/user-guide/v6-platehole/
Initially, the boundary are hole, right , top, left and down.
I am able to generate the the full circle but I am concerned about defining the new patch names and what will happen to the earlier faces at the symmetry location
The patch names should be
inlet, outlet, topwall, bottomwall and cylinder
Can anyone guide me?
Originally Posted by jaswi View Post
Hi Nikhil
/src
With Best Regards
Jaswi
ansab_sindhu is offline   Reply With Quote
create the file *.foam phongstar OpenFOAM 12 October 14, 2018 18:06
[GAMBIT] How to plot S pipe mariam.sara ANSYS Meshing & Geometry 36 November 7, 2013 15:22
[ANSYS Meshing] is it possible to create virtual edges on the blades er_ijaz ANSYS Meshing & Geometry 0 November 3, 2013 05:15
[DesignModeler] Design Modeller create surface papis ANSYS Meshing & Geometry 0 October 31, 2013 13:52
About create interface! xinzhiyu2008 STAR-CCM+ 2 August 6, 2010 20:47
