[Technical] Convert mesh
Old   March 16, 2009, 19:00
Default Convert mesh
Ulisses
ulisses is on a distinguished road
Hello everyone,
I am a new user in OpenFoam and Salome and I'm having some problems. I'm not so sure, but I think that the unit of length in OpenFoam is meter while in Salome is milimeter (if someone could confirm this to me I'd be grateful).
So I'd like to know if when I use the command "ideasUnvToFoam" to convert the mesh if it's still necessary after this to use the command " transformPoints . . -scale '(0.001 0.001 0.001)'" to convert the units of the Salome to the units of OpenFoam.
Grateful for the help
Ulisses
ulisses is offline   Reply With Quote
Old   March 17, 2009, 00:00
Default check using paraview
Prapanch Nair
prapanj is on a distinguished road
Hi ,
Open you files with paraview, in the properties section you can see the X, Y and Z bounds of the geometry. Check if the size has changed after you used the converter. I haven't used Salome, but an intuitively I feel that the converter wouldn't change the units of measure.
Hope this helps
Prapanj
prapanj is offline   Reply With Quote
Old   March 17, 2009, 04:07
Mattijs Janssens
mattijs is on a distinguished road
The ideasUnvToFoam actually reads the scale factor from the unv file so if Salome writes it it should work. Check the output of the converter for
Unit factors:
Length scale : dddd
mattijs is offline   Reply With Quote
Old   March 17, 2009, 15:28
Ulisses
Unit factors:
Length scale : dddd
But how can I do it? What command control should I use?
Thanks for help.
Old   March 17, 2009, 20:46
Ahmed
Ahmed is on a distinguished road
salome does not use units, the length scale is extracted from the physical properties assigned to the geometry by the solver used, so as long as you use a consistent system of units for the properties you do not have to worry about the length unit.
Bear in mind that Salome is designed to mainly provide pre and post processing for code aster and code saturne. So I am curious to know the results of what you are doing, say, I am trying to use Salome to be the front end for OpenFoam.
Good luck and keep us informed
Ahmed is offline   Reply With Quote
Old   March 18, 2009, 12:58
Ulisses
Hi Ahmed,
I verified what you said about the units in Salome using the tip that prapanj posted.
I am using Salome to generate a geometry and a mesh of a gate valve. I learned how to generate a mesh in the Salome and export it to OpenFoam in this site:
http://www.caelinux.org/wiki/index.php/Doc:CAETutorials
But the command in OpenFoam-1.4.1 "ideasUnvToFoam" that is used to import a mesh has a bug. You'll find the correction in:
http://www.cfd-online.com/Forums/ope...g-amp-fix.html
So far I got good results with the Salome and OpenFoam.
Thanks for the answer.
Old   March 18, 2009, 19:10
Thumbs up
Ahmed
Thanks for the information. Yes, the caelinux.org/com is the main source of free tutorials about Salome/aster/saturn
Good Luck
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ANSYS Meshing] Convert a Nastran mesh (.bdf) to Fluent mesh (.msh) dynlevirus ANSYS Meshing & Geometry 1 August 27, 2012 04:06
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
