[Commercial meshers] problem about "gambit mesh converts to OF"
Old   June 10, 2011, 05:28
Default problem about "gambit mesh converts to OF"
桂莹
yingkun is on a distinguished road
hi,foamers
I used gambit to generate my mesh,and defined two interfaces,then in fluent I coupled them,but when I convert it to OF,in the boundary file,there still two interfaces,so I need to specify the boundary conditions,but I don't know what the boundary conditions are,and generally,we don't need to define the internal faces and their boundary condition,so what can I do?
can anybody help me?
Best regards!
ying
yingkun is offline   Reply With Quote
Old   June 10, 2011, 06:25
Olivier
olivierG is on a distinguished road
hello,
You may look at "mergeMeshes" or "mergeOrSplitBaffles", and at http://www.openfoam.com/docs/user/st...-utilities.php
regards,
olivier
olivierG is offline   Reply With Quote
Old   June 10, 2011, 06:36
桂莹
hi,olivier,
does it deal with the interface? I don't know what the command mean
thanks!
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[GAMBIT] Problem with mesh in Gambit giuseppemerlini ANSYS Meshing & Geometry 12 November 10, 2014 01:04
[GAMBIT] problem in 3d mesh with gambit m5m5kh ANSYS Meshing & Geometry 2 June 5, 2013 04:06
[Commercial meshers] gambit mesh to Foam problem AmirBaqa1987 OpenFOAM Meshing & Mesh Conversion 1 May 19, 2013 05:26
Problem for making mesh in GAMBIT chlim FLUENT 0 July 8, 2005 18:23
