[Technical] General Grid Interface GGI basics
Like Tree3Likes
  • 1 Post By marcosch
  • 2 Post By hjasak
Old   February 6, 2009, 05:38
Default General Grid Interface GGI basics
Marco Schiller
marcosch is on a distinguished road
Hello!
I found the GGI mentioned several times as a possible solution to moving mesh problems.
But I have problems finding out what this method involves. Is it OpenFOAM specific (I found only few references from CAD programs)? Is it a documented (where?) standard?
Can you point me to a few tutorials or talks introducing the GGI on practical cases?
Thank you
Marco
Tobias Adam likes this.
marcosch is offline   Reply With Quote
Old   February 6, 2009, 06:10
Default Hello, I would first sugges
Hrvoje Jasak
I would first suggest you read the two presentations and a paper from Martin Beaudoin on the subject of GGI: this will give you some background on the theory and use. I am still hoping we will write a "proper" numerics paper once the extensions needed for the complete turbomachinery package in OpenFOAM are finished.
In OpenFOAM-1.5-dev, there is a tutorial in icoDyMFoam called mixerGgi that will show you the mechanics. Other cases, including partial overlap GGI, cyclic GGI etc will doubtless follow. I am particularly looking forward to getting the mixing plane code from the breeder into the main branch.
You can find the slides somewhere under www.openfoamworkshop.org; Martin can probably help you with the paper and other slides if you have trouble finding them.
Hope this helps,
Hrv
fumiya and Turin Turambar like this.
Hrvoje Jasak
Old   February 6, 2009, 07:27
Default Thank you, Mr. Jasak. I found
Marco Schiller
Thank you, Mr. Jasak. I found these slides to provide a first overview on the topic: http://www.openfoamworkshop.org/08/presentations/Turbomachinery/Beaudoin_Jasak.p df
But for getting started with the mixerGgi tutorial I hope that someone will point me to the second presentation and to the paper from Martin Beaudoin that you mentioned, because I still don't feel like understanding how the GGI works.
In 1.5-dev I find the mixerGgiFvMesh class, but only a mixer2D tutorial, no mixerGgi tutorial?
Thank you
Marco
Old   February 6, 2009, 11:20
Default Hello, We are waiting for t
Martin Beaudoin
mbeaudoin will become famous soon enough
We are waiting for the Berlin conference proceedings to be put online.
http://www.opensourcecfd.com/confere...tpage&Itemid=1
In the meantime, you can grab a copy of the GGI paper here:
http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/Berlin2008/Papers/OSCIC-08_BeaudoinMa rtinJasakHrvoje.pdf
Martin
mbeaudoin is offline   Reply With Quote
Old   January 5, 2011, 02:05
Jie
jiejie is on a distinguished road
If I want to extend the 2d mixer ggi case to 3d case (extrude) in the z-direction. How should I set the boundary condition for the top and bottom patches - "frontAndBackPlanes" in 2d case (e.g. wall or movingWallVelocity)? or should I set the part in the "insideSlider" as movingWallVelocity and the part in the "outsideSlider" as wall?
Thanks a lot
jiejie is offline   Reply With Quote
Old   January 12, 2011, 01:54
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
It depends what case you want to set up.
physical boundary wall and numerical boundary fixedvalue ; value uniform (0 0 0). if your top and bottom patches are stationary.
physical boundary: wall; and movingWallvelocity for numerical boundary may give you rotational patches.
Two cases should yield results.
You don't have to change the boundary condition of insideslider or outsideslider. it works for 3d. take care of nFaces and startFaces. make them conform to your mesh patches.
regards, Junwei
su_junwei is offline   Reply With Quote
Old   January 12, 2011, 02:08
Jie
Hi junwei
if I just want to extend the 2d mixerGgi to 3d, I thought the top and bottom surface inside the insideSlider should rotate as well? Am I right?
I set all of the top and bottom patches as wall.
However, I found that the stator (except the outsideSlider patch) is rotating during the simualtion as well, which causing the cell next to it to be skewed as shown at the screen shots on http://www.flickr.com/photos/58216789@N06/5348038235/
I think it might due to the set-up of moving faces and zones?
Old   January 12, 2011, 02:37
su_junwei's Avatar
su junwei
Hi junwei
I set all of the top and bottom patches as wall. However, I found that even the top and bottome patches that outside the outsideSlider are moving as well. Only the cells on the outsideSlider is fixed and it causing the cell next to it to be skewed as shown at the screen shots on http://www.flickr.com/photos/58216789@N06/5348011299/
Thanks
Oh, I get what you mean. A better solution is cut the up or bottom patch into two parts which exactly wrap the stator or rotator. You can set up two different boundary conditions for the two parts.
Even through you set up a rotatingwall or fixed value for top or bottom patch, the cell skewness will not appear, I think. In GGI, the rotator mesh are just rotated, the shape of cells will not be changed.
Regards, Junwei
Old   January 12, 2011, 18:40
Jie
Hi junwei
Regarding to your suggestion, I did have two parts for the top and bottom surfaces (one for stator and one for rotator). I think the rotation of the stator is due to the following reson:
After I compared the 3d case with the 2d case, I found that it only includes the cells in the rotator in the moving Cells in file /constant/polyMesh/cellZones for the 2d case. However, somehow it includes the cells from both stator and rotator in movingCells in the cellsZones file. It is very hard to separates the cells from rotator and stator. I am still trying to figure out how it happened at the first place.
Would you have any idea about this? Could it be due the meshing software? I am using icemcfd.
I have upload the case at http://www.megaupload.com/?d=2IIU3UVC
Old   January 12, 2011, 20:37
Jie
I am not sure whether it is the meshing problem or not. Now I can make the stator to be stationary by re-initialise the /constant/polyMesh/cellZones with the followings:
FoamFile
version 2.0;
format ascii;
class regIOobject;
location "constant/polyMesh";
object cellZones;
0
Then, the cellZones will be re-written with the celld from rotor part.
Cheers
Old   January 12, 2011, 21:43
su_junwei's Avatar
su junwei
cellZones? You don't need to define cellzones. mixggifvMesh will do it for you. You just need to define the face zone for the interface and its shadow of stator and rotator.
you can define a internal face and convert it fluent mesh and imprt it to openfoam with options -writeZones . Split the mesh along the interface using splitMesh .
alternatively, you can mesh the stator and rotator seperately and merge it using mergeMesh utility.
regards, Junwei
Old   January 12, 2011, 22:14
Jie
I think when I use fluent3DMeshtoFoam, OpenFOAM writes some stuff into the cellZones instead have an empty file. That's why I re-initialise it.
When you split the mesh along the interface, did you define this interface in the mesh when you are drawing it?
Regards,
Jie
Old   December 6, 2011, 13:07
Default movingWallVelocity
  #13
musaddeque hossein
musahossein is on a distinguished road
Does the keyword movingWallVelocity indicate surface moving with the mesh? In the sloshingTank2D problem, in the blockMesh folder, all the patches are defined as "walls" including atmosphere. The front and back are defined as "empty". In the U file in "0" folder, all the walls are defined in the following way:
boundaryField
walls
type movingWallVelocity;
value uniform (0 0 0);
does this mean that the front and back do not have to be defined, and the atmosphere (top wall) is defined as having velocity as well?
Any help would be greatly appreciated. Thanks!
musahossein is offline   Reply With Quote
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
"grid points" or "grid interface" ztdep Main CFD Forum 1 June 6, 2007 15:00
grid interface !!! ed FLUENT 3 July 24, 2005 06:51
periodic grid interface santosh FLUENT 3 August 30, 2001 10:06
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
