May 8, 2006, 02:05 |
GmshToFoam undefined faces
Giuseppe Noviello
Hi to all
my name is Giuseppe and I'm new user of OF and gmsh. I've a problem with my simple case a cube, so when I use gmshToFoam utility it report this warning: Exec : gmshToFoam /home/giuseppe/OpenFOAM/giuseppe-1.3/run/tutorials/simpleFoam prova cubef.msh Date : May 08 2006 Time : 08:00:30 Host : linux PID : 7819 Root : /home/giuseppe/OpenFOAM/giuseppe-1.3/run/tutorials/simpleFoam Case : prova Nprocs : 1 Create time Read nVerts:865 Read nElems:4928 Mapping region 6 to Foam patch 0 Mapping region 15 to Foam patch 1 Mapping region 19 to Foam patch 2 Mapping region 23 to Foam patch 3 Mapping region 27 to Foam patch 4 Mapping region 28 to Foam patch 5 Mapping region 1 to Foam cellZone 0 Cells: total:4016 hex :0 prism:0 pyr :0 tet :4016 Patches: Patch Size 0 228 1 94 2 94 3 94 4 86 5 228 CellZones: Zone Size 0 4016 --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 573 Found 824 undefined faces in mesh; adding to default patch. Finding faces of patch 0 Finding faces of patch 1 Finding faces of patch 2 Finding faces of patch 3 Finding faces of patch 4 Finding faces of patch 5 FaceZones: Zone Size Writing zone 0 to cellZone cellZone_0 and cellSet End where is my error? someone can help me? Thanks to all. Giuseppe |
May 15, 2006, 04:39 |
It means you do not have defin
Mattijs Janssens
Rep Power: 26 |
It means you do not have defined gmsh surfaces on all boundary faces. You obviously have some:
Patch Size 0 228 1 94 2 94 3 94 4 86 5 228 but there are still 824 boundary faces that are not covered by gmsh surfaces. |
May 19, 2006, 06:35 |
Hi Mattijs
exactly which is t
Giuseppe Noviello
Hi Mattijs
exactly which is the right procedure? This is my simple geo file: Point(1) = {0,0,0,0.1}; Point(2) = {0.5,0,0,0.1}; Point(3) = {0.0,0.5,0,0.1}; Point(4) = {0.5,0.5,0,0.1}; Line(1) = {1,2}; Line(2) = {2,4}; Line(3) = {4,3}; Line(4) = {3,1}; Line Loop(5) = {2,3,4,1}; Plane Surface(6) = {5}; Extrude {0,0,0.5} { Surface{6}; } Physical Surface(101) = {15,6,23,28,19,27}; Physical Volume(100)= {1}; I've seen that 824 faces is the number of prism which gmsh produce, beside tetrahedra is right? Thanks in advantage Giuseppe |
May 19, 2006, 12:58 |
Sorry not prism but triangles.
Giuseppe Noviello
Sorry not prism but triangles....
May 19, 2006, 13:38 |
Hi, maybe its a bug and can be
Hi, maybe its a bug and can be solved by running the newest gmsh version (v1.65) at: http://geuz.org/gmsh/src/
If you are to use the mesh you might want to use the extra recombine posibillity in the extruded direction. see the totorial 3 for this. |
May 20, 2006, 07:53 |
Hi, Giuseppe,
I ran your si
Pei-Ying Hsieh
Rep Power: 18 |
Hi, Giuseppe,
I ran your simple geo file. I got 336 triangles and the rests are Tets. I used gmsh 1.65. Your geo file looked fine to me. Recombine Surface will give you hex and/or prism elements, which are better than tet elements. Pei |
May 21, 2006, 01:47 |
Hi,Pei
I've put Recombine Sur
Giuseppe Noviello
Hi,Pei
I've put Recombine Surface im my geo file but i've 96 Triangles 120 Quads 0 Tet 0 Hex and 0 prism .............. Plane Surface(6) = {5}; Extrude {0,0,0.5} { Surface{6}; } Recombine Surface{15,6,23,28,19,27}; .............................. moreover when I use gmshToFoam for import mesh I've FOAM FATAL ERROR : faces deallocated Where is my mistake? Thanks Giuseppe |
May 22, 2006, 04:54 |
I don't know much about gmsh b
Mattijs Janssens
Rep Power: 26 |
I don't know much about gmsh but an error like
FOAM FATAL ERROR : faces deallocated probably means that there are no volume elements (tets, hexes etc.) in the file you are trying to read. Just look at the file with an editor. 2nd number is the element type acc. to the gmsh documentation. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
