[snappyHexMesh] what is the possible problem
Old   July 19, 2014, 21:40
Default what is the possible problem
xurenyi
xurenyi is on a distinguished road
I designed a cube box as background grid, and a surface(.stl ) to slice this box.
type
blockMesh
snappyHexMesh
succeed!
and then type paraFoam
the cube box unsliced is shown in the window.
locationInMesh in snappyHexMeshDict is confirmed correct.
If I change the area of refinement parameter in snappyHexmeshDict, it does work.
Why the .stl file didn't work? what is the possible problem?
xurenyi is offline   Reply With Quote
Old   August 11, 2014, 09:57
cutter is on a distinguished road
just an idea:
The meshers blockMesh and snappyHexMesh write each intermediate mesh of the meshing process to a different time directory (0 or constant for block mesh, 1 for castellated mesh, 2 for snapped mesh and maybe 3 for mesh with boundary layers).
Assuming the meshing process succeeded, you might need to skip to the last time step in paraFoam in order to see the final mesh (button 'Last Frame' in toolbar 'VCR Controls').
You may also use 'snappyHexMesh -overwrite' in order to write all meshes into into a single time step directory.
Good Luck!
cutter is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
