[blockMesh] patch on a plane
Old   July 20, 2011, 17:26
Default patch on a plane
dshawul is on a distinguished road
I have a blockMeshDict with many blocks (hexs) in it. When specifying the patches, I have to include all faces of the blocks that are considered as inlet for example. This is very tedious and I want to specify just a plane so that all faces lying on that plane will be included as patch. x = 0 is inlet , x = 10 is outlet, y = 12 is top etc... Is it possible to do that ?
dshawul is offline   Reply With Quote
Old   July 20, 2011, 18:27
Retired Super Moderator
Bruno Santos
Greetings Daniel,
I think that what you are looking for is createPatch. To find more about it, see the files that appear when running this command:
find $WM_PROJECT_DIR -name "createPatchDict"
Best regards,
Bruno
Old   July 22, 2011, 10:47
Thank you very much,
It took me long to understand how it works but that is exactly
the tool I needed.
regards,
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Boundary Patch is not a strict Plane Error using CFX Mesher pizzaspinate CFX 6 September 15, 2015 05:27
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
