[snappyHexMesh] SnappyHexMesh Advice Please.
Old   April 15, 2011, 08:54
Default SnappyHexMesh Advice Please.
Mark Beal
msbealo is on a distinguished road
Hi
I'm trying to use snappyHexMesh on a simple yacht geometry but I'm having a couple of issues.
1) There seem to be single closed cell artefacts on the outside of the added boundary layers.
2) The boundary layers do not always cover the entire geometry.
(see attached file)
I've played with as many of the snappyHexMeshDict settings as I can and have improved the situation by changing featureAngle to 180 and changing the layers to absolute rather than relative.
If anyone has any advise then please let me know,
Regards,
Mark
P.S. I've just seen the snapEdge tool which might solve other issue.
msbealo is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
