[mesh manipulation] polyDualMesh and volume calculation...
Old   September 10, 2009, 13:37
Default polyDualMesh and volume calculation...
jbf
jb
jbf is on a distinguished road
I have simulated the flow of a liquid that escapes from a container. I used the 'interFoam' solver. I generated the thetrahedral mesh with gmsh, then I converted it with the polyDualMesh utility. The so obtained mesh is funny to use : it increases the calculation speed and reduces the courant number. In my simulation, the liquid flows against a wall and a part of it passes above this wall, and finaly reaches an other container. I have to calculate the volume of liquid that passed above the wall. I thus use the 'integrate variables' filter of paraview in order to integrate the gamma-field in a definite region.
My problem is the following : the 'integrate variables' filter returns an absurd (and negative) volume !!! (but it works well on the initial thetrahedral mesh)... Please, do you know a methods (software), that can calculate the correct volume on this kind of mesh (onbtained with polyDualMesh) ???
Any answer is welcomed...
JB
jbf is offline   Reply With Quote
Old   September 14, 2009, 14:41
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Did your checkMesh report some strangeness on the poly mesh?
I ask because I've been in the same situation and checkMesh on the tet mesh is just fine but after running polyDualMesh the checkMesh reports with errors that cells have negative volume.
In a post I've read Hrv Jasak states that polyDualMesh only works for delaunay tet meshes. The errors mostly occurs in cells in areas with sharp corners.
read 1 (page 2 especially)
read 2
linnemann is offline   Reply With Quote
Old   September 15, 2009, 18:37
jbf
jb
Hi Linnemann,
Your are right : polyDualMesh seems to work for Delaunay thetrahedral mesh. Actually, I use 'gmsh' to generate this kind of mesh (+ Netgen optimization). The 'checkMesh' utility does not return any errors about the cell volume in my case, but il crashes (seg fault) just after having said : 'Mesh is OK'. I think my problem does not come from the mesh itself, but from paraview. Indeed, (it seems that) OpenFoam works fine on this mesh. But the integration of the gamma field with paraview fails... I am very embarassed, because I did a lot of calculations on this kind of mesh (obtained with polyDualMesh), but I can't calculate the volume of fluid in a specific region... Do you think however all my calculations could be wrong because of bad cells generated by polyDualMesh ?
JB
Originally Posted by linnemann View Post
Hi
read 2
[mesh manipulation] problem using polyDualMesh Rebecca513 OpenFOAM Meshing & Mesh Conversion 10 March 4, 2020 12:53
polydualmesh and ability to do DNS manuc OpenFOAM Pre-Processing 0 June 14, 2016 02:22
[mesh manipulation] polydualmesh and ability to do DNS manuc OpenFOAM Meshing & Mesh Conversion 1 June 14, 2016 02:20
on volume elements and polyDualMesh ramcdougal OpenFOAM Running, Solving & CFD 2 February 22, 2012 08:09
Problems on Tetrahedra to Polyhedra using polyDualMesh on concave surface object chnrdu OpenFOAM Pre-Processing 2 July 18, 2009 12:58
