[Commercial meshers] How To Use OpenFOAM Software To Calculate Pump?
Old   August 27, 2009, 05:34
Default How To Use OpenFOAM Software To Calculate Pump?
任芸
renyun0511 is on a distinguished road
hi all,
i am a new OpenFOAM user, several days ago ,i installed the OpenFOAM software(1.5 version) .now,i try to simulate internal flow filed of a pump by OpenFOAM,the problem puzzled me is that : i don't know how to use the sofeware?
first,i built the geometry in PRO/E.
then, i meshed it in Gambit,and exported the mesh to an .msh file.
the first problem is that i don't know which solver do i choose? and then how to operate it?
could someone help me? thanks a lot!
renyun0511 is offline   Reply With Quote
Old   August 28, 2009, 02:51
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
First thing to do would be to read the manual.
When that is done look at some of the tutorials (there are a lot).
If that doesn't help you look at www.openfoamwiki.net
The solver choice depends solely on what kind of physical problem you are solving. For steady flow in a pump I would look at simpleFoam or MRFsimpleFoam, use the search function to find info.
If you are new to CFD I suggest you buy and read:
http://www.ercoftac.org/index.php?id=77
The following which is free, although aimed at marine it has some very good guidelines when using CFD.
https://pronet.wsatkins.co.uk/marnet...ations/bpg.pdf
Best Regards
Linnemann
linnemann is offline   Reply With Quote
Old   August 28, 2009, 03:59
任芸
I did the .msh file in fluent,now,i'm try to do it in OpenFOAM.I don't know how to do in it?for example,how to set the parameter of inlet velocity and rotatioan rate?which values will be setted and which elements can be ingnored? which puzzled me a lot!
thanks all the same!
Old   August 28, 2009, 14:13
Yingfeng Shen
yingfeng is on a distinguished road
It is good idea to through the tutorial case first. In general you probably need to do the following:
1. import mesh into OpenFOAM. If the boundary conditions are lost, use autoPatch to find the patches. After that, paraFoam can show you which patch is where. checkMesh is a good tool to evaluate your mesh.
2. look at the case folder, 0/ folder is where you set boundary condition for each field, for example, U and p. The best way currently is to manually edit boundary condition for each patch; system/ folder is where you choose the schemes and solver parameters. constant/ folder is where you set physical properties.
3. run your solver. You can always monitor your result with paraFoam
Good luck!
Yingfeng
yingfeng is offline   Reply With Quote
Old   August 30, 2009, 22:50
任芸
Thank you very much! now,i try to use MRFSimpleFoam solver,when i open the mixerVessel2D/ foders,i just see the rotor,the stator,the back and the front,i know they are not what i want ,but i don't know how to modify them.I'm not understand the information in these folder
divergence problems in simulating pump using OpenFOAM Alisa_W OpenFOAM 6 May 28, 2017 09:20
ERCOFTAC centrifugal pump case study with OpenFOAM extend 3.2 saleriCAE OpenFOAM 0 March 8, 2017 05:16
Solvers to be used for Simulating Centrifugal pump in OpenFoam coolcrasher OpenFOAM Running, Solving & CFD 7 September 4, 2015 08:51
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 09:12
Compare 2D axi-symmetric and 3D. Is OpenFOAM calculate the velocity wrong? RalphS OpenFOAM 6 November 13, 2010 20:51
