[Commercial meshers] GambitToFoam error please help me
Old   November 8, 2006, 07:27
Default GambitToFoam error please help me
gabrieler
I a problem. I have generated a mesh using gambit 2.2.30. The mesh format is neu.
When I try to convert this to openfoam I get the following error:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web:
Http://www.openfoam.org |
| \/ M anipulation | |
Exec : gambitToFoam /home/Gabriele/OpenFOAM/Gabriele-1.3/run/tutorials/icoFoam/ mod2Dpr mesh_1.neu
Date : Nov 08 2006
Time : 14:09:28
Host : linux-26vo
PID : 5356
Root : /home/Gabriele/OpenFOAM/Gabriele-1.3/run/tutorials/icoFoam/
Case : mod2Dpr
Nprocs : 1
Create time
Title: mesh 1
Written by Gambit version 2.2.30
Nov 2006 number of points: 15262
number of cells: 5701
number of patches: 6
Reading nodal coordinates
Reading cells
Reading cell streams
Reading cell stream labels
Finished reading cell stream labels
Reading patches
patch 0: name: inlet
Reading patches
patch 1: name: outlet
Reading patches
patch 2: name: wall
Reading patches
--> FOAM FATAL IO ERROR : Attempt to get back from bad stream
file: IStringStream.sourceFile at line 0.
From function void Istream::getBack(token& t)
in file db/IOstreams/IOstreams/Istream.C at line 44.
FOAM exiting
Can anyone help me ?
I'm sorry, my english is not good.
Thanks
Gabriele
Old   November 8, 2006, 09:25
Default Try loading the mesh into Flue
Hrvoje Jasak
Try loading the mesh into Fluent and writing it out and then try again.
Hrv
Hrvoje Jasak
Old   November 8, 2006, 09:30
Default I can't. I haven't Fluent. Ga
gabrieler
Gabriele
Old   November 8, 2006, 09:34
Default But you have Gambit, which mea
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
But you have Gambit, which means you can save it in fluent format "msh".
So, try that and use fluentMeshToFoam insead of gambitToFoam.
Dragos
dmoroian is offline   Reply With Quote
Old   November 8, 2006, 09:41
Default Hi Gabrielle, In any case,
Hrvoje Jasak
Hi Gabrielle,
In any case, there should not be a problem. Can I have a look at that Gambit file (I wrote the converter). You can find my E-mail address in the profile.
Hrv
Hrvoje Jasak
[Commercial meshers] GambitToFoam segmentation fault yurifrey OpenFOAM Meshing & Mesh Conversion 2 August 3, 2013 07:36
[Commercial meshers] gambitToFoam for conjugate heat transfer operita OpenFOAM Meshing & Mesh Conversion 1 March 24, 2012 09:49
[Commercial meshers] gambitToFoam mesh convertion error gascortado OpenFOAM Meshing & Mesh Conversion 1 January 19, 2011 05:51
[Commercial meshers] gambitToFoam boundary defining problem maysmech OpenFOAM Meshing & Mesh Conversion 0 April 21, 2010 03:41
GambitToFoam segmentation fault hoerl OpenFOAM Installation 3 November 20, 2006 05:47
