[snappyHexMesh] snappyHexMesh layers part
Old   April 15, 2010, 11:53
Default snappyHexMesh layers part
Marine
marine is on a distinguished road
hello!
I'm trying to use snappyhexmesh for an external flow around a ship and I don't really understand how the differents functions in addlayerscontrols work. Can someone explain me how I choose the values for finalLayerThickness, expansionRatio and minThickness? I've searched for posts about that on the forum but maybe missed them, if they already exit can you give me the link?
thank you very much!!
Marine
marine is offline   Reply With Quote
Old   April 16, 2010, 05:43
Marine
I have a very high Reynolds, 10^9, and I'd like yplus about 100 wich give me a first mesh size of 1mm (using the online tool y+estimation). I guess I put "minthickness" to this value.
I don't understand why I have to give a value for "finalLayerThickness" if I specify the "minThickness", the "expansionRatio" and the "nsurfaceLayer" I want. Can someone explain me that?
thank you very much.
Marine
Old   April 19, 2010, 04:16
Marine
Does someone know if the "expansionratio" is the ratio between two successives layers or between the furthest and the closest to the surface?
I tried to change it but my cells always have the same size as the ones on my surface (I defined nsurfacelayer = 10).
Old   April 20, 2010, 13:12
Francesco Del Citto
fra76 is on a distinguished road
The layers are controlled by the last element size (with "last" I mean the one far from the surface, close to the volume cells). You specify its desired size, in terms of ratio with the near volume cell, the expansionRatio, which I think is the ratio between the height of two consecutive layer cells, and all the elements are determined in this way. The minThickness is a quality parameter. If snappy can only build layers so that the relative first element height is below the minThickness value, layer extrusion from that face is disabled.
See the comment in the example snappyHexMeshDict:
     //- Minimum thickness of cell layer. If for any reason layer
      //  cannot be above minThickness do not add layer.
      //  See relativeSizes parameter.
      minThickness 0.25;
As far as I know, there's no way of specifying the height of the near-wall cell, neither absolute nor relative.
Hope this helps,
Francesco
fra76 is offline   Reply With Quote
Old   April 22, 2010, 05:30
Marine
Thank you, I'm having a lot of dificulties with the boundary layer, sometimes I only have BL on the interior of my surface and sometimes only on the borders...
Do you know if it's possible to have a boundary layer on a surface with differents refinement levels? I'm trying with 2 differents levels (but not one on the boundaries and one on the middle), that could be the origin of my problem.
bests
Marine
Old   April 25, 2010, 13:51
Francesco Del Citto
Yes, it is.
The transition in layers height above the two refinement levels is a bit too fast, but it works for sure.
Old   April 25, 2010, 14:09
Fabian Braennstroem
braennstroem is on a distinguished road
Hi Franceso,
hope your are doing well! I wonder, if you would recommend to use absolute layer sizes to circumvent the above problem...
Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   April 27, 2010, 07:09
Francesco Del Citto
Hi Fabian!
Good point. Depending on the geometry, this is a good solution.
Francesco
addlayerscontrols, layers, snappyhexmesh
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 08:26
[snappyHexMesh] proble of creating layers with snappyHexMesh comingdaytime OpenFOAM Meshing & Mesh Conversion 3 May 24, 2018 06:18
[snappyHexMesh] snappyHexMesh layers at the corner missing wc34071209 OpenFOAM Meshing & Mesh Conversion 3 February 12, 2014 11:32
[snappyHexMesh] Internal layers in snappyHexMesh onyir OpenFOAM Meshing & Mesh Conversion 0 April 16, 2013 11:00
[snappyHexMesh] snappyHexMesh : Layers on patches Nucleophobe OpenFOAM Meshing & Mesh Conversion 0 October 11, 2012 17:34
