June 20, 2011, 14:01 |
makeAxialMesh for OpenFoam-2.0.0
when I compile the makeaxialmesh in openfoam 2 I enconter bellow problem please help me to compile makeAxialMesh
Making dependency list for source file makeAxialMesh.C could not open file repatch.H for source file makeAxialMesh.C SOURCE=makeAxialMesh.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yas/OpenFOAM/OpenFOAM-2.0.0/src/dynamicMesh/lnInclude -I/home/yas/OpenFOAM/OpenFOAM-2.0.0/src/cfdTools/lnInclude -I/home/yas/OpenFOAM/OpenFOAM-2.0.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/yas/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude -I/home/yas/OpenFOAM/OpenFOAM-2.0.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/makeAxialMesh.o makeAxialMesh.C: In function ‘void changeCoordinates(Foam:olyMesh&, Foam:lane, linie&, Foam::scalar, Foam::scalar, bool)’: makeAxialMesh.C:198: error: ‘mathematicalConstant’ has not been declared makeAxialMesh.C:199: error: ‘mathematicalConstant’ has not been declared makeAxialMesh.C: In function ‘void splitWedge(Foam:olyMesh&, Foam::word, Foam:lane)’: makeAxialMesh.C:255: error: invalid use of incomplete type ‘const struct Foam::SubField<Foam::Vector<double> >’ /home/yas/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.H:62: error: declaration of ‘const struct Foam::SubField<Foam::Vector<double> >’ makeAxialMesh.C:257: error: invalid use of incomplete type ‘const struct Foam::SubField<Foam::Vector<double> >’ /home/yas/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.H:62: error: declaration of ‘const struct Foam::SubField<Foam::Vector<double> >’ makeAxialMesh.C:258: error: invalid use of incomplete type ‘const struct Foam::SubField<Foam::Vector<double> >’ /home/yas/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.H:62: error: declaration of ‘const struct Foam::SubField<Foam::Vector<double> >’ makeAxialMesh.C:261: error: invalid use of incomplete type ‘const struct Foam::SubField<Foam::Vector<double> >’ /home/yas/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.H:62: error: declaration of ‘const struct Foam::SubField<Foam::Vector<double> >’ makeAxialMesh.C:262: error: no match for ‘operator[]’ in ‘fcs[faceI]’ make: *** [Make/linux64GccDPOpt/makeAxialMesh.o] Error 1 |
June 20, 2011, 18:53 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I won't have time to look into this for the next month (actually I have time, but there is more interesting stuff to do during vacation). For the time being I'd suggest that you use makeAxialMesh from one of your working 1.x-installations (the solver doesn't care where his mesh comes from, unless the mesh format changed). If you want to be sure that I remember porting it please add a ticket at https://sourceforge.net/apps/mantisb..._view_page.php (Section "Breeder Stuff" - MAM doesn't have its own section). Of course: if somebody beats me with porting it ... I can live with that Bernhard |
June 20, 2011, 19:00 |
#3 | |
Laurence R. McGlashan
Rep Power: 23 |
grep -lre 'mathematicalConstant::' . | xargs -d'\n' sed -i 's/mathematicalConstant::/constant::mathematical::/g'
Laurence R. McGlashan :: Website Last edited by l_r_mcglashan; June 20, 2011 at 19:19. |
June 21, 2011, 05:06 |
Hi McGlashan
thanks for your explanation with your command the makeAxialMesh is compiled I want to Run flow filed about a cone and I create a 2D mesh for this geometry can you help me to convert this mesh to a axisymmetric mesh (wedge mesh) ? if It is possible Please give me your Email best regards |
August 31, 2011, 03:15 |
#5 | |
Jordi Muela
thanks! This worked for me! But now i'm having a problem with the function 'collapseEdges'. Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 Foam::polyMesh::calcDirections() const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::polyMesh::polyMesh(Foam::IOobject const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/collapseEdges" #6 __libc_start_main in "/lib/libc.so.6" #7 in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/collapseEdges" Best regards, Jordi. |
August 31, 2011, 07:06 |
#7 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
September 9, 2011, 07:53 |
Jordi Muela
sorry for my late answer. First of all, thanks for the new version . I've tested it with the testcase, and it works perfectly, as you've said. But i'm still having the same problem with my own case. The problem starts when i do the makeAxialMesh. Before using the utility makeAxialMesh, if i do a checkMesh i'm obtaining a "Mesh OK", but if i do the checkMesh after run makeAxialMesh then i'm getting the same message error (floating point exception) that i've posted in the previous post, thus it's a problem with my geometry and the utility makeAxialMesh... I'm using makeAxialMesh utility after a snappyHexMesh and a extrudeMesh (great improvement of this tool in OF 2.0.x!), because i'm using a STL geometry but i want to solve the case in 2D axisymmetric. In OF 1.7.1 it works great... I attach an image of the mesh after the makeAxialMesh with the patch names... it's seems ok, at first view.. Thanks a lot for your time, i keep investigating. Jordi. |
September 12, 2011, 05:50 |
#9 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
What you could do to pinpoint this problem: use MAM 2.0 then do checkMesh and or collapseEdges with 1.7. If that works then something in 2.0 was reimplemented that makes this fail. In that case write a bug-report on the OpenCFD-Mantis Bernhard |
September 19, 2011, 23:14 |
Pallav Jha
Hi Bernhard,
I am using your makeAxialMesh utility with OF-2.0 but running into problems that I cannot resolve. <code> object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (5 505 -0.5) (0 505 -0.5) (5 500 -0.5) (0 500 -0.5) (5 0.5 -0.5) (0 0.5 -0.5) (15 500 -0.5) (15 0.5 -0.5) (5 505 0.5) (0 505 0.5) (5 500 0.5) (0 500 0.5) (5 0.5 0.5) (0 0.5 0.5) (15 500 0.5) (15 0.5 0.5) ); blocks ( hex (3 2 0 1 11 10 8 9) (20 5 1) simpleGrading (1 1 1) hex (5 4 2 3 13 12 10 11) (20 1000 1) simpleGrading (1 1 1) hex (4 7 6 2 12 15 14 10) (30 1000 1) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 1 9 8) ) wall inletWall ( (0 2 10 8) ) patch atmosphere ( (7 4 12 15) (4 5 13 12) (2 6 14 10) (6 7 15 14) ) empty frontAndBack ( (1 0 2 3) (2 6 7 4) (3 2 4 5) (9 8 10 11) (10 14 15 12) (11 10 12 13) ) patch center ( (1 3 11 9) (3 5 13 11) ) ); mergePatchPairs ( ); // ************************************************** *********************** // <code> makeAxialMesh writes the new mesh to 0.01; however, collapseEdges 1e-8 180 gives Collapsing 0 small edges Collapsing 0 in line edges The same is for values from 1e-6 to 1e-8 Please advise me as to what I should do. Thanks and regards. |
September 20, 2011, 03:54 |
#11 |
Jordi Muela
Hi Pallav,
Are you running OF 2.0.x? This code for the dictionary blockMeshDict that you've posted is wrote in OF 1.x.x syntax, it shouldn't work in OF 2.0.x. Best regards, Jordi. |
September 20, 2011, 05:01 |
#12 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If that is not the problem visually check the mesh in paraview |
September 20, 2011, 21:07 |
#13 | |
Pallav Jha
Hello Bernhard,
Thanks for your reply. Here are the steps that I took:
<code> // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0.01 Merging: edges with length less than 1e-08 meters edges split by a point with edges in line to within 179 degrees Collapsing 1006 small edges Morphing ... Collapsing 0 small edges Collapsing 0 in line edges Max face area:6.54291e-07 Collapse area factor:1e-09 Collapse area:6.54291e-16 Collapsing 0 small high aspect ratio faces Writing collapsed mesh to time 0.02 End <code> So, if I understand correctly, the final axisymmetric mesh is in the folder 0.02. How do I check the mesh for this time step? I get an error if I try paraFoam or paraView. Thanks a lot. Regards, Pallav Quote:
I am running OF-1.7-x on a supercomputer. I run OF-2.0.1 on my laptop. I have run the corresponding svn codes to build makeAxialMesh at both places. I transferred the case_folder from the supercomputer and ran it on my laptop. Hence, the difference in syntax in the blockMeshDict file. However, there is no problem when I run 'blockMesh'. checkMesh gives 'OK' However, I did get the same error as you when I did a checkMesh after makeAxialMesh. So, I went back to the supercomputer and did everything from scratch in OF-1.7-x Thanks and regards. |
September 21, 2011, 05:33 |
#14 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Of course the error would be helpful. Try the following: deselect all fields before changing the time-step. Alternatively rerun all mesh-manipulation with -overwrite. That would make sure that the final mesh is in constant/polyMesh |
September 21, 2011, 18:40 |
#15 |
Pallav Jha
Thank you Bernhard.
I was able to visually check the mesh and everything looks great. (OF-1.7) I adapted the new patches to the p_rgh, U, etc. files as per your comment about adapting fields at http://www.cfd-online.com/Forums/ope...tric-flow.html However, I run into a few errors. I guess this is not the correct thread to discuss about the same. I will post them in some other thread. Thanks once again for your help. Regards, Pallav |
October 2, 2015, 08:46 |
makeAxialMesh
#16 |
Antony Premkumar
Rep Power: 10 |
Hi Guys,
I would like to compile makeAxialMesh . I have downoaded from openfoamwiki. But i dont know how to compile it. Please help me. Thanks&Regards, Antony |
October 11, 2015, 08:47 |
#17 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I've added a chapter in the wiki page that explains how to install: http://openfoamwiki.net/index.php/Co...h#Installation
October 14, 2015, 04:23 |
checkMesh
#18 |
Antony Premkumar
Rep Power: 10 |
Thanks wyldckat,
I have yet another problem. I am doing a external flow study on a axis symmetric body. I am using blockMesh -> snappyHexMesh -> makeAxialMesh -> collapseEdges. when i view the mesh it is all fine . but when i check the mesh with 'checkMesh' i am getting 7 errors. I have attached the log file i received for checkMesh. Is there anything that i have to do with rotationDict or collapseDict? Code:
Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 100 202 ok (non-closed singly connected) outlet 100 202 ok (non-closed singly connected) upperWall 1200 2402 ok (non-closed singly connected) frontAndBack 0 0 ok (empty) lowerWall 1532 2677 ok (non-closed singly connected) ua1 31770 32535 ok (non-closed singly connected) frontAndBack_pos 142483 145823 ok (non-closed singly connected) frontAndBack_neg 142375 145713 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-1.1 0 -0.0141658) (4.6 0.325 0.0141868) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) Wedge frontAndBack_pos with angle 2.49754 degrees ***Cannot find opposite wedge for wedge frontAndBack_pos Boundary openness (-9.02861e-19 1.54122e-14 1.31133e-12) OK. ***Open cells found, max cell openness: 0.0218662, number of open cells 152521 <<Writing 152521 non closed cells to set nonClosedCells <<Writing 228809 cells with high aspect ratio to set highAspectRatioCells ***Zero or negative face area detected. Minimum area: 0 <<Writing 130 zero area faces to set zeroAreaFaces ***Zero or negative cell volume detected. Minimum negative volume: -7.9226e-17, Number of negative volume cells: 120358 <<Writing 120358 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 175.974 average: 70.2632 *Number of severely non-orthogonal (> 70 degrees) faces: 330991. ***Number of non-orthogonality errors: 306103. <<Writing 637094 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 1338 faces are incorrectly oriented. <<Writing 1338 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 1.58762e+06, 118079 highly skew faces detected which may impair the quality of the results <<Writing 118079 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 7 mesh checks. End |
October 17, 2015, 10:44 |
#19 |
Bruno Santos
Rep Power: 128 |
Quick answer: I very rarely need to use wedges, so I don't remember how it works exactly.
I need at least an example case based on the one you have to work with, so that I can inspect and do a bit of trial and error myself. |
October 27, 2015, 10:14 |
#20 |
Antony Premkumar
Rep Power: 10 |
@wyldckat. Thanks. I have also searched for examples online but was unlucky.
I am doing this work as a 'Studien Arbeit' at my university. |
[mesh manipulation] makeAxialMesh and axisymmetric flow | yassepid | OpenFOAM Meshing & Mesh Conversion | 5 | January 28, 2024 22:38 |
[Other] Installing makeAxialMesh - strange wmake error | krzychu111 | OpenFOAM Community Contributions | 1 | December 19, 2018 18:29 |
[mesh manipulation] How to make a pipe using makeAxialMesh | tomloh | OpenFOAM Meshing & Mesh Conversion | 15 | September 3, 2013 05:52 |
[mesh manipulation] makeAxialMesh - installation issues | simulator4711 | OpenFOAM Meshing & Mesh Conversion | 3 | March 21, 2012 07:59 |
OpenCFD release OpenFOAM® version 2.0.0 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 1 | July 1, 2011 08:43 |
