[Other] What error is this?
Old   March 4, 2010, 04:16
Default What error is this?
Calobra's Avatar
Ruben Wetind
Calobra is on a distinguished road
I tried to blockMesh a geometry based om the motorcycle_tut.
Strange message came. ACtually the same error came when I tried to run foamToVTK on another case. Seems to be related to the C reader???
Suggestions?
ruben@ruben-desktop:~/OpenFOAM/ruben-1.6.x/run/torus/constant/triSurface$ blockMesh
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x-06b0cd81604d
Exec : blockMesh
Date : Mar 04 2010
Time : 10:09:09
Host : ruben-desktop
PID : 5406
Case : /home/ruben/OpenFOAM/ruben-1.6.x/run/torus/constant/triSurface
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/ruben/OpenFOAM/ruben-1.6.x/run/torus/constant/triSurface/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
Calobra is offline   Reply With Quote
Old   March 4, 2010, 04:20
Default top level
romant's Avatar
Roman Thiele
romant is on a distinguished road
you have to go into the top location of your case
cd ~/OpenFOAM/ruben-1.6.x/run/torus
and then run
blockMesh
~roman
romant is offline   Reply With Quote
Old   March 4, 2010, 04:23
Calobra's Avatar
Ruben Wetind
of course---- my error
thanks a lot
