[blockMesh] Preview mesh in Paraview
Old   February 12, 2009, 10:23
Default Preview mesh in Paraview
Gareth
gareth__it_power is on a distinguished road
Hi
I'm getting to grips with the meshing in blockMeshDict, but find it frustrating that the only way to view the mesh is once I have applied all the initial conditions and run the model, then exporting to VTK and selecting wireframe. For some reason paraFoam does not work on my setup, so I can only use foamToVTK.
Is there a way to quickly export the mesh to paraView to have a look at it, after running blockMesh?
Many thanks
Gareth
gareth__it_power is offline   Reply With Quote
Old   March 25, 2009, 16:29
James
derjames is on a distinguished road
you can use Salome (3.2.x) to draw the geometry and then create and visualise the mesh. When you finish, save the created mesh as IDEAS and then use the ideasToFoam tool to conver to OpenFOAM format. There is a tutorial about this at the caelinux website www.caelinux.com
hope this helps...
j
derjames is offline   Reply With Quote
Old   March 26, 2009, 07:26
Johannes Baumann
johannes is on a distinguished road
Hi Gareth,
another option would be to use the native OpenFOAM-Reader by Takuya Oshima.
It's the only ParaView post-processing method I'm using at the moment and I'm very satisfied with it. And - important for you - it's possible to visualize the mesh whether or not there are result files available for that case.
Best regards,
Johannes
johannes is offline   Reply With Quote
Old   March 16, 2011, 17:43
sho
Son Ho
sho is on a distinguished road
I am new at OF and starting to learn it with OpenFOAM 1.7.1 on Ubuntu 10.10 on VMWare Player. To develop a mesh using blockMesh, I follow the steps from the tutorial:
1. Edit blockMeshDict
2. Run blockMesh
3. Run paraFoam
4. View mesh on paraFoam
5. Quit paraFoam
6. Repeat step 1
My question is that how can I eliminate step 5 (and therefore step 3 in the following cycles) and get paraFoam to update and view the new mesh?
Thanks.
Son
sho is offline   Reply With Quote
Old   March 17, 2011, 01:49
Martin
MartinB will become famous soon enough
Hi Son,
disable the "Cache Mesh" option (red arrow), click "Update GUI" option (green arrow) to enable the "Apply" button (just switch between On/Off all the time), click the "Apply" button (blue arrow). The updated mesh will be loaded and displayed.
Another feature, if you don't already use it, is to name the blocks in the blockMeshDict this way (be aware of "block_1" as a name for this block):
hex (15 9 52 58 23 16 59 66) block_1 (8 4 8) simpleGrading (1 1 1)
With the option "Include Sets" (yellow arrow) you can select the blocks to be shown in paraFoam. Disable the "internalMesh" option and select the blocks to be investigated instead.
Martin
MartinB is offline   Reply With Quote
Old   March 17, 2011, 10:59
sho
Son Ho
Thank you very much for the tips, Martin. I tried them out and it works perfectly.
I only have do the "disable Cache Mesh - enable Update GUI - click Apply" once. After that, I just have to click on the button "Refresh Times" in order to show the updated mesh (I use paraView 3.8.1 which came with openFoam 1.7.1 package).
Son
Old   June 3, 2011, 11:03
Mike
mikemech is on a distinguished road
Im trying to postprocess a mesh that I created with blockMesh, and I want to inspect separetely some blocks that I have saved in a "Sets" folder. I followed what MartinB said, but the problem is that Im using Paraview 3.10.1 on Windows XP. I cannot find the properties listed in Martin's screenshot in the object inspector!
Does anybody have an idea?
mikemech is offline   Reply With Quote
Old   June 3, 2011, 11:30
Martin
Hi Mike,
you can use foamToVTK this way:
foamToVTK -cellSet block_1
You will get additional .vtk files in the VTK folder and you can import the blocks independently.
Martin
Old   June 4, 2011, 12:13
Mike
Thanks Martin! It works perfectly
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Commercial meshers] MRF: imported mesh from ICEM not shown in ParaView and trying to merge with other n0ukh3z007 OpenFOAM Meshing & Mesh Conversion 0 September 20, 2015 15:04
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
