[Salome] mesh conversion Salome --> OpenFoam
Like Tree2Likes
Old   May 2, 2011, 12:32
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
hi,
i am using sHM just for complex geometrys with good results.
never meshed in Salome befor ... the tutorials ? thats a good idea, where did i get those tutorials ?
regards tobi,...
PS: sure, you get 3D-geometrys but if you got just one cell in the z-direction you can use the empty patch, ... but i know what you wanna say to me
I 've found the tutorials - thx for that advice
Tobi is offline   Reply With Quote
Old   May 2, 2011, 12:43
vaina74 is on a distinguished road
I linked the tutorials I refer to in the previous post. OK, you know empty patches, but you didn't create an appropriate 3D mesh in SALOME. For your purposes, you must apply a 3D algorithm on a solid or generate a 2D mesh and then extrude it. Otherwise you can't convert anything.
vaina74 is offline   Reply With Quote
Old   May 2, 2011, 12:56
Tobi's Avatar
Tobias Holzmann
okay thx.
i always using Catia V5 and convert it to an STL ... split it into the boundarys in Salome and mesh it with sHM. So thx for your advice. I wll have a look at the tutorials.
nice evening,
tobi
Old   May 2, 2011, 13:51
Tobi's Avatar
Tobias Holzmann
Hi,..
now its working. I did something wrong in the meshing tool in Salome
thx to you.
Tobi
Old   May 11, 2012, 14:58
Question
  #25
Tomislav Maric
tomislav_maric is on a distinguished road
Originally Posted by Tobi View Post
Hi,..
thx to you.
Tobi
What exactly did you do wrong, I'm seeing the same thing. The .hdf is attached. I've tried meshing a NACA0015 airfoil in 2D like this:
Geometry creation:
#G1 In geometry module it is possible to define the airfoil via polynomial equations:
New entity - Basic - Curve - Analytical
and then enter the polynomial for the NACA00xx like the one described here:
http://en.wikipedia.org/wiki/NACA_airfoil
This creates the single side of the NACA00xx profile, the other side you can mirror, or multiply the polynomial with -1.
#G2 From the two polynomial curves, create a wire.
#G3 From the wire, create a face.
#G4 Create a circle that encompasses the airfoil face.
#G5 Create a frace from this circle.
#G6 Cut the circle face with the polynomial face to get the basis for the mesh: NACA0015-CircleCut in the .hdf file.
Then I've tried to generate the mesh in 2 ways:
M1 : extrusion of a planar mesh
#M1.1 Mesh NACA0015-CircleCut to create a planar triangular mesh.
#M1.2. Extrude the mesh
#M1.3 Filter based selection of face groups:
There are filters now in the new version of Salome which can be superimposed. They may be based on various criteria (parametric, relationships with other geometry, and similar).
Example of selecting the inletOutlet group using filters:
Mesh -> Create Group -> Filter Based
For a filter, if you select the Geometry to be Quadrangle, and add another filter (plus button to the right with logical AND option for the composition of filters) that states that the faces are Free faces, the result is the ring of quadrangle faces that define the inletOutlet patch.
The empty patches and the airfoil have their own settings, check them out with right click to the group, and edit.
#M1.4 Once this is done (the groups are there, and the mesh is extruded), I export to .unv, and see the same error you had.
M2 Three dimensional extrusion algorithm, on a 3D extruded geometry
#M2.1 This procedure is different from M1 in the fact that extruded geometry is produced first by extruding NACA0015-CircleCut.
#M2.2 Explosion of extruded geometry into faces: unfortunately, with analytical function that represents the polynomial, if it is linear interpolated between the points, this results with like 1000 faces. I've grouped the faces that will be used for quadrangle mapping and triangle meshing.
#M2.3. Create mesh on extruded geometry: 3D Extrusion algorithm
#M2.4 Create submesh: extruded ring (inletOutlet of the previous mesh) is submeshed with Quadrangle (mapping) and no hypothesis is set.
#M2.5 Create submesh: 2D Projection algorithm on two triangle faces (create .hdf)
M2 results in an algorithm faliure. The procedure is explained for a simpler geometry here:
http://www.caelinux.org/wiki/index.p...ELinux_2008.29
Obviously, I'm breaking my back here .... if anyone can tell me where I did a wrong step, it would be great!
I couldn't attach the .hdf because of its size, here is where you can download it:
http://www.2shared.com/file/3Yn6lIHI/NACA0015.html
tomislav_maric is offline   Reply With Quote
Old   May 14, 2012, 12:55
Tobi's Avatar
Tobias Holzmann
hi,
i have had a look at your file and tried a bit. Would you like to have a 2D mesh with hexaedrals? Well I think its not as simple as in ANSYS. I meshed a lot of geometrys with salome using hexaedrals but thats not easy with your geometry couse salome always wants to have "a box with four lines" to create the hexaedrals (like in Ansys cfx mesher)... well, i think you are not able to make a 2D mesh with tetraedrals.
The problem is, that your airfoil has a lot of lines. Every line have to enclose a box with four lines (hope you understand me).
Tobi
Old   May 15, 2012, 07:33
Tomislav Maric
hi,
Tobi
Hi Tobi,
thanks a lot for your advice... I've used an .igs/.brep CAD model of an airfoil, and then the algorithm worked properly... I'll upload the .hdf again as soon as I get to my home PC. It would be great to have a structured NACA0015 airfoil mesh if you can spare one, because of the drag coefficients computation as well...
Thanks again,
Tomislav
Old   May 16, 2012, 02:19
Tobi's Avatar
Tobias Holzmann
ufff i was a bit confused
First of all. If I mention 2D - mesh I mean a 3D mesh with one cell in one directory so you can use empty patches to do like a 2D mesh.
You are creating a planar 2D triangular mesh and then you wanted to extrude it to a 3D mesh using 1 cell in the direction of extrude, right?
I thought you wanna mesh it with hexaedrals only - sorry for miss understanding.
Tobi
Old   May 16, 2012, 05:36
Tomislav Maric
Tobi
Well, actually I do need a 3D mesh with one cell in one direction for a 2D simulation in OpenFOAM.
A hex mesh would be much better than triangular prism (extruded triangles), have you done something like this in Salome?
Old   May 17, 2012, 07:03
Tobi's Avatar
Tobias Holzmann
yes I did it very often,...
Unfortunately I am not on my desk computer and have no hdf file to show you how to mesh with hex. I ll upload one on monday evening!
Tobi
Referencing to salome tutorials: http://www.salome-platform.org/user-...edf-exercise-1
elvis likes this.
Old   November 19, 2012, 04:03
sebastian n
gruenertee is on a distinguished road
First of all, i want to thank everybody who keeps up this forum i am studying mechanical engineering and i try to learn CDF simulation. i created simple construction elements with salome 6.5.0, created a mesh and exported it to a unv file. My problem is that i just can simulate symmetric elements like a t shaped pipe, but once my element is asymmetric nothing happens when i start paraFoam. A Friend of mine told me i should use local coordinates; could that be the mistake? and how to use local coordinates in Salome and mesh it?
Thanks
gruenertee is offline   Reply With Quote
Old   November 19, 2012, 07:16
Tobi's Avatar
Tobias Holzmann
Hi Sebastian and welcome to the forum,
I am not so familiar with the paraview code but in my case every geometrie is working.
Maybe try the following:
1. create a file with the ending *.foam like
touch paraview.foam
2. open paraview with the following command
paraview
and load the file you created befor.
Tobi
Old   November 21, 2012, 06:18
sebastian n
touch paraview.foam
paraview
Tobi
At first i want to thank you for your post; i took notice of your advice but my cfd simulation still does not work. Are you taking a look into my upload files? www.workupload.com/file/9pdHRMR
Old   November 21, 2012, 06:37
Tobi's Avatar
Tobias Holzmann
like your case I think you mean, that you can not visualize your results. You mesh is very coarse but with the right settings its possible to get a solution.
I wrote you an Email.
Tobi
Old   February 21, 2013, 15:42
Roman Gášpár
roman.gaspar is on a distinguished road
Hello foamers...
I have a very similiar problem. But a bit different. I exported the .unv file from salome Im using 6.6. and I create B-C and everything in OF folders. I tried to convert mesh to OF (2.1.1) mesh but I obtained this error code:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : ideasUnvToFoam segmentbc.unv
Date   : Feb 21 2013
Time   : 21:37:20
Host   : "dell"
PID    : 11581
Case   : /home/gaspar/OpenFOAM/gaspar-2.1.1/run/cavity
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM FATAL ERROR:
Cannot open file "segmentbc.unv"
    From function ideasUnvToFoam
    in file ideasUnvToFoam.C at line 673.
FOAM exiting
Had anybody similar or same problem?
Thx for help.
Regards
Roman
roman.gaspar is offline   Reply With Quote
Old   February 22, 2013, 05:58
Tobi's Avatar
Tobias Holzmann
Hi Roman,
like your output told you, OF can not find your file. Is your *.unv file in your case folder?
Old   February 26, 2013, 09:33
Roman Gášpár
Thank you Tobi
I had my .unv file in constant folder...after that I moved it to OF case root folder and now it works...Thank you again
Roman
Old   September 10, 2014, 08:43
Default Same problem to convert
  #38
Himanshu Sharma
himanshu28 is on a distinguished road
Hi Roman,
I am also getting the same problem.
|  \\    /   O peration     | Version:  2.3.0                                 |
Build  : 2.3.0-f5222ca19ce6
Exec   : ideasUnvToFoam UAV_salome.unv
Date   : Sep 10 2014
Time   : 17:42:25
Host   : "mohd-CELSIUS-W510"
PID    : 12849
Case   : /home/mohd/Himanshu/test_1
nProcs : 1
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:"  SI: Meter (newton)"
unitType:2
Unit factors:
    Length scale       : 1
    Force scale        : 1
    Temperature scale  : 1
    Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 1169416 points.
Processing tag:2412
Starting reading cells at line 2338855.
First occurrence of element type 22 for cell 1 at line 2338856
--> FOAM Warning :
    From function readCells(IFstream&, label&)
    in file ideasUnvToFoam.C at line 467
    Reading "UAV_salome.unv" at line 2338856
    Cell type 22 not supported
--> FOAM FATAL IO ERROR:
Attempt to get back from bad stream
file: IStringStream.sourceFile at line 0.
    From function void Istream::getBack(token&)
    in file db/IOstreams/IOstreams/Istream.C at line 56.
FOAM exiting
I am uploading my .hdf file with the https://drive.google.com/file/d/0B0P...it?usp=sharing
Thank you
himanshu28 is offline   Reply With Quote
Old   October 23, 2014, 08:42
Bernhard Linseisen
Linse is on a distinguished road
Just a minor hint, as most of you seem to prefer the unv-method: If you google for salomeToOpenFOAM.py you should find a short python-script which can be started from within Salome and which will export the marked mesh into a complete polyMesh-folder. For me it worked including pyramids as well...
Linse is offline   Reply With Quote
Old   December 21, 2017, 11:39
Default Salome mesh having pyramids to openfoam
  #40
Ashish Kumar
ashish.svm is on a distinguished road
In my salome generated mesh I have some pyramids, but while exporting to UNV format salome ignores pyramid elements. Actually I need those pyramid cells so is there any way by which I can export that mesh to openfoam without removing pyramids?
ashish.svm is offline   Reply With Quote
[Salome] Problems for creating mesh in salome to OPENFOAM bye bye my blue OpenFOAM Meshing & Mesh Conversion 8 December 5, 2023 00:57
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[Commercial meshers] Mesh conversion .gtm to OpenFOAM ansab OpenFOAM Meshing & Mesh Conversion 2 December 6, 2016 13:48
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 17:36
