[Other] surfaceCheck problem
Old   May 7, 2010, 04:24
Default surfaceCheck problem
vivien
vivien is on a distinguished road
Hi, All,
I had a very fine mesh in .stl format. I use surfaceCheck in OF and got following errors:
small edge between points 681085 (-30.4527 -3.2288 1662.82) and 681096 (-30.4527 -3.22877 1662.82) distance:3.00407e-05
small edge between points 681598 (-30.6627 -2.85385 1662.82) and 681597 (-30.6627 -2.8538 1662.82) distance:4.98295e-05
small edge between points 681280 (-30.9028 -3.0338 1662.82) and 681279 (-30.9027 -3.0338 1662.82) distance:9.91821e-05
small edge between points 681239 (-30.9177 -3.06383 1662.82) and 681240 (-30.9177 -3.0638 1662.82) distance:2.98023e-05
small edge between points 682270 (-30.3927 -3.1238 1662.84) and 682278 (-30.3927 -3.12375 1662.84) distance:5.00679e-05
small edge between points 683171 (-30.5727 -2.9738 1662.85) and 683184 (-30.5727 -2.97373 1662.85) distance:6.98566e-05
small edge between points 683612 (-30.6777 -2.76388 1662.87) and 683611 (-30.6777 -2.7638 1662.87) distance:8.01086e-05
Found 1821 nearby points.
Surface is not closed since not all edges connected to two faces:
connected to one face : 0
connected to >2 faces : 2537
Conflicting face labels:10148
Dumping conflicting face labels to "problemFaces"
Paste this into the input for surfaceSubset
Number of unconnected parts : 2
Splitting surface into parts ...
writing part 0 size 1371912 to "merge_0.ftr"
writing part 1 size 7338 to "merge_1.ftr"
Anybody has ideas how to correct for that?
Thank you very much in advance!!
Vivien
vivien is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
