[mesh manipulation] transformPoints and rotateMesh
Like Tree8Likes
Old   March 31, 2011, 04:51
Default transformPoints and rotateMesh
bephi is on a distinguished road
hi at all!
i have a mesh which i would like to translate and rotate so that the coordinate system is in the middle of the inlet (nearly a circle) and the z-axis should be normal to the inlet surface.
when i read in just the inlet i get the following coordinates:
Bounds:
X Range: 0.00153 to 0.00418 (delta: 0.0026)
Y Range: 0.159 to 0.16 (delta: 0.00179)
Z Range: -0.218 to 0.216 (delta: 0.00212)
does anyone know how i can accomplish my aim with the utilities transformPoints -translate and rotateMesh?
with regards!
bephi is offline   Reply With Quote
Old   March 31, 2011, 07:12
Martin
MartinB will become famous soon enough
Hi bephi,
simple way to get the center:
x_c = 0.5 * (0.00153 + 0.00418)
y_c = 0.5 * (0.159 + 0.16)
z_c = 0.5 * (-0.218 to 0.216)
Test in paraview:
- Just import "inlet"-patch
- Sources->Sphere
- insert x_c, y_c and z_c in "Center"
- "Radius" = 0.00005
More exact way:
- import "inlet" patch into paraview
- File->Save Data, "Files of type: .csv"
- FieldAssociation "Points"
- Import the .csv-file into OpenOffice Calc
- use "AVERAGE" function for each column
Result is: (0.002850023 0.159609 -0.2167553)
Check in paraview as described above.
Move mesh with:
transformPoints -translate "(-0.002850023 -0.159609 +0.2167553)"
Rotation:
The surface normal is "0.004016555 0.7621565 0.647346". Desired direction is "0 0 -1".
rotateMesh "(0.004016555 0.7621565 0.647346)" "(0 0 -1)"
That's it...
Have fun
Martin
chegdan, louisgag, tfuwa and 2 others like this.
MartinB is offline   Reply With Quote
Old   March 31, 2011, 07:50
Thank you very much! Everything worked fine! I always used a wrong normal vector! Now the mesh is like its supposed to be!
Old   December 10, 2011, 22:07
Ehsan
ehsan is on a distinguished road
Hi
I like to move my all cells of my mesh only by dx/2 and dy/2 and create a new mesh. Could you please help me how to apply transform mesh command to create a new mesh whose cells are moved by dx/2 and dy/2 relative to the first mesh?
Thanks a lot
Ehsan
ehsan is offline   Reply With Quote
Old   February 14, 2013, 00:14
Ali Khalifesoltani
asoltoon is on a distinguished road
Hi all,
I want to rotate my primary mesh block(around x axis) that is produced by blockMesh to align it with my STL file, but when I run:
rotateMesh "(0 1 0)" "(0 0 1)"
the following error appears:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : rotateMesh (0 1 0) (0 0 1)
Date   : Feb 14 2013
Time   : 08:36:43
Host   : "Ali-Laptop"
PID    : 3307
Case   : /home/ali/OpenFOAM/ali-2.1.1/run/tutorials/mesh/snappyHexMesh/wigleyTutor
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Writing points into directory "/home/ali/OpenFOAM/ali-2.1.1/run/tutorials/mesh/snappyHexMesh/wigleyTutor/constant/polyMesh"
--> FOAM FATAL ERROR:
No times selected
    From function rotateMesh
    in file db/Time/timeSelector.C at line 257.
FOAM exiting
when I don't rotate my mesh block and run SHM, then I can rotate the generated mesh but the rotation before final mesh generation is not possible. Can anybody help me?
Regards,
Ali
asoltoon is offline   Reply With Quote
Old   February 14, 2013, 01:44
Nima Samkhaniani
nimasam is on a distinguished road
Dear Ali
you can use following command
transformPoints -rotate  '( (0 1 0) (0 0 1) )'
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   February 14, 2013, 02:18
Ali Khalifesoltani
Thanks for the reply Nima.
Old   July 31, 2013, 10:21
Default rotate
sh.d is on a distinguished road
Hi namasam
I want to rotat airfoil without rotated mesh. and using simplefoam in Different angles of attack
please can you help me?
sh.d is offline   Reply With Quote
Old   July 31, 2013, 10:24
Nima Samkhaniani
its impossible to rotate airfoil but! fixed the mesh :P
you may want to change the direction of inlet velocity
Old   August 13, 2013, 05:13
Illya Shevchuk
linch is on a distinguished road
short & simple question: how to use the transformPoints utility from a custom directory?
Example:
transformPoints  -roots sourceDir/sourceCase -case targetDir/targetCase -scale "(2.0 2.0 2.0)"
returns error:
bool IPstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor
From function UPstream::init(int& argc, char**& argv)
in file UPstream.C at line 81.
FOAM aborting
I suppose, that the -roots option is the wrong one, isn't? But in the options list I don't see any suitable option, to specify the root dir:
Usage: transformPoints [OPTIONS]
options:
-case <dir> specify alternate case directory, default is the cwd
-noFunctionObjects do not execute functionObjects
-parallel run in parallel
-region <name> specify alternative mesh region
-rollPitchYaw <vector> transform in terms of '(roll pitch yaw)' in degrees
-roots <(dir1 .. dirN)> slave root directories for distributed running
-rotate <(vectorA vectorB)> transform in terms of a rotation between <vectorA> and <vectorB> - eg, '( (1 0 0) (0 0 1) )'
-rotateFields read and transform vector and tensor fields too
-scale <vector> scale by the specified amount - eg, '(0.001 0.001 0.001)' for a uniform [mm] to [m] scaling
-translate <vector> translate by the specified <vector> - eg, '(1 0 0)'
-yawPitchRoll <vector> transform in terms of '(yaw pitch roll)' in degrees
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
Using: OpenFOAM-2.1.x (see www.OpenFOAM.org)
Build: 2.1.x-c1330db6b6e8
Something like -root instead of -roots would be the right option. I also tried
transformPoints  sourceDir/sourceCase targetDir/targetCase -scale "(2.0 2.0 2.0)"
, but it seems I have to provide options, since the error is:
Wrong number of arguments, expected 0 found 2
Best regards,
Ilya
linch is offline   Reply With Quote
Old   August 13, 2013, 05:41
Nima Samkhaniani
maybe you want to choose -case
transformPoints -case <write your path> -scale '(2.0 2.0 2.0)'
Old   August 13, 2013, 07:28
Illya Shevchuk
Ah ok,
it works, thanks. For that, I have to copy the mesh from the source to the target first. I was just irritated by the Hrvoje's post:
Originally Posted by hjasak View Post
Try something like:
transformPoints <root> <case> -scale "(1e-3 1e-3 1e-3)"
Enjoy,
Hrv
Old   October 2, 2013, 09:07
Porisel is on a distinguished road
hi
i typed following and got an error
transformPoints -scale (1000 1000 1000)
before, i done blockmesh and snappyhexmesh.
the problem, the stl points will be interpreted as meters, but should be millimeters.
the error:
Wrong number of arguments, expectet 0 found 2
typed it in the case folder.
Porisel is offline   Reply With Quote
Old   October 2, 2013, 09:39
colinB is on a distinguished road
Dear Porisel
you are trying to use the wrong command!
the transformPoints command is used to transform an existing
mesh which has been created with sHM or blockMesh.
In order to transform your stl file however you need the command:
surfaceTransformPoints
to see how it works type: surfaceTransformPoints -help
To get more insight on the commands available and what to use
them for have a look at the documentation of OpenFoam
chapter 3.6 where you find a detailed list of all utilities.
regards
Colin
A CFD free user likes this.
colinB is offline   Reply With Quote
Old   October 2, 2013, 09:45
Hi colinB,
thank you for your answer.
i already have generated the mesh with blockmesh and snappyhexmesh. now i want to scale the whole mesh, because i dont want to have exorbitant velocity and pressure values
but i will try surfaceTransformpoints.
kind regards,
Porisel
Old   October 2, 2013, 10:25
Oh sorry I misunderstood your post:
"before, i done blockmesh and snappyhexmesh."
the error then is that you forgot the inverted commas around your vector
so the correct command reads:
transformPoints -scale '(1000 1000 1000)'
maybe you also have to add a source file and a target file
(I'm not sure, but for surfaceTransformPoints you have to do so)
regards
Porisel likes this.
Old   October 7, 2013, 02:56
with inverted commas it dont work, too. but with quotationmarks it works well.
Old   July 12, 2016, 10:46
Madeleine
Madi is on a distinguished road
Hi to all,
i tried to change my coordinate system. At the moment it is in the inlet, I tried to move it in the outlet at a waterlevel of 0.85. So i used
transformPoints -translate (15 0 0.85) But the only thing thats changed is that my mesh moved 15 m in x direction and 0.85 m in the z direction. The coordinate system remains the same. (Pictures)
Can someone fix my problem?
Tanks
Madi is offline   Reply With Quote
Old   July 12, 2016, 11:49
Madeleine
ok i found my mistake, i move it into the negative way (- 15 0 -0.85) Then it's Zero in the outlet.
But now i want to do setFields again. But i didn't work anymore? But why? I doesnt write in the alpha.water file and dont make a box in my case. Isnt it allowd to do setFields after transform points?
Old   October 19, 2016, 13:01
Gareth
bullmut is on a distinguished road
Small q: can i rotate a zone?
The utility says i can rotate a region but i would like to rotate a cell zone...
Any advice
bullmut is offline   Reply With Quote
