[Commercial meshers] FluentMesh conversion problem
Old   November 26, 2006, 08:41
Default FluentMesh conversion problem
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
dear everyone,
i have a fluent .msh file when i use fluentMeshToFoam to change the mesh to Foam. it is said :
FINISHED LEXING
Foam::error::printStack(Foam:stream&)
Foam::sigSegv::sigSegvHandler(int)
/lib/tls/libpthread.so.0 [0x3dc8b8]
fluentMeshToFoam [0x8055421]
__libc_start_main
__gxx_personality_v0
what is problem?
waynezw0618 is offline   Reply With Quote
Old   November 26, 2006, 10:21
Default Did you write out your Fluent
Hrvoje Jasak
Did you write out your Fluent file in ascii?
Could you please produce a trace-back and post it here.
Hrv
Hrvoje Jasak
Old   November 26, 2006, 22:37
Default root@localhost ~]# fluentMeshT
wayne.zhang
[root@localhost ~]# fluentMeshToFoam OpenFOAM/root-1.3/run/tutorials/lesInterFoam/ hydrocylone /root/fluent-new.msh
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : fluentMeshToFoam OpenFOAM/root-1.3/run/tutorials/lesInterFoam/ hydrocylone /root/fluent-new.msh
Date : Nov 27 2006
Time : 11:45:05
Host : localhost.localdomain
PID : 21928
Root : OpenFOAM/root-1.3/run/tutorials/lesInterFoam/
Case : hydrocylone
Nprocs : 1
Create time
Dimension of grid: 3
Number of points: 356188
Reading points
Number of cells: 340982
Reading uniform cells
number of faces: 1038000
Reading uniform faces
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
FINISHED LEXING
/lib/tls/libpthread.so.0 [0xbf08b8]
__libc_start_main
Old   November 26, 2006, 23:05
Default Dear Hrv: i use ICEMcfd to cr
wayne.zhang
Dear Hrv:
i use ICEMcfd to creat mesh for fluent,what is wrong with it?
it is a mesh file for hydrocylone,could the OpenFoam do the Numerical simulation for both air-core and particle in the hydrocylone?
Old   November 28, 2006, 04:31
Default You can produce a more detaile
Mattijs Janssens
mattijs is on a distinguished road
You can produce a more detailed traceback if you recompile fluentMeshToFoam with full debugging. Just add to EXE_INC in Make/options the compilation options
-DFULLDEBUG -g -O0
and recompile.
mattijs is offline   Reply With Quote
Old   November 30, 2006, 01:53
Default Hi Hrv and Mattijs: i have do
wayne.zhang
Hi Hrv and Mattijs:
i have do the recompilation of fluentMeshToFoam,and here is the new trace back:
[root@localhost .OpenFOAM-1.3]# fluentMeshToFoam /root/OpenFOAM/root-1.3/run/tutorials/oodles hyrocylone /root/fluent-new.msh
Exec : fluentMeshToFoam /root/OpenFOAM/root-1.3/run/tutorials/oodles hyrocylone /root/fluent-new.msh
Date : Nov 30 2006
Time : 14:54:42
PID : 6299
Root : /root/OpenFOAM/root-1.3/run/tutorials/oodles
Case : hyrocylone
Nprocs : 1
Create time
Reading points
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
Reading zone data
FINISHED LEXING
--> FOAM FATAL ERROR : index 6 out of range 0 ... 5
From function UList<t>::checkIndex(const label)
in file /root/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/UListI.H at line 107.
FOAM aborting
Foam::error::abort()
fluentMeshToFoam [0x804da24]
fluentMeshToFoam [0x804e27c]
fluentMeshToFoam [0x804e2e2]
fluentMeshToFoam [0x8056d14]
__libc_start_main
已放弃
please help me to solve the problem,and how to make simulation of aircore and particle in the hydrocylone by Foam?
Old   November 30, 2006, 03:48
Default Your mesh is invalid. Try run
Hrvoje Jasak
Your mesh is invalid. Try running the attached version of fluentMeshToFoam and you will get a full error message. Of course, you need to compile it first.
Hrv
fluentMeshToFoam.L
Hrvoje Jasak
Old   November 30, 2006, 05:52
Default FINISHED LEXING --> F
wayne.zhang
FINISHED LEXING
--> FOAM FATAL ERROR : Trying to add 7th face to a cell with 6 faces. Face inde x: 1007892 Current faces: 6(35472 36212 36268 36269 36270 36271)
From function fluentMeshToFoam
in file fluentMeshToFoam.L at line 928.
FOAM aborting
fluentMeshToFoam [0x804da74]
fluentMeshToFoam [0x80571da]
__libc_start_main
已放弃
Old   November 30, 2006, 06:03
Default Hi Hrv i use ICEMCFD to creat
wayne.zhang
Hi Hrv
i use ICEMCFD to creat this .msh file for fluent calculation. i am not quiet sure about my method of export the .msh file for fluent calculation in ICEM. i guess the problem may because of my operation. here is my operation:
1) make geo and premesh
2) right click the block tree and choose convert to unstructure mesh
3) choose fluent as solver
4) export msh
it that right?
i am not sure about "2)" ,but all my friends do it.
could you please help me?
thanks!
Old   November 30, 2006, 06:49
Default I'm just curious: did you try
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
I'm just curious: did you try to read this mesh with fluent?
Dragos
dmoroian is offline   Reply With Quote
Old   November 30, 2006, 07:02
Default Fluent will quietly fix the me
  #11
Hrvoje Jasak
Fluent will quietly fix the mesh for you during the read. With all these broken meshes, if you can read them into Fluent and write them out again, the new case file will convert correctly.
In short, Icem, Gridgen and the like do not correctly adhere to Fluent mesh description and there isn't much I can do about it.
Hrv
Hrvoje Jasak
Old   November 30, 2006, 22:38
Default HI Dragos i have read this me
  #12
wayne.zhang
HI Dragos
i have read this mesh to fluent without any errors.
wayne
Old   November 30, 2006, 23:12
Default Hi Hrv i use Tgrid to refine
  #13
wayne.zhang
Hi Hrv
i use Tgrid to refine the mesh.and now i can convert it to Foam!thanks!
by the way,it there any application in foam for the multiphase flow in hydrocyclone ?or i need to write the application for my simulation?
[Commercial meshers] Problem In conversion From Fluent to Foam aks017 OpenFOAM Meshing & Mesh Conversion 0 April 15, 2019 06:12
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 19:41
Mesh& steptime independant: conduction-convection problem Fati1 Main CFD Forum 1 October 28, 2018 13:52
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Unit Conversion Problem lambuhere CFX 0 August 20, 2004 04:49
