[Commercial meshers] Internal patches with fluentMeshToFoam
Old   October 27, 2008, 15:33
Default Internal patches with fluentMeshToFoam
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
Due to a radius in one of my computational domains I forced an element-change in the surrounding of the radius. I used tetrahedron-elements to model the radius and used hexahedron-elements at the rest.
At the intersection of the two element-areas I had to define some faces in GAMBIT to make the distinction between the two areas possible.
Have a look at the image. I have marked the patches of concern.
How can I tread these internal patches in OpenFOAM?
Unfortunately OpenFOAM does not recognize the mesh as 2D or 3D. Maybe this is due to difficulties with the empty BC's I used for these internal patches ...
Do you have any ideas?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   October 28, 2008, 06:56
Default Hi Sebastian! You're trying
Assistant Moderator
Bernhard Gschaider
Hi Sebastian!
You're trying to employ the axial-symmetry of your case? In that case
1. make a 2D-mesh (with rectangles and triangles)
2. convert it to OF (the elements become bricks and prisms)
3. Use http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh to make an axialsymmetric mesh
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 28, 2008, 08:26
Default Hello Bernhard. Yes, this i
sega's Avatar
Sebastian Gatzka
Hello Bernhard.
Yes, this is exactly what I want to do!
This sounds like a very good idea.
I will try this at once.
I created the first mesh in GAMBIT with three different volumes I did not connect.
May this be a problem regarding the internal patches?
(Just in case I have to go back to the first approach ...)
Old   October 28, 2008, 09:15
Default So, back again - so soon ... :
sega's Avatar
Sebastian Gatzka
So, back again - so soon ... :-(
I have done as suggested by Bernhard.
I created the 2D-geometry with GAMBIT, converted to OpenFOAM (fluentMeshToFoam) and used the MakeAxialMesh tool.
When running the paraFoam I get this message:
FOAM FATAL ERROR : wedge frontAndBackPlanes plane aligns with a coordinate plane.
So, I think there went something wrong with collapseEdge, which I used with arguments 0 180.
But I'm not sure what they mean ...
Want to have a look at the case?
Here it is:
http://www.familie-gatzka.de/sega/DO...AxiMesh.tar.gz
Thanks!
Old   October 28, 2008, 10:59
Default Hi Sebastian! I can't repro
Assistant Moderator
Bernhard Gschaider
Hi Sebastian!
I can't reproduce your problem because the tar-file is corrupted (when extracting I only get a partial copy of the msh-file). Mesh-utilities write the resulting mesh to the NEXT time-step. Are you sure you copied everything from 1e-6/polyMesh to constant/polyMesh before proceeding to the next step?
Bernhard
Old   October 28, 2008, 11:16
Default Hi Bernhard. Well, I did NO
sega's Avatar
Sebastian Gatzka
Hi Bernhard.
Well, I did NOT copy the resulting mesh.
I actually wondered what the additional timestep directory was used for ...
(Maybe you should mention it in your usage wiki ... just for the beginner)
Will try it later.
Thanks so far!
Old   October 28, 2008, 12:28
Default Well, maybe you could modify t
Assistant Moderator
Bernhard Gschaider
Well, maybe you could modify the Wiki-page accordingly ....
Old   October 29, 2008, 02:14
Default Hello, again. I still have
sega's Avatar
Sebastian Gatzka
Hello, again.
I still have some questions regarding this problem.
After running the makeAxialMesh tool, there are the frontAndBackPatches and two other patches frontAndBackPatches_pos and ..._neg.
To get rid of them is to use the collapseEdge tool?
So, I copied the new mesh into the constant directory and used collapseEdge.
But what arguements should I use?
In the usage wiki you say something like this:
For an application like this, you would want to use collapseEdges with a very small length scale argument and an angle argument near 180 degrees
What is the length scale argument?
The length of the whole edge?
And what is the 180 degrees good for?
Especially if I want an angle of 2.5 degrees?
Hope you can help me.
Thanks so far & have a nice day.
Old   October 29, 2008, 06:45
Default The collapseEdges-utility remo
Assistant Moderator
Bernhard Gschaider
The collapseEdges-utility removes edges that are ridiculously small. Like the edges on the "axis" patch.
Concerning the arguments: type "collapseEdges -h" and you will be enlightened
frontAndBackPatches are the "old" patches. If you look at the new boundary-file the sizhe of that is 0 after makeAxialMesh because all those faces either go to frontAndBackPatches_pos/neg. You'll have to add those patches to the boundaries in the field-file
Old   October 29, 2008, 07:37
Default Ok, Thank you Bernhard. Now,
sega's Avatar
Sebastian Gatzka
Now, I got it regarding the frontAndBackPatches_pos/neg.
I created new BC for the positive and negatice wedge faces and deleted the old entry.
The mesh looks good, but still I can't get the meaning of collapseEdges.
Running the collapseEdges -h gives me the familiar output:
Usage: collapseEdges <root> <case> <edge> <merge>
--> FOAM FATAL ERROR : Wrong number of arguments, expected 4 found 0
Invalid option: -h
But I'm still not enlighted.
Using the collapseEdge like "collapseEdge . . 30e-3 5" (30e-3 is the length of domain) gives a whole crowd of messages like this:
Cell:2516 uses faces:6(4975 38275 41439 60756 4498 4973) of which too many are marked for removal:
and at the end:
Morphing ...
Collapsing 0 small edges
Collapsing 0 in line edges
Max face area:0.896123
Collapse area factor:1e-09
Collapse area:8.96123e-10
Collapsing 0 small high aspect ratio faces
Writing collapsed mesh to time 1e-06
End
Now I can use the funkySetFields to initialize my two phase problem and started to calculate with interFoam.
Strange to me, the simulation is running FAR to fast, but the interface is not moving at all.
I know the physical behavious from a similar case.
So, the mesh "looks" good but due to the fact that the interface is not moving I think there is still something wrong.
If you want to have a look.
This time the file should not be corrupt:
http://therealsega.th.funpic.de/open...AxiMesh.tar.gz
Old   October 28, 2009, 11:51
Florian Krause
florian_krause is on a distinguished road
Hi guys,
I want to re-open the discussion between Sebastian and Bernhard. I am using makeAxialMesh with some slight modifications to be able to compile it under my OF-1.6.x.
makeAxialMesh -axis ... -wedge ... -> runs without problems, grid look fine
collapseEdges 0.001 170 -> runs without problem, I got the following output
Create time
Create polyMesh for time = 0
Merging:
edges with length less than 0.001 meters
edges split by a point with edges in line to within 170 degrees
Collapsing 101 small edges
Morphing ...
Max face area:0.00250237718349
Collapse area:2.50237718349e-12
Writing collapsed mesh to time 0.05
End
when I run the checkMesh on the new grid with the collapsed edges I get the following output
Mesh stats
internal points: 0
faces: 4010
internal faces: 1890
cells: 1000
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 900
prisms: 100
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
frontAndBackPlane 0 0 ok (empty)
InOutlet 20 42 ok (non-closed singly connected)
center 0 0 ok (empty)
pipe_wall 100 202 ok (non-closed singly connected)
frontAndBackPlane_pos1000 1111 ok (non-closed singly connected)
frontAndBackPlane_neg1000 1111 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (0 0 4.03063173324e-05) (5 0.5 0.0436596936827)
Mesh (non-empty, non-wedge) directions (1 1 0)
Mesh (non-empty) directions (1 1 1)
***Number of edges not aligned with or perpendicular to non-empty directions: 2020
<<Writing 2121 points on non-aligned edges to set nonAlignedEdges
Boundary openness (5.05184045313e-19 -8.16550549354e-16 -5.37567505446e-16) OK.
Max cell openness = 1.65706464942e-16 OK.
Max aspect ratio = 22.9255856257 OK.
Minumum face area = 0.000109048468415. Maximum face area = 0.00250237718349. Face area magnitudes OK.
Min volume = 5.45242342075e-06. Max volume = 0.000103596044993. Total volume = 0.0545242342067. Cell volumes OK.
Mesh non-orthogonality Max: 0 average: 0
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.330801283002 OK.
Failed 1 mesh checks.
so somehow it seems that the collapseEdges didnt work properly with my options on my case. Or is this another problem?! Any ideas?
cheers,
Florian
florian_krause is offline   Reply With Quote
Old   October 28, 2009, 16:01
Assistant Moderator
Bernhard Gschaider
Re-open: I realized I never answered to Sebastians last post. But I guess the problem went away in the mean-time
<snip>
checkMesh for the mesh after makeAxialMesh showed no such problems? Then try using the mesh without collapsing and set the axis boundary to symmetry (or zeroGradient)
Old   October 29, 2009, 08:11
Florian Krause
Hi Bernhard,
I did a checkMesh on the grid and here is the output
Mesh stats
internal points: 0
faces: 4110
cells: 1000
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 1000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Point usage OK.
Face vertices OK.
InOutlet 20 44 ok (non-closed singly connected)
center 100 202 ok (non-closed singly connected)
<<Writing 2222 points on non-aligned edges to set nonAlignedEdges
Boundary openness (5.07768106926e-19 -8.16550549354e-16 -5.37567505446e-16) OK.
***Zero or negative face area detected. Minimum area: 0
<<Writing 100 zero area faces to set zeroAreaFaces
Min volume = 7.47743760209e-06. Max volume = 0.000103596044993. Total volume = 0.0561517870683. Cell volumes OK.
Mesh non-orthogonality Max: 76.4964690725 average: 12.7337115278
*Number of severely non-orthogonal faces: 32.
<<Writing 32 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 83 faces are incorrectly oriented.
<<Writing 83 faces with incorrect orientation to set wrongOrientedFaces
***Max skewness = 7.40663060245, 84 highly skew faces detected which may impair the quality of the results
<<Writing 84 skew faces to set skewFaces
Failed 4 mesh checks.
I am not sure about the first error message, for the second I guess its just collapsed faces from the axis patch, the third one I am again not sure about it, and the last one i guess is just that i have needle-like volumes.
so I guess I have to use collapseEdges, just with the proper option settings....
I attached the original polyMesh directory after I converted from fluent .cas to OF format. If you would have a minute to have a look at it, would be really nice and helpful,.... maybe there is something wrong with the original grid
thanks and best,
Florian
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 08:19
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
How to handle internal patches for p,T,U monsoon OpenFOAM 16 March 22, 2013 15:00
