[Gmsh] Where are my Cells ?!
Old   December 10, 2010, 04:56
Default Where are my Cells ?!
Chapury is on a distinguished road
Hay all,
im trying to generate a simple cone-cyl simulation. here is my geo file:
__________________________________________________ ___________
l1 = 0.05;
l2 = 0.01;
n=10;
Point(1) = {-0, -0, 0,l1};
Point(2) = {0.4, -0, 0,l2};
Point(3) = {0.6, 0.1, 0,l2};
Point(4) = {1, 0.1, 0,l2};
Point(5) = {1, 0, 0,l2};
Point(6) = {1.3, -0, 0,l1};
Point(7) = {1.3, 0.4, 0,l1};
Point(8) = {0, 0.4, 0,l1};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 5};
Line(5) = {5, 6};
Line(6) = {6, 7};
Line(7) = {7, 8};
Line(8) = {8, 1};
Line Loop(9) = {7, 8, 1, 2, 3, 4, 5, 6};
Plane Surface(12) = {9};
Extrude {{1, 0, 0}, {0, 0, 0}, Pi/2} {
Surface{12}; Layers {n}; Recombine;
Surface{44}; Layers {n}; Recombine;
Surface{76}; Layers {n}; Recombine;
Surface{108}; Layers {n}; Recombine;
Physical Surface("inflow") = {124, 28, 60, 92, 25, 57, 89, 121, 75, 43, 139, 107};
Physical Surface("wall") = {64, 32, 96, 128, 68, 132, 36, 100, 71, 39, 135, 103};
Physical Volume("vol") = {2, 1, 4, 3};
after i 3D mesh it and convering it using gmshToFoam, fixing the boundaries etc., loading the mesh using paraFoam, the inflow and walls apears great.
However, there are no inside cells.
It seems that the msh file does now contain the "vol" cells.
what am i doing wrong ? im sure its a no brainer
ps.
when trying to view the mesh in enGrid im getting the same problem.
Please HELP
Chapury is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh does not remove internal cells Binglian Hu OpenFOAM Meshing & Mesh Conversion 16 June 3, 2021 09:38
cellZone not taking all the cells inside rahulksoni OpenFOAM Running, Solving & CFD 6 January 25, 2019 00:11
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
