[mesh manipulation] How does one create a patch on a complex geomtry?
Old   September 24, 2009, 05:13
Default How does one create a patch on a complex geomtry?
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Is there some tool or method of defining patches on my geometry?
autoPatch doesn't gives me the right patches as the patches I want to define are not easily recognisable using different angles in autoPatch.
I've searched through the forum and found that 'patchTool' was in version 1.4, and seems to be what I'm looking for, but since it seems to have been discontinued, is there some other newer tool/utility that will do the job?
Or should I just try get patchTool working on 1.4?
How do other people define patches on complex geometries?
Any suggestions are most welcome,
Philip
bigphil is offline   Reply With Quote
Old   October 9, 2009, 07:40
bigphil's Avatar
Philip Cardiff
For anyone else who has the same sort of problem,
I found that patchTool in OF-1.4-dev and earlier does the job, even if it's a bit tedious for finer meshes.
Philip
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 36 January 7, 2015 00:31
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[mesh manipulation] Using createPatch in place of couplePatches sripplinger OpenFOAM Meshing & Mesh Conversion 8 November 13, 2009 07:14
