[Commercial meshers] HRSG Simulation
Old   June 13, 2011, 16:15
Question HRSG Simulation
Hassaan Rafi
hassaan is on a distinguished road
I have made the geometry and have meshed it in Gambit (in 2D ).
I applied the boundary zones in the following way.
1. Water Pipes -- Wall BC.
2. One Edge as --Mass Flow Inlet
3. another edge as --Pressure Outlet
When i export it to Fluent, it loads properly but when i go to specify the boundary conditions at these zones. The 'mass flow inlet' and 'pressure outlet' zones are not listed there.
May i add i am new to CFD. So, your help will be greatly appreciated. Its my final year project.
Thanks in advance.
hassaan is offline   Reply With Quote
Old   June 14, 2011, 03:26
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
OpenFOAM isn't supposed to recognize the kind of BC you set up, but it will recognize the patch name you gave in Gambit.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 16, 2011, 17:27
Hassaan Rafi
I see but for some reason it was not even recognizing all the patch names.
However, i am now using ANSYS 12.0 to solve the case and i am facing another difficulty. I am new to CFD analysis and i cant seem to figure out how to use wall BC to simulate heat transfer between two fluids.
I am analyzing the heat transfer between two fluids separated by a metal pipe. I am using the wall boundary condition to separate the fluids. However, i am unable to understand how to use the wall BC.
Can anyone help me with this? any examples or tutorials than can be of help? Thanks in advance!
boundary condition, fluent 12.0, gambit 2.4.6, hrsg
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 09:36
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 05:28
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 02:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 15:06
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 03:16
