May 7, 2010, 04:24 |
surfaceCheck problem
vivien
Hi, All,
I had a very fine mesh in .stl format. I use surfaceCheck in OF and got following errors: small edge between points 681085 (-30.4527 -3.2288 1662.82) and 681096 (-30.4527 -3.22877 1662.82) distance:3.00407e-05 small edge between points 681598 (-30.6627 -2.85385 1662.82) and 681597 (-30.6627 -2.8538 1662.82) distance:4.98295e-05 small edge between points 681280 (-30.9028 -3.0338 1662.82) and 681279 (-30.9027 -3.0338 1662.82) distance:9.91821e-05 small edge between points 681239 (-30.9177 -3.06383 1662.82) and 681240 (-30.9177 -3.0638 1662.82) distance:2.98023e-05 small edge between points 682270 (-30.3927 -3.1238 1662.84) and 682278 (-30.3927 -3.12375 1662.84) distance:5.00679e-05 small edge between points 683171 (-30.5727 -2.9738 1662.85) and 683184 (-30.5727 -2.97373 1662.85) distance:6.98566e-05 small edge between points 683612 (-30.6777 -2.76388 1662.87) and 683611 (-30.6777 -2.7638 1662.87) distance:8.01086e-05 Found 1821 nearby points. Surface is not closed since not all edges connected to two faces: connected to one face : 0 connected to >2 faces : 2537 Conflicting face labels:10148 Dumping conflicting face labels to "problemFaces" Paste this into the input for surfaceSubset Number of unconnected parts : 2 Splitting surface into parts ... writing part 0 size 1371912 to "merge_0.ftr" writing part 1 size 7338 to "merge_1.ftr" Anybody has ideas how to correct for that? Thank you very much in advance!! Vivien |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
