[Gmsh] Compiling gmshFoam with OpenFOAM-1.5
Old   June 18, 2009, 06:47
Default Compiling gmshFoam with OpenFOAM-1.5
BlGene is on a distinguished road
I encountered a buch of problems when trying to compile gmshFoam with openfoam-1.5, in order to get gmsh2ToFoam. Before I try anything experimental like changing makefiles I wanted to inquire if gmshFoam is compatible with openfoam-1.5.
This is the compile error I get (below). It seems to be looking for a buncg of lnInclude files that don't exist in /usr/lib/OpenFOAM/OpenFOAM-1.5/src.
OStringStream.H, messageStream.H, error.H do exist but the compiler is not finding them.
+ wmake libso libgmshMessageStream
SOURCE=gmshMessageStream.C ;  g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3  -DNoRepository -ftemplate-depth-40  -IlnInclude -I. -I/usr/lib/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/usr/lib/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc/gmshMessageStream.o
In file included from gmshMessageStream.C:30:
gmshMessageStream.H:41:27: error: OStringStream.H: No such file or directory
gmshMessageStream.H:42:27: error: messageStream.H: No such file or directory
gmshMessageStream.C:31:19: error: error.H: No such file or directory
gmshMessageStream.H: In member function 'Foam::gmshMessageStream& Foam::gmshMessageStream::operator<<(T)':
gmshMessageStream.H:90: error: 'OStringStream' was not declared in this scope
gmshMessageStream.H:90: error: expected `;' before 'os'
gmshMessageStream.H:90: error: 'os' was not declared in this scope
gmshMessageStream.C: In function 'Foam::gmshMessageStream& Foam::endl(Foam::gmshMessageStream&)':
gmshMessageStream.C:61: error: 'Info' was not declared in this scope
gmshMessageStream.C:64: error: 'Warning' was not declared in this scope
gmshMessageStream.C:67: error: 'SeriousError' was not declared in this scope
gmshMessageStream.C:70: error: 'FatalError' was not declared in this scope
make: *** [Make/linux64Gcc/gmshMessageStream.o] Error 1
BlGene is offline   Reply With Quote
Old   June 18, 2009, 10:03
Takuya OSHIMA
7islands is on a distinguished road
Hi BlGene,
It should be if you checked out from the svn repository. Do other OF user libraries compile on your installation?
Takuya
7islands is offline   Reply With Quote
Old   June 18, 2009, 12:36
I have a svn checkout. I haven't tried to install any other OF user libraries, which ones should I try to install? One possibility might be that the gentoo package manager that I am using is removing the lnInclude files that the makefile is looking for.
Old   June 19, 2009, 10:22
Takuya OSHIMA
Yes the possibly missing lnInclude directories are where I'm suspecting, if you really installed OF under /usr/lib/OpenFOAM/OpenFOAM-1.5. For trying out, any user libraries floating around on this forum or on the Wiki should be OK (e.g. groovyBC).
Takuya
Old   July 28, 2009, 19:26
Default Something is missing I think?
Rickard Hidefjäll
SkunkWorks is on a distinguished road
Hi then I try to compile gmshFoam with ./Allwmake
It stops after a while.
It looks like this at the end
__________________________________________________ _____________________
SOURCE=gmshViews/gmshViews.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/dynamicMesh/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I../libgmshMessageStream/lnInclude -I.. -DWM_PROJECT_VERSION_MAJOR=`echo 1.5 | awk 'BEGIN{FS="."}{print $1;}'` -DWM_PROJECT_VERSION_MINOR=`echo 1.5 | awk 'BEGIN{FS="."}{print $2;}'` -DWM_PROJECT_VERSION_PATCH=`echo 1.5 | awk 'BEGIN{FS="."}{if (length($3) > 0) print $3; else print "0";}'` -IlnInclude -I. -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gmshViews.o
/usr/bin/ld: cannot find -lfiniteVolume
collect2: ld returnerade avslutningsstatus 1
make: *** [/home/rickard/OpenFOAM/rickard-1.5/lib/linux64GccDPOpt/libgmshFoam.so] Fel 1
__________________________________________________ ______________________
Any suggestions ?
May be linux64GccDPOpt is corrupt But the check sum is gone according to todays relies om OF 1.6. Is it possible to compile th 1.6. ?
/ Rickard
SkunkWorks is offline   Reply With Quote
Old   July 28, 2009, 20:28
Takuya OSHIMA
Hi Rickard,
I still haven't done any testing with the 1.6 release. Meanwhile you can try downloading the 1.5 realease again from here.
T
Old   July 29, 2009, 09:16
Default Reloaded files And with 64 bit support. (I've got Core2 duo)
Rickard Hidefjäll
Hi And thanks a lot!
I still have problem. It starts with;
__________________________________________________ ______________________________
rickard@SkunkWorks:~/OpenFOAM/OpenFOAM-1.5/applications/utilities/gmshFoam$ ./Allwmake
Making dependency list for source file gmshMessageStream.C
SOURCE=gmshMessageStream.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gmshMessageStream.o
'/home/rickard/OpenFOAM/rickard-1.5/lib/linux64GccDPOpt/libgmshMessageStream.so' is up to date.
+ wmake libso libgmshFoam
Making dependency list for source file gmshMesh/gmshMeshFormat.C
Making dependency list for source file gmshMesh/gmshPhysicalNames.C
Making dependency list for source file gmshMesh/gmshNodes.C
could not open file Map.hh for source file gmshMesh/gmshNodes.C
Making dependency list for source file gmshMesh/gmshElements.C
Making dependency list for source file gmshMesh/gmshMesh.C
could not open file Map.hh for source file gmshMesh/gmshMesh.C
Making dependency list for source file gmshToPolyMesh/gmshToPolyMesh.C
could not open file Time.hh for source file gmshToPolyMesh/gmshToPolyMesh.C
could not open file Map.hh for source file gmshToPolyMesh/gmshToPolyMesh.C
Making dependency list for source file polyMeshConversion/polyMeshConversion.C
could not open file Time.hh for source file polyMeshConversion/polyMeshConversion.C
Making dependency list for source file polyMeshToGmsh/polyMeshToGmsh.C
could not open file Time.hh for source file polyMeshToGmsh/polyMeshToGmsh.C
Making dependency list for source file gmshViews/gmshViewBase.C
could not open file Time.hh for source file gmshViews/gmshViewBase.C
Making dependency list for source file gmshViews/gmshViewPointMesh.C
could not open file Time.hh for source file gmshViews/gmshViewPointMesh.C
Making dependency list for source file gmshViews/gmshViewPointMeshMotion.C
could not open file Time.hh for source file gmshViews/gmshViewPointMeshMotion.C
Making dependency list for source file gmshViews/gmshViewSurfaceMesh.C
could not open file Time.hh for source file gmshViews/gmshViewSurfaceMesh.C
Making dependency list for source file gmshViews/gmshViewSurfaceMeshMotion.C
could not open file Time.hh for source file gmshViews/gmshViewSurfaceMeshMotion.C
Making dependency list for source file gmshViews/gmshViewVolMesh.C
could not open file Time.hh for source file gmshViews/gmshViewVolMesh.C
Making dependency list for source file gmshViews/gmshViewVolMeshMotion.C
could not open file Time.hh for source file gmshViews/gmshViewVolMeshMotion.C
Making dependency list for source file gmshViews/gmshViews.C
could not open file Time.hh for source file gmshViews/gmshViews.C
SOURCE=gmshMesh/gmshMeshFormat.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/dynamicMesh/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I../libgmshMessageStream/lnInclude -I.. -DWM_PROJECT_VERSION_MAJOR=`echo 1.5 | awk 'BEGIN{FS="."}{print $1;}'` -DWM_PROJECT_VERSION_MINOR=`echo 1.5 | awk 'BEGIN{FS="."}{print $2;}'` -DWM_PROJECT_VERSION_PATCH=`echo 1.5 | awk 'BEGIN{FS="."}{if (length($3) > 0) print $3; else print "0";}'` -IlnInclude -I. -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gmshMeshFormat.o
And ends up :
'/home/rickard/OpenFOAM/rickard-1.5/lib/linux64GccDPOpt/libgmshFoam.so' is up to date.
+ wmake gmsh2ToFoam
Making dependency list for source file gmsh2ToFoam.C
could not open file Time.hh for source file gmsh2ToFoam.C
could not open file Map.hh for source file gmsh2ToFoam.C
SOURCE=gmsh2ToFoam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I../libgmshFoam/lnInclude -I../libgmshMessageStream/lnInclude -I.. -DWM_PROJECT_VERSION_MAJOR=`echo 1.5 | awk 'BEGIN{FS="."}{print $1;}'` -DWM_PROJECT_VERSION_MINOR=`echo 1.5 | awk 'BEGIN{FS="."}{print $2;}'` -DWM_PROJECT_VERSION_PATCH=`echo 1.5 | awk 'BEGIN{FS="."}{if (length($3) > 0) print $3; else print "0";}'` -IlnInclude -I. -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gmsh2ToFoam.o
gmsh2ToFoam.C: In function "void runGmsh(const Foam::fileName&, const Foam::argList&, Foam::label)":
gmsh2ToFoam.C:83: varning: jämföreslse mellan heltalsuttryck med och utan tecken
gmsh2ToFoam.C:102: varning: användning av gammaldags typkonvertering
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I../libgmshFoam/lnInclude -I../libgmshMessageStream/lnInclude -I.. -DWM_PROJECT_VERSION_MAJOR=`echo 1.5 | awk 'BEGIN{FS="."}{print $1;}'` -DWM_PROJECT_VERSION_MINOR=`echo 1.5 | awk 'BEGIN{FS="."}{print $2;}'` -DWM_PROJECT_VERSION_PATCH=`echo 1.5 | awk 'BEGIN{FS="."}{if (length($3) > 0) print $3; else print "0";}'` -IlnInclude -I. -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/rickard/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/gmsh2ToFoam.o -L/home/rickard/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt \
-ldynamicMesh -L/home/rickard/OpenFOAM/rickard-1.5/lib/linux64GccDPOpt -lgmshFoam -lgmshMessageStream -lOpenFOAM -liberty -ldl -lm -o /home/rickard/OpenFOAM/rickard-1.5/applications/bin/linux64GccDPOpt/gmsh2ToFoam
/usr/bin/ld: cannot find -liberty
make: *** [/home/rickard/OpenFOAM/rickard-1.5/applications/bin/linux64GccDPOpt/gmsh2ToFoam] Fel 1
I've got Swedish support in the prompt.
The first line says warning : compare between integer with and without sign
The second and third says :warning : use of old type converting. casting I think.
Any new suggestions ?
Regards / Rickard
Old   July 29, 2009, 09:26
Takuya OSHIMA
You need libiberty. IIRC it's in binutils-devel (the exact name depends on your distro).
T
Old   August 5, 2009, 06:49
bigred's Avatar
Matthew Philpott
bigred is on a distinguished road
which is the latest version of gmshFoam and from where is it available for download? I would like to use it to simplify meshing of more complicated models. Thanks.
bigred is offline   Reply With Quote
Old   August 6, 2009, 04:03
Takuya OSHIMA
Hi Matthew,
Please try
svn co https://of-interfaces.svn.sourceforge.net/svnroot/of-interfaces/trunk/gmshFoam
Takuya
Old   August 6, 2009, 04:26
bigred's Avatar
Matthew Philpott
Thanks Takuya,
i'll give it a try this evening. I've been having problems get gmsh to work stably on my laptop though. I think it has something to do with the Via chipset and the S3 graphics not really being supported by ubuntu (or actually via not supporting ubuntu )
CAELinux 2009 + OF1.5
Ubuntu 9.04 x64 (jaunty jackalope) + OF1.6
gmsh2tofoam
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer wildfire230 OpenFOAM Installation 20 May 6, 2020 07:30
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
[swak4Foam] Difficulties compiling with OpenFOAM v5.0 MauricioReis OpenFOAM Community Contributions 19 October 16, 2019 00:58
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
Others library application for OpenFoam 1.5 in Windows lcnmy OpenFOAM Installation 2 July 21, 2010 20:54
