[Salome] Salome Geometry question (Pipe with certain wall thickness)
Old   April 1, 2009, 06:51
Default Salome Geometry question (Pipe with certain wall thickness)
Hectux is on a distinguished road
I hope I am in the right Forum.
I am just trying to create a pipe with Salome.
I have manged to create a pipe with zero wall thickness with the pipe extrusion (extrusion along a path) tool with a circle and a vector.
my problem is: I need a pipe with a certain wall thickness.
I have tried it with 2 vectors from which one showed in the direction of the wall. But with no success. Could someone help me? Because I have still problems opening the help files.
Best regards
Hectux is offline   Reply With Quote
Old   April 8, 2009, 06:44
Problem solved
in k-epsilon wall function approach high Re turbulence models: question of velocity romant OpenFOAM Programming & Development 6 May 26, 2016 09:14
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
