[Gmsh] Converting curved surfaces problem
Old   August 1, 2007, 05:58
Default Converting curved surfaces problem
Mark Dowling
markdowlinguk is on a distinguished road
Can anybody tell me what might be wrong here..
I'm having problems whenever I try to convert a GMSH .msh file which contains a curved surface (as generated by the circle arc option in Gmsh). It generates a reasonably looking mesh in Gmsh but when I run gmshToFoam I get a whole load of the following type of error...
--> FOAM Warning : Not using gmsh face 3(21 2 20) since zero vertex is not on boundary of polyMesh
--> FOAM Warning :
From function gmshToFoam
in file gmshToFoam.C at line 799
Could not match gmsh face 3(21 2 20) to any of the interior or exterior faces that share the same 0th point
--> FOAM Warning :
Could not match gmsh face 3(3 2 21) to any of the interior or exterior faces that share the same 0th point
Viewing the resulting mesh on paraFoam shows that only the parts of the mesh enclosed by straight lines have been converted (and correctly!) but areas enclosed in one or more curved line are omitted from the mesh in paraFoam
Any ideas - I'm completely confused - I think Im defining the curves okay in Gmsh, but Im a beginner to all this, so I might be wrong!
Is Gmsh the best free mesh generator available on the net or is there something more useful for generating 3D meshes as trying to write out a complex blockMeshDict manually is making my head spin.
Regards
Mark
markdowlinguk is offline   Reply With Quote
Old   August 1, 2007, 20:52
Default Hi, A likely cause in such a
Takuya OSHIMA
7islands is on a distinguished road
A likely cause in such a case is you forgot to define a physical volume that includes the volume enclosed by the curved surfaces (if there's any physical group defined), thus there's no volumetric elements (tet/hex etc.) for the volume in the .msh file. If you use physical group definition in your .geo please check the definition carefully, or save the .msh file with Mesh.SaveAll set to 1.
Takuya
7islands is offline   Reply With Quote
Old   August 2, 2007, 05:42
Default Hi Takuya, My experience with
Mark Dowling
Hi Takuya,
My experience with Gmsh is limited but I think I have the physical volume set up correctly - see the included simple .geo file...
Point (1) = {-25, -50, 0, 25};
Point (2) = {25, -50, 0, 25};
Point (3) = {25, 50, 0, 25};
Point (4) = {-25, 50, 0, 25};
Point (5) = {25, -50, 1, 25};
Point (6) = {25, 50, 1, 25};
Point (10) = {-25, 50, 1, 25};
Point (14) = {-25, -50, 1, 25};
Point (15) = {0, 50, 0, 25};
Point (16) = {0, 50, 1, 25};
Line (1) = {1, 2};
Line (2) = {2, 3};
Line (3) = {3, 4};
Line (4) = {4, 1};
Line (8) = {5, 6};
Line (9) = {6, 10};
Line (10) = {10, 14};
Line (11) = {14, 5};
Line (13) = {2, 5};
Line (14) = {3, 6};
Line (18) = {4, 10};
Line (22) = {1, 14};
Circle (29) = {6, 16, 10};
Circle (30) = {3, 15, 4};
Line Loop (6) = {2, 3, 4, 1};
Plane Surface (6) = {6};
Line Loop (15) = {2, 14, -8, -13};
Ruled Surface (15) = {15};
Line Loop (19) = {3, 18, -9, -14};
Ruled Surface (19) = {19};
Line Loop (23) = {4, 22, -10, -18};
Ruled Surface (23) = {23};
Line Loop (27) = {1, 13, -11, -22};
Ruled Surface (27) = {27};
Line Loop (28) = {8, 9, 10, 11};
Plane Surface (28) = {28};
Line Loop (32) = {14, 29, -18, -30};
Ruled Surface (32) = {32};
Line Loop (34) = {9, -29};
Plane Surface (34) = {34};
Line Loop (36) = {30, -3};
Plane Surface (36) = {36};
Surface Loop (1) = {6, 28, 15, 19, 23, 27};
Volume (1) = {1};
Physical Point(37) = {6,3,16,15,10,4,14,1,5,2};
Physical Line(38) = {11,1,8,2,10,4,9,3,29,30,14,18,22,13};
Physical Surface(39) = {28,6,27,23,15,19,32,34,36};
Physical Volume(40) = {1};
From this I generated the 1D, 2D and 3D mesh and then saved as .msh, but when I try to run gmshToFoam i get lots of error like...
--> FOAM Warning : Not using gmsh face 3(20 3 2) since zero vertex is not on boundary of polyMesh
--> FOAM Warning :
Could not match gmsh face 3(20 3 2) to any of the interior or exterior faces that share the same 0th point
If you can work out what I'm doing wrong then please let me know
Many thanks
mark
Old   August 2, 2007, 06:50
Default gmshToFoam expects all faces o
Mattijs Janssens
gmshToFoam expects all faces of the surface mesh to match an external face of the volume mesh. It uses the surface mesh regions to denote patches of the volume mesh.
I haven't really used gmsh but seems to me you have extraneous information in your file.
Old   August 2, 2007, 08:05
Default Hi Mark, Try replacing the li
Takuya OSHIMA
Hi Mark,
Try replacing the line
to
Surface Loop (1) = {6, 28, 15, 23, 27, 32, 34, 36};
(remove surface 19 and add 32, 34 and 36).
I haven't tried the final gmshToFoam conversion test by myself but the physical volume definition clearly lacks the part which is enclosed by the curved surface, while the physical surface definition seems to be OK.
And just fyi the last part of the thread
http://www.cfd-online.com/OpenFOAM_D...es/1/3841.html
might be helpful for checking if physical group definition is exactly as you intended.
Takuya
[Commercial meshers] Problem encountered in converting Fluent mesh to OpenFOAM Mesh sathya123 OpenFOAM Meshing & Mesh Conversion 2 November 22, 2015 03:22
[Commercial meshers] Problem converting fluent (.msh) into .foam format with very big mesh Balti OpenFOAM Meshing & Mesh Conversion 8 June 20, 2013 16:43
[Gmsh] problem converting mesh from gmsh Fried OpenFOAM Meshing & Mesh Conversion 8 October 18, 2011 08:53
Multiple Sahdows / Periodicity Problem Michael Pi FLUENT 0 July 11, 2005 07:42
Normal Vector on Curved Surfaces Karl FLUENT 0 July 2, 2001 04:35
